I screwed up big time installing PCIII. HELP PLEASE! - Wrist Twisters
post #1 of 16 Old 11-12-2013, 04:06 PM Thread Starter
Please don't ask why, or how I arrived at the place I am. I just don't want to make further mistakes. In the process of adding a power commander, I cut the red wire with a yellow tracer. All the way back to the grey plug. My soldering skills are terrible. I have two choices; replace the entire electrical harness, or hire an electrician to rewire the red wire with yellow tracer to the plug. Please look at the picture I've attached of the damage, and weigh in.
Thanks,
-Rudy
RudyHuxtable is offline
post #2 of 16 Old 11-12-2013, 04:07 PM Thread Starter
PS, in the bottom right hand corner, you can see the remnant if the red wire with yellow tracer.
post #3 of 16 Old 11-12-2013, 04:10 PM
Crap dude. Crack the case if you can, might find a bit more wire inside to solder to.
But if you are not good at soldering, find a friend that is.
post #4 of 16 Old 11-12-2013, 04:19 PM
You need to open that cannon plug, de-pin the wire and add some length to it.
Its not hard to do, but judging by the pic above .... you should seek some help.
post #5 of 16 Old 11-12-2013, 04:23 PM
Helimech, run over there with your Dremel
post #6 of 16 Old 11-12-2013, 04:26 PM
Could you imagine the damage a dremel would cause in that mans hands!
you could use a razor blade and blow torch too ...... oh never mind!
post #7 of 16 Old 11-12-2013, 05:03 PM Thread Starter
would it just be easier to buy a new cannon plug and run it to the source? I'm not sure this is salvageable. And I dont know anyone with soldering skills personally
post #8 of 16 Old 11-12-2013, 05:09 PM Thread Starter
Best approach for crack the plug?
post #9 of 16 Old 11-12-2013, 05:21 PM
I yi yi... Why on earth would you cut it right at the plug???
You do NOT need to cut / break the plug. Undo the plug from the ecu... Look at the pin there will be a little metal tab that holds it from backing out. Push the tab and then you can push the pin out and solder some wire on to the pin... Directly connect that to the wire you chopped... And do one of two things... 1. Forget the power commander.... 2 take it yo someone who knows what they are doing.
Also pretty sure you never have to cut any wires... Should just be able to use splices.
EDIT: Not to be a dick, but if you cant easily figure out how to get the pin out of the plug itself (you should not have to split the plug apart... each pin has a small rubber gasket on the back of it as seen in the pics... all of which are just pressed into the plug itself and held in by the aforementioned metal tab) i would stop working on it... i would hate to see you cause damage to the point where a new ecu is needed.
post #10 of 16 Old 11-12-2013, 05:23 PM
There should be a few tabs & safety looks to pop/press to split it into a few pieces, its a weather proof plug and might be tricky to get the pieces to separate.
post #11 of 16 Old 11-12-2013, 07:02 PM Thread Starter
Thanks for your help guys. I'm going to have someone else handle this. I've been through a lot lately and probably shouldn't be riding anyhow.
post #12 of 16 Old 11-12-2013, 09:01 PM
w/e it has been man hope it all works out.
Definitely do not go on a motorcycle ride with a completely scrabbled worn out mind. Only so so once you have gotten to the point where w/e it is can be put on the back burner and you can concentrate mentally solely on riding while moving.
I have hurt myself on the dirbike a time or two taking anger / aggression / mental hurt out on the motorcycle, and it was a big eye opener that it should never be done on a street bike.
Good luck with the power commander install, sorry it went south, and if you need any more help dont hesitate to ask.
post #13 of 16 Old 11-13-2013, 06:13 AM
100% agree with this! I had a rough fall at work & barely had any seat time because of it. I was working 60+ hr weeks, working back shift ..... Be safe, be sure and have your head in a good space before u ride.
OP .... Try to find a dedicated electrical shop or small bike shop to give u a hand. Don't go to the dealership, they will want try to replace the full harness. Maybe even a car audio place, they don't need to know motorcycles.... Just be comfortable with de-pinning connectors.
post #14 of 16 Old 11-14-2013, 07:28 PM
If you were closer, I could do it in a jiff.
I agree with the above, an audio shop might be a good place to look. Many are familiar with connectors and soldering. Don't go someplace they let some high school kid do installs (*cough* Best Buy *cough*)
post #15 of 16 Old 11-14-2013, 10:12 PM Thread Starter
Hey guys, good news! I found a guy through the local rider forum. He puts together solar panels and did a fantastic job fixing my mess. Helped me out the bike back together and made sure it was running right. All good! Thanks for your support
post #16 of 16 Old 11-17-2013, 04:43 AM
No association w/ Tirone.
redletter's Avatar
Glad to hear you got it straightened out! I had a hard time soldering that splice in until I dropped the whole plastic rear section to get my hands in there, enjoy the PC3.
redletter is offline
