I didn't do this when I rebuilt the clutch, what does it mean? - Wrist Twisters
 3Likes
  • 1 Post By mcromo44
  • 1 Post By Islandboy
post #1 of 14 Old 10-30-2019, 12:11 AM Thread Starter
I was looking at this page and noticed a pic of the clutch where it says this:
"...but here make sure you see that the outermost plate fits in an alternate grove"
At the bottom of this page:
cbr900f, 919, Hornet Factory Pro 800 869-0497 EVO Shiift Star Kit
I replaced the friction disks a few months back and never knew anything about this "alternate grove" and have no idea if I did it or not, I just put the new friction disks in.
What is this and why do we need to do it, what happens if I didn't get it right?
post #2 of 14 Old 10-30-2019, 09:17 AM
Not so fast.......
My guess is that you are alright.
The "alternate" just means fitting things up on the basis of disc/plate/disc/plate etc. as you do the stack building up of the basket.
The outer "disc" gets indexed differently, noting that the OEM outer is colour coded Green.
So as long as you first fitment was a disc, and you then "alternated" correctly with your subsequent fitments, and used the dedicated outer disc in the outer position and mounted it to the clutch cover, you are A OK.
Just revisit your work by memory based on the above, and see if you think you still might have an issue.
Hopefully you don't.
post #3 of 14 Old 10-30-2019, 09:38 AM Thread Starter
Not so fast.......
I don't remember the last disk being different. I remember the first disk in was different and so I followed the pattern that was there already, but I don't remember any of the other disks being different.
I see here that there are 3 different disks:
https://www.bikebandit.com/oem-parts...1093#sch416190
I don't remember buying 3 different types of disks and I specifically remember going thru every one of them.
I only remember the "odd" one that was a bit different in size and that went first. I wonder what the difference is in the last one.
post #4 of 14 Old 10-30-2019, 10:30 AM
Sorry, but I don't know about the 3 disc types at all, and have no way to determine it.
You mention one being differently sized and that you put it in first.
Is that because of comparison to what you removed, or is it the only one that fits there?
Did you get OEM parts?
If so, the outer disc is supposed to be green.
If it ends that you have OEM parts, with one green one, and yet another that is different from the others and only fits inboard, then simply take it apart and check your stack build and rearrange if need be.
Short story, it seems to me that you are stuck having to open it up again.
post #5 of 14 Old 10-30-2019, 12:24 PM
Meh... not an hard task. This pic was dated 09/05/2002 and as best as I can remember I had not owned the bike for no more than a week before I had it apart...
post #6 of 14 Old 10-30-2019, 12:46 PM
Almost a whole week before tinkering with a new bike.
Excellent!
I remember riding home on my new CB750 in '73 with a set of clubman bars in my backpack, having just picked up the bike from Sturgess in Hamilton Ontario.
Let's just say my Dad didn't understand why I was making changes on a brand new bike I'd only had for less than an hour.
Just thinking about it makes me smile again.
WxN likes this.
post #7 of 14 Old 10-30-2019, 02:39 PM Thread Starter
I don't mind opening it up, but I know for a fact that at least one disk was different. I took the stack of disks and compared each one, including the markings.
Maybe this will help explain:
https://www.partzilla.com/catalog/ho...-ac-919/clutch
In this pic, you see items, 7, 8 and 9. Used in these quantities: 1, 6, 1
So you have 3 different part numbers used in the set of friction disks.
22201-MAE-000 qty 1
22201-MAE-E00 qty 6
22202-MAE-000 qty 1
I actually ordered thru Partzilla, and my order history shows that I ordered exactly that... 3 part numbers plus the clutch cable.
However, I don't remember seeing the difference other than the one "odd" one that was clearly very different.
I also didn't really need the clutch, once I changed the oil, the slippage went away and I wasn't able to reproduce it. When I measured the old vs new clutch pack stacked together... I could NOT tell the difference. I went ahead and installed the new disks that had been soaking for a long time.
By that time, they were LONG out of the package... So no chance of tracing it back using the package... I'd need to know the markings or how do you tell one from the other?
It didn't even occur to me, that there were 3 unique disks until I say the first pic posted and I couldn't remember if I actually set the 3rd disk type as last and don't know how to see which is which.
post #8 of 14 Old 10-30-2019, 02:58 PM
Often colour coded on edge.
Final disc goes into alternate groove.
Do you still have your old discs?
mcromo44 likes this.
post #9 of 14 Old 10-30-2019, 04:28 PM
This is what's needed to help out KarlJay.
Someone else that has done it, got it right, and remembers.
And even has some pictures.
post #10 of 14 Old 10-30-2019, 04:40 PM Thread Starter
I'm not sure if I kept the old disks or not, I wonder what the difference is and if they are marked like that.
It was early this year and that's after they sat for a while so I don't remember if they were marked the same way.
Do you happen do know what the difference is? One was very clearly a different size, IIRC, it was bigger on the inside so that "meat" part was smaller than the rest.
post #11 of 14 Old 11-07-2019, 01:17 AM
This might help. Similar clutch.
https://youtu.be/1ke6zyhk0EE
post #12 of 14 Old 11-07-2019, 09:59 AM Thread Starter
Ok, now I get it. There's a 2nd set of slots and the last disk goes in the 2nd set of slots. Now I know what to look for. Two things, 1. A different disk 2. set into a different set of slots.
I'm going to open it up and check.
post #13 of 14 Old 11-07-2019, 11:22 AM
Personally, I would only every disassemble the clutch spring bolt set the way he reinstalled them, instead of zipping each one out in a single fast go.
Too easy to snap off a (bolt receiving) tower.
I distinctly recollect that Pvester stripped a tower bolt hole on his, but I don't know if that was at reassembly or disassembly.
badmoon692008 likes this.
post #14 of 14 Old 11-07-2019, 09:58 PM Thread Starter
That's strange that he did it that way. Anytime you have a shared load, you always want to go in stages.
