Idle is jumpy - Wrist Twisters
 1Likes
  • 1 Post By johnfellows
post #1 of 10 Old 03-04-2017, 01:28 PM Thread Starter
captainchadl's Avatar
Idle is jumpy
The other day when I was riding, I felt that the idle was fluctuating a lot. At first, it was jumping to ~1300 rpm then later on that day it was jumping to 1500rpm (as the gauge measures). I checked the fuel pressure regulator and it will hold a vacume, so it is not leaking. I just changed the spark plugs, but I have not had a chance to take it for a ride since then.
Any other suggestions of possible causes would be appreciated.
captainchadl is offline
post #2 of 10 Old 03-04-2017, 02:05 PM
nathanktm's Avatar
You sure the choke is pushed in all the way?
nathanktm is offline
post #3 of 10 Old 03-04-2017, 02:13 PM Thread Starter
Yes, it is definitely pushed in all the way.
post #4 of 10 Old 07-15-2017, 09:36 AM
My idle goes up about that much after the bike is fully warmed up. Cold it starts around 1000, warm its around 1300
ewmin3m likes this.
johnfellows is offline
post #5 of 10 Old 07-15-2017, 09:40 AM
TWSS
post #6 of 10 Old 07-15-2017, 01:54 PM
Suggest you also check your cable slack.
If there is not enough free play, certain bar positions can effect the idle speed.
mcromo44 is online now
post #7 of 10 Old 07-16-2017, 07:31 PM
TheScientist's Avatar
Not on a bike but in vehicles I've had troublesome idle with air in the coolant lines.
2003 Honda CB900 919 Hornet - Current
1999 Suzuki Bandit S1200 - sold
1986 Honda Magna V65 - sold
TheScientist is offline
post #8 of 10 Old 07-21-2017, 07:15 AM
Moto-Doc
Nealio919's Avatar
Mine will surge at idle. It will do it when warm but very little. When cold it has a tendency to surge a little rougher on warm up. This was never present in stock form. When I added exhaust, BMC filter, PCIII, air-box mod, PAIR valve block off plates and smog removal- that's when I noticed it. I KNOW mine is a tuning issue as I am running a generic map and my symptoms change with different maps available.
Can you tell us what modifications you have done to your bike? I am betting you have the same issue.
2006 Honda 919 TURBO
2014 Honda CB1000R
2005 Ducati Monster S4R
2000 Honda 750 Nighthawk -Sold
1997 Suzuki DS350SE -Sold
2002 Honda 750 Shadow ACE -Sold
2006 Kawasaki ZX-6R -Sold
2003 Honda CBR954RR (Drag Bike) -Sold
2002 Honda CBR954RR -Sold
1992 Honda 750 Nighthawk -Sold
1972 Honda CB350 -Sold
Nealio919 is offline
post #9 of 10 Old 07-21-2017, 10:40 AM
G'day Neilio919. How's Pvster's sato map been running for you?
Also Captain my bike came with a surge or a pulse a idle and very low revs. This has mostly gone now. A starter valve synchronization and pc111usb pretty much did this.
post #10 of 10 Old 07-24-2017, 08:11 AM
Moto-Doc
Nealio919's Avatar
Good day to you as well!
The Pvster Sato map did okay. I ran the bike for an entire tank with this map to give it a fair shake. I feel it is a good "street" map. It was smooth at all revs when cruzing around, and throttle response under no load was acceptable. However for my application, temperature, altitude (about 1,100 ft), air density, and riding style- this map does not cut it... It is in my opinion very LEAN. My bike ran hotter temperatures than normal, and was lacking in the power delivery significantly. I also found myself using the choke alot in the cool mornings and engine start was more difficult when hot. I switched back to the "yoshi" map and was instantly reminded of what I had been missing. This will have to do till I get a custom tune.
Mods: Delkevic SS70 exhaust w/o inserts (Y-pipe and two cans with stock header), BMC air filter, PCIII, PAIR block off plates and smog removal, intake flapper mod- vacuum pod, and flapper removed and pod hole covered and smoothed out.
2014 Honda CB1000R
