Honda Hornet issue - Wrist Twisters
post #1 of 19 Old 08-13-2013, 05:58 PM Thread Starter
Honda Hornet issue
What's up everybody.
I need to pick some brains on here. I've owned my 2002 Hornet 919 for almost a year. Always got right around 40 mpg on it until a couple months ago.
Long story short, I got some diagnostic work done after my MPG's went down about 20 percent out of no where and I had some low end (up to about 1,500 RPM) bogginess. It was concluded that my injectors were dirty and that my fuel pressure regulator was compromised.
The injectors were cleaned, I replaced my old air filter with a new K&N and replaced my fuel pressure regulator too. The bogginess is gone and the girl moves smooth and fast once again. But my MPG's are still down around 34 from about 40.
Anyone have pointers or other things to look into that would be causing the dip in MPG's? I read somewhere on this forum recently about a PC III board or something like that that could make the air-fuel ratio less rich. Is that something I should look into?
Any help would be greatly appreciated.
Looking forward to interacting with some like-minded peeps on here.
Thanks.
Ryan
RyPThomas is offline
post #2 of 19 Old 08-13-2013, 06:05 PM
Remove the K&N, put stock filter back on.
CB700S is online now
post #3 of 19 Old 08-13-2013, 06:21 PM
Welcome to WT!
Some people don't like K&N's, but your problem started with the stock filter and I doubt that is a factor at all.
I'm sure others will have some suggestions to try. The PC3 idea would only (possibly) mask whatever problem you are having. You'd be treating the symptom and not the cause.
Ottawa919 is offline
post #4 of 19 Old 08-13-2013, 06:25 PM
I'm saying 'put the stock filter back on' so he's back to baseline - he had many things done to the bike, so we need to eliminate as many variables as possible. Also old clogged stock filter is not equal to new stock filter.
post #5 of 19 Old 08-13-2013, 06:33 PM Thread Starter
Just went out to do a quick look-see and listen to something I noticed after replacing the FPR. A squealing-like sound when I turn the key. I'm not an expert but it sounds like it's coming from inside the tank and therefore the fuel pump (I hope not but that's my fear).
post #6 of 19 Old 08-13-2013, 06:44 PM
Fuel pump is supposed to whir for 2-3 seconds when you set the key to on and flip the kill switch to run.
post #7 of 19 Old 08-13-2013, 06:48 PM Thread Starter
It "whirs" but the pitch of the whir sound changed abruptly once I changed out the FPR. Got me concerned.
post #8 of 19 Old 08-13-2013, 07:47 PM
How many miles are on it?
post #9 of 19 Old 08-14-2013, 05:03 AM Thread Starter
42,000. I bought with 28K on it.
post #10 of 19 Old 08-14-2013, 05:38 AM
Tool & Die
morrow919's Avatar
I don't know how good an idea it is, but maybe you could run some fuel system cleaner through it. I like the Seafoam brand my self. I've used it on my cars, trucks, lawn equipment, and motorcycles. And +1 on removing the K&N. The oils from the filter can sometime get sucked into the intake and cause odd issues. Kept fowling out my mass air sensor on my truck.
'07 Hornet - Candy Glory Red
morrow919 is offline
post #11 of 19 Old 08-15-2013, 06:00 AM
Squealing noise after changing the FPR? Someone else here also had that problem when they forgot to remove the rubber cap on the bottom of the FPR before installing it in. Check that.
2012 Yamaha Super Tenere
2001 Honda Blackbird
post #12 of 19 Old 08-15-2013, 08:59 AM
Canadian Blue
Mark919's Avatar
This is a great suggestion! +1
The black rubber plug covers the o-ring and opening.
Mark919 is offline
post #13 of 19 Old 08-15-2013, 10:13 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Here is the thread..................read it all the way through:
https://www.wristtwisters.com/forums/...tml#post532252
ST-DocLizard1 is offline
post #14 of 19 Old 01-10-2014, 09:19 PM Thread Starter
DocLizard,
Just read through the entire thread (after five months lol) you posted and the sound is the exact same as what I'm suffering from. Sounds like I need to replace my FPR (again) and make sure it is completely ready to install before I do so.
I've been riding less recently due to work, but I have more time to do so now so I'll be working on getting my MPG's back up to where they were before.
Once I replace the FPR and have the miles to check the MPGs I'll report back.
post #15 of 19 Old 01-11-2014, 12:56 PM
Again. That sucks. After how many miles?
Im at 7k miles and I bought one to have for when the fpr fails
post #16 of 19 Old 01-11-2014, 01:34 PM Thread Starter
I think I need to pull off my FPR and see if that 'seal' is blocking fuel return like it was in the thread that is linked to above. That seems to be what caused the fuel pump squeal in the other thread. I'm hoping to get this done tomorrow.
post #17 of 19 Old 01-21-2014, 03:25 PM Thread Starter
Great news on this front! I found some time yesterday (Thanks, MLKjr!) to pull off my FPR and lo and behold, that rubber cap was sitting there cramping my fuel's style. I took it off, put everything back together and two takeaways: 1: the 'squeal' of the fuel pump is gone and 2: after a ride to the office and back today, my fuel mileage is back to where it was before my original FPR kicked the bucket. I rode 163 miles before the fuel indicator light came on!! So pumped, and so happy you were all able to lend a hand on this, especially you Doc Lizard!
Much thanks again and I'll be around here more often to chime in when I can.
-Ryan
post #18 of 19 Old 01-21-2014, 03:54 PM
Ginger-prick
EatDirtFartDust's Avatar
Here in the midwest, gas stations switch their blend of fuel, and it is very common for people to lose mpg's on any type of vehicle during winter time.
2007 Honda 919.
EatDirtFartDust is offline
post #19 of 19 Old 01-21-2014, 03:54 PM
Excellent. Glad you got it sorted. Amazing the amount of 919 knowledge here. Don't be a stranger.
