How do i fix front fender on 919 - Wrist Twisters
post #1 of 8 Old 04-09-2017, 06:45 PM Thread Starter
IHellsent's Avatar
How can i fix this crack on my front fender. I don't care if it looks pretty i just don't want it to break20170409_181654.jpg
Sent from my LGMS428 using Tapatalk
Just ride!
2006 Honda 919 (my baby)
1990 GS500 (POS first bike)
2015 Honda Grom (City destroyer)
IHellsent is offline
post #2 of 8 Old 04-09-2017, 07:06 PM
nathanktm's Avatar
Scotch tape. Lots of it
nathanktm is offline
post #3 of 8 Old 04-09-2017, 07:09 PM Thread Starter
IHellsent's Avatar
lol i was thinking gorilla glue or super glue.
Just ride!
post #4 of 8 Old 04-09-2017, 07:26 PM
should be able to put a few drops of super glue in there. Hold it for a min and should be done.
post #5 of 8 Old 04-09-2017, 10:13 PM
Get it plastic welded.
post #6 of 8 Old 04-10-2017, 05:28 AM
I'd fibreglass it. Get a auto body repair kit. Mostly resin mix and glass matting. Some body filler. Bit of paint it would look like new.
post #7 of 8 Old 04-16-2017, 07:24 PM
JPhilB's Avatar
Use this. Bondo Epoxy bumper repair syringe kit 280 - Read 1 Reviews on Bondo #280
I used it on my rear cowl and the mesh and epoxy make a great repair.
JPhilB is offline
post #8 of 8 Old 04-17-2017, 05:05 AM
In addition to actually repairing the fender it is also essential to address the reason it cracked in the first place. In this case I'm willing to bet that when you installed the stainless steel brake lines you did not reinstall the two clips that retain the original lines just above the calipers. Without those clips when the bolts were tightened down the fender was pulled further out, stressing the plastic which failed at the weakest point.
All you need to do is insert washers the same thickness as the clips then do the repair.
