How do you remove handlebar anti-vibration inserts? - Wrist Twisters
post #1 of 6 Old 08-16-2012, 06:16 AM Thread Starter
I got some bar end mirrors for my 919 and took off the bar-end weights to install them. However, I can't figure out how to remove the stock bar inserts. It's probably really simple and I'm just not getting it. Can anyone tell me how to remove the the inserts?
Thanks.
Holden is offline
post #2 of 6 Old 08-16-2012, 07:31 AM
Look for the small hole near the end of the handle bar.
A small spring steel tang that is attached to the inner core registers there.
Take off the bar end.
Remove the screw.
Thread the screw into the inner, without the bar end weight.
Grab the screw, depress the tang with a small screwdriver or drift, and pull out the core.
post #3 of 6 Old 08-16-2012, 07:33 AM
Look for the small hole near the end of the handle bar.r
Remove the screw.
The tang will be under the grips.
marylandmike is online now
post #4 of 6 Old 08-16-2012, 07:54 AM
Yes, I forgot about that.
12 mm in from end face of bar and vertically up.
Also, I erred by saying just use the screw.
Leave on the bar weight but make sure the screw is loose so no compression is occuring.
The bar weight is easier to pull on.
Should be an easy extract.
Old bars could be a bit rusted inside.
If so, some WD40 will help.
post #5 of 6 Old 08-16-2012, 08:38 AM
Thanks.
Another option if you're interested: Take a lathe to the bar end weights and cut the middle section down to the size needed in order to mount the bar end mirrors on the weights themselves. This allows you to keep all the bar weights and it looks factory.
Check out this thread for pictures: https://www.wristtwisters.com/forums/...out-29477.html
post #6 of 6 Old 08-16-2012, 11:30 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Remove the bar ends. Reinsert the bolt with some large diameter washers against the end of the handlebar and just turn the bolt until the insert backs out. This was the approach when I added my Throttlemeister. No need to remove the grips.
Doc
ST-DocLizard1 is offline
