I need help!! 919 noise - Wrist Twisters
post #1 of 10 Old 06-15-2009, 06:45 PM Thread Starter
Well, I got a problem and here my story.
I have an 04' 919, It's been great I had it for almost a year now, Over the winter I replaced the chain and sprockets and switched over to a wave rotor (not that I think this matters). I just got it out about 3 months ago and it's was fine for about 2 months, about a month ago I started getting a clunking noise when I'd roll the bike (Sounds like a chain binding) and when I got up to 100kph I hear a loud whirling noise.
For awhile I thought it was the chain, after cleaning and lubing and cleaning and lubing, the noise wouldn't go away. Then I realized I had play in the rear wheel, so I bought new bearings for the rear and put them in, the noise is still there. So I started trying different combination's using my old sprockets and stuff, then I started removing things. (I also realized I had the wheel spacers backwards for few weeks but when I switched them back the noise still persists) I removed everything until I was down to just the rear wheel, axel and the spacers, when the tire spins I hear this really loud clunk (sounds like metal and metal) within the wheel/hub, the right side caliper spacer doesn't move so I've ruled that out, and it's inconsistent when it's spinning around, it almost never does it in the same spot. When the axel nut just hand tight, it doesn't make the noise, but when you tighten it snug or to the proper torque the noise then appears.
I'm stumped, If anyone has an idea I could really use it, and thanks for the help.
Epicsoldier is offline
post #2 of 10 Old 06-15-2009, 07:47 PM
look in a parts catalog and check the exploded view.. make sure there are no parts/spacers etc missing... check the bearings again... (i know they are new) but i have seen brand new bearings in the box that were covered in rust..
post #3 of 10 Old 06-15-2009, 08:02 PM Thread Starter
I checked through my service manual and everything seems to be there, I guess that's my next choice is to pull the bearings back out
post #4 of 10 Old 06-15-2009, 08:08 PM
Last time I adjusted my chain, I had it a little too tight. It would make a clunking noise when I would roll the bike. I pulled the counter shaft sprocket cover and it was coming from that area. The counter shaft sprocket has a little play in it ....I loosened the chain up a bit and it went away.
Good luck!
post #5 of 10 Old 06-15-2009, 08:20 PM Thread Starter
Well the noise started before I even replaced the bearings, but I'm not ruling that out.
As far as the chain goes, I pretty much ruled that out I think, Even without the chain around the rear sprocket, and the wheel just rolling on the axel is doesn't make the noise till you tighten it up, it's within the wheel I'm sure.
post #6 of 10 Old 06-15-2009, 09:40 PM
Corner speed sets u free
streakin919's Avatar
I know this sounds crazy, but since the wheel is hollow i would check to make sure there isn't something being flung around in there. another thing to rule out before you start spending money.
streakin919 is offline
post #7 of 10 Old 06-16-2009, 04:56 AM
This has been discussed a few times. I believe the answer was that the countershaft sprocket needs to be greased. I'll try to search for another thread.
post #8 of 10 Old 06-17-2009, 11:08 AM Thread Starter
I think I got it, I studied the diagram in the service manual and it looks like Honda forget to get a part when ordering the bearings.
Thanks guys!
post #9 of 10 Old 06-18-2009, 03:53 AM
not cro-magnon
Relic11's Avatar
Thanks guys!
Which part?
Relic11 is offline
post #10 of 10 Old 06-18-2009, 07:58 AM Thread Starter
On the sprocket hub bearing, there's a sleeve that is supposed to be pressed into the bearing that fills in the space between that hub and the wheel itself. When it's not in, it allows the bearing to move side to side.
