High current remote switching - Wrist Twisters
post #1 of 19 Old 10-01-2012, 10:56 AM Thread Starter
Recently, I saw a product which uses four grip switches and a switching module intended to replace the standard left side switches. A good idea, but IMO the switches would be prone to inadvertant operation, and with the switch housing gone there is a long stretch of bare handlebar showing between the grip and the clutch lever perch. My design addresses these problems using sealed pushbuttons in a much smaller housing than stock.
First, the button: about ten years ago a diver had a non pressure compensated housing for a digital camera, but was having difficulty keeping the housing sealed around the shutter switch. He was grousing about it when I suggested a 6mm tactile switch shoved inside a brake bleeder cap and sealed with industrial thermal adhesive, then epoxied to the housing. When I got it rigged he tested it to 250 feet and it did not leak at all. For the math challenged that's just under 125 PSI in salt water. 10 years later it is still in service and has no problems.
Fast forward to now and that is the same principle I used for the switch, in this case intended to be mounted to the front of the stock left switch housing and pushed by the index finger. I also updated the rubber cap to one I accidentally found online that fits the tactile switch much better. Frankly I forget what the cap was originally for, but as long as I have a source I'll continue to use them.
Next the switch housing: I want to control the headlight high / low (one button), turn signal left / right (two buttons), and horn (one) with the button locations more ergonomic than the conventional setup. The question is how to make it? The answer came when my granddaughter was visiting, and we went to a craft store for whatever she wanted, and right in front of me was the solution -- Fimo oven fired clay. Layering and carving it on a scrap piece of 7/8ths tubing over a very intermittent week resulted in this:
The second image is taken from what will be underneath the bar, and both of the turn signal buttons and horn button are activated by the thumb, while the dimmer is at the front and selected with the index finger, thus:
The positioning is preliminary, but close to what I think will work.
The switching module: I'm keeping specifics of the nature of the circuit under my hat for the moment, at least until the provisional patent process is underway. Suffice it to say the circuit design is finalized, parts are spec’d out, and board designed.
As to function:
-- The headlight dimmer is a toggle type which one push of the button will toggle between low and high beams.
-- The turn signal buttons individually toggle that side on or off, and a push of the other side switch will cancel the one side and activate the other. So far no hazard switch implemented, but if the demand is there ...
-- The horn button is a simple relatively direct driver for the transistor, no fancy electronics involved. It has sufficient capacity to drive two horns directly, or can pick up a relay for air horns.
All switching is done by P channel MOSFET transistors with an Rds (on resistance) of 0.01 ohm, meaning there is little heat generated in operation. Thus far I can reliably switch as much as 250 watts resistive per function, and 200 watts inductive with the necessary bypass diode across the motor. Of course the current capacity can be adjusted up or down to suit applications by using different transistors.
Using surface mount components the total size of the module will be 20mm x 55mm x 8mm, exceptionally small for the current being switched, and will be fully encapsulated for environmental protection.
If I can source the connectors for the stock 919 left side switch assembly I could make it plug and play, but it would not be a problem to hard wire it in, just more time consuming.
I'll let you know when initial field testing of a prototype unit is underway.
post #2 of 19 Old 10-01-2012, 03:16 PM
You have been watching too much of this guy.
Turbo Encabulator - YouTube
post #3 of 19 Old 10-01-2012, 03:21 PM
What just happened?
post #4 of 19 Old 10-01-2012, 03:25 PM
I like craft stores.....
post #5 of 19 Old 10-01-2012, 04:28 PM
Total Awards: 17
how high is its current rating? I have an appliance with power rating of 1.21 jigawatts, flux capacitor.
zaq123 is offline
post #6 of 19 Old 10-01-2012, 04:34 PM
so wait... one button does it all??
post #7 of 19 Old 10-01-2012, 04:41 PM
undercover919's Avatar
no looks like he has a few buttons, on the left side would be a turn signal, horn, and hi/lo..
not sure if he plans on replacing the right side as well, but what I think he would need is a starter, possibly a momentary kill switch/whatever (like on dirt bikes) and turn signal
Am I right?
2003 Honda 919
undercover919 is offline
post #8 of 19 Old 10-01-2012, 05:04 PM
Looks like a sleek little unit Rob. What would cause someone to replace their stocker?
post #9 of 19 Old 10-01-2012, 05:40 PM
Any chance a "pass" button could be added? My friend's 2011 Speed Triple has a dedicated lever-button for just that and I was surprised they weren't more commonplace on motorcycles.
jscott is offline
post #10 of 19 Old 10-01-2012, 06:32 PM Thread Starter
Close. Both turn signal buttons are on the left side, but it would not be difficult to place the right button on the right side.
Am I right?
Actually, there are several Yamahas with a small separate switch pod on the right for start / kill that would nicely fill the bill.
Much of my handlebar business is from custom builders, and there is definitely a market there, so I am looking into it with this.
Look up Grip Ace for another unit.
The dimmer button can be used for flash-to-pass. It's very easy to get to even with the clutch pulled in. Essentially it does not require the rider to release the grip even a little, unlike conventional switches.
post #11 of 19 Old 10-01-2012, 06:43 PM
Is it bad that I understood Rob's first post? Lol I feel geeky...
Rob that's awesome. I'd be very interested in a unit. If you want sometime to test the unit under hard conditions (cold, wet, daily operations, etc) I'd be more than happy to help lol. I would also be interested in a right side unit as well, provided it doesn't radically change the operation of the throttle tube and 2-way cable system. Keep us posted!
Pvster is online now
post #12 of 19 Old 10-01-2012, 09:24 PM
thats a sweet lil setup! makes sense now!
post #13 of 19 Old 02-07-2013, 03:13 AM
CB900
rockdog32's Avatar
Very Nice!
rockdog32 is offline
post #14 of 19 Old 02-07-2013, 03:48 AM
Tool & Die
morrow919's Avatar
Rob that's awesome. I'd be very interested in a unit. If you want sometime to test the unit under hard conditions...
If your bike sitting on a lift is considered hard conditions, then I'm terrible to my ride.
morrow919 is offline
post #15 of 19 Old 02-07-2013, 03:51 AM
Tool & Die
morrow919's Avatar
"panametric fam...hydroscoptic mozel veins...lunar wayne shaft to prevent side fumbling"
Sounds like these parts belong on the shelf next to the muffler bearings.
post #16 of 19 Old 02-07-2013, 09:02 AM
bpolunin's Avatar
Would be interesting to see how much this little unit would run...
2007 Yamaha VStar Classic
2005 Suzuki SV650 - traded
2003 Honda 919 - traded
2008 Aprilia Tuono 1000R - Sold
2008 Aprilia RSV1000R Track Only
2007 Honda CBR600RR - sold
2005 Honda CBR600F4i
bpolunin is offline
post #17 of 19 Old 02-10-2013, 04:39 PM
250W / 12V = 20.8A
250W / 14V = 17.9A
cychotic is offline
post #18 of 19 Old 02-10-2013, 09:38 PM
Detale's Avatar
I think it's a brilliant idea executed wonderfully. Is the clay going to be the permanent housing or will you be using it as a mold for a plastic setup. You can get resin kits pretty cheaply if you wanted to try your hand at it. If these were on the market I'd look into buying one. Not for my 919 but for some custom stuff I get into now and again.
Great work! Please keep us updated.
Detale is offline
post #19 of 19 Old 02-10-2013, 09:44 PM
+1 Rob, any updates??
