how do you push start a 919? - Wrist Twisters
post #1 of 7 Old 06-24-2016, 08:50 PM Thread Starter
Came out from the store today sat on the bike while it was on but not running, I put on the helmet and gloves. When I went to hit the starter, it just buzzed.
I'm sure the headlight and fan were running, but didn't think it would matter much.
I tried about 10 times to push start:
1st gear, duck walk with ign on, release clutch... engine moved but didn't start.
tried 2nd gear, still nothing.
I don't know if I wasn't "duck walking" it fast enough or if the system needs a certain amount of amps/volts to start.
post #2 of 7 Old 06-24-2016, 09:40 PM
when my battery croaked a few weeks ago I just put it in second, grabbed the clutch got a run at it, hopped on and popped the clutch, fired right up.
You did have the key on? Right?
post #3 of 7 Old 06-24-2016, 10:05 PM
You gotta get a decent speed going, cant duck walk it, more like duck run it. Go at least 2 miles an hour, pop the clutch while thumbing the starter at the same time. It should fire right up. 2nd gear tends to work best.
post #4 of 7 Old 06-25-2016, 05:42 AM Thread Starter
Ok, so I just didn't have enough speed. Good to know. If I had a bit of a slope, it probably would have worked.
Anyone ever heard of using a drill battery to jump start a bike? Seems like one could be stored in a tank bag just in case.
post #5 of 7 Old 06-25-2016, 06:15 AM
Same thing for me, same method, fired up real nice and easy first time.
(challenging is a Norton Commando on straight 50 oil on a cold night on cold engine if you don't get it to start the first try)
I hadn't had to do it for many years, which reminds me, the term I was taught eons ago was "run and bump".
Duck walking won't do it, that's for sure.
Meanwhile, for cars it was "push start".
post #6 of 7 Old 06-25-2016, 07:54 AM
NealC's Avatar
It has electronic fuel injection, so yes, it needs a certain amount of "juice" to operate the fuel pump and injectors.
Even when you are able to "bump", or jump start it, be careful pulling into traffic until you have a decent charge on the battery. A need for WOT drives the injectors to 100% duty cycle. If there is not enough "juice" it will fall on its face.
BTDT, almost got run over.
NealC is offline
post #7 of 7 Old 06-25-2016, 11:23 AM
nathanktm's Avatar
Last time I had to bump start it, I had to bring it to a full out sprint, then jump on it and have my butt smack down on the seat just as I released the clutch for some extra weight on that rear wheel. I had a completely dead battery and it was like, 8 F outside. Give it some gas too, cuz the my idle was so low that it nearly died out again.
nathanktm is offline
