Ignition coil wrong on 919 manual? - Wrist Twisters
post #1 of 3 Old 03-18-2013, 07:58 PM Thread Starter
Can anyone tell me if the ignition coils on page 377 (17-0) in the manual are right. My spark plug wire are numbered and they go as follows. The coil behind the radiator is numbered for 1 and 4 and the coil on the left side is 2 and 3(clutch side) The manual says left side is 1 and 4.? Now the diagram underneath the (system diagram) shows #4 is Y/Blu, which is the front coil. #3 is BLu/y Which is the left hand side coil. I've read from others here that I am right and the picture here is wrong.? What does your 919 look like?
erked in fortmyers is offline
post #2 of 3 Old 03-18-2013, 09:19 PM
first off... please stop making new threads, use your original thread and if you want the name of it changed to something more generic then hit up a moderator.
It doesnt matter what coil fires what pair, so long as the harness is plugged into the proper one corresponding to the proper pair of cylinders. that stated one coil has a set of wires that fits better to its pair of cylinders compared to the other.
post #3 of 3 Old 03-19-2013, 08:34 AM Thread Starter
I'm have not learned the ways of this site yet, post vs. thread. I will learn! Also I was hoping for a quick reply. Thanks for info on coils. I just wanted to have the facts of the manual straight.
I just got a call from the news station and they wanted to know what was going on with my 919.
Told them about doing compression test. Got 135 psi on 1,2 and #4 cylinders and 180 on #3. She told me to take my bike in and tell them to fix it or they WILL send a cameria crew out to investigate the situation.
So I want to have all my information correct..
