Idea to stop the chain adjusters from moving, lock nut inside. - Wrist Twisters
 2Likes
  • 2 Post By Islandboy
post #1 of 3 Old 05-29-2019, 06:13 PM Thread Starter
Just remove the rear tire to do the swing arm bolt switch. I took out the adjusters to see if I had a nut that would fit the threads. So far, no luck.
My idea is to add a nut inside the adjuster on the threads where it screws into the swing arm. You would get in there and loosen it up, adjust as needed, the tighten up the lock nut. It might be tough to get a wrench in there, but it's worth trying.
IDK if it's a common size or not, but I'm not having much luck finding a match so far.
post #2 of 3 Old 05-29-2019, 06:29 PM
By eye and steel rule it looks like a nominal 8mm diameter by peering down from above.
The threads look fine.
So, it is an 8, then it's like M8-1 as compared to the normal coarser M8-1.25 thread pitch.
I doubt a hex nut would even clear while turning, let alone how to get an open end wrench on it.
post #3 of 3 Old 05-29-2019, 06:32 PM
Put your nuts on opposite lock to one another. So that they work against the force applied to the rear axle by the drive chain. I've never had mine come loose by doing this.
mcromo44 and badmoon692008 like this.
