HELP Please!! - Wrist Twisters
post #1 of 42 Old 10-03-2012, 06:33 PM Thread Starter
holeysocks's Avatar
HELP Please!!
Hello to the fourm:
I just bought a 2005 919 and I am having some problems concerning the swing arm, rear tire and rear brake, not being installed right.
The rear axle was messed up and I ordered a new one with both spacers.
looking at the service manual(page14-0) there is a flanged spacer on the sprocket side and a smaller spacer on the brake side, however, if I try to use both spacers things are out of alignment. Looking at a video (Something Just Didn't Feel Right) this bike doesen't appear to have a spacer between the wheel bearing and the caliper mount
Am I looking at this wrong ??? does anyone have pictures??
Please Help!! new to me motorcycle and I would really like to ride it for the 1st time
David
holeysocks is offline
post #2 of 42 Old 10-03-2012, 07:09 PM
Originally Posted by holeysocks View Post
Hello to the fourm:
David
Do you have the spacers installed like these pics? That's my bike in that thread and it has both spacers. The right hand spacer just fits down into the wheel bearing cavity.
post #3 of 42 Old 10-03-2012, 07:21 PM Thread Starter
holeysocks's Avatar
Yes I think they were just like that. I will have to look more tomorrow.
Thank You
post #4 of 42 Old 10-03-2012, 08:31 PM Thread Starter
holeysocks's Avatar
I went out and looked and I had installed the spacers just like you show,
post #5 of 42 Old 10-03-2012, 08:34 PM Thread Starter
holeysocks's Avatar
one thing,,in the right side picture, the flange of the spacer appears to almost rest on the oil seal?? maybe a very small gap,,is that right?
post #6 of 42 Old 10-03-2012, 09:00 PM
Looks right to me.
post #7 of 42 Old 10-03-2012, 09:10 PM Thread Starter
holeysocks's Avatar
I think the problem is the bearings are to thick,, on the left side I have almost all of the spacer showing and it looks like you only have about a 1/8" to 3/16" showing
Rear wheel and brake where installed wrong and the azle was held in by a peice of coat hanger,,so I am not sure what I have to work with I am not sure they are the right ones for the bike
Thanks Again for your Help
post #8 of 42 Old 10-03-2012, 09:39 PM
Can you take and post pictures so we can see what you have to work with?
post #9 of 42 Old 10-03-2012, 10:04 PM
sometimes those spacers are hard to get in the seals. make sure both surfaces (inner of the seal and outter of the spacer) are clean... then apply some grease to either of the surfaces, and push in.
post #10 of 42 Old 10-04-2012, 01:16 AM
TWSS
post #11 of 42 Old 10-04-2012, 04:23 AM Thread Starter
holeysocks's Avatar
I will post pictures this afternoon, also I do not think there are any seals maybe pictures will help
post #12 of 42 Old 10-04-2012, 04:26 AM
TWSS
post #13 of 42 Old 10-04-2012, 04:33 AM
I was gonna say if the dust seals are flush, then the bearings should be the right thickness, but if you don't have to seals maybe the PO installed the wrong size bearings or maybe they weren't pressed all the way in.
Pics may help.
post #14 of 42 Old 10-04-2012, 04:48 PM Thread Starter
holeysocks's Avatar
post #15 of 42 Old 10-04-2012, 04:49 PM Thread Starter
holeysocks's Avatar
post #16 of 42 Old 10-04-2012, 04:49 PM Thread Starter
holeysocks's Avatar
post #17 of 42 Old 10-04-2012, 04:53 PM Thread Starter
holeysocks's Avatar
post #18 of 42 Old 10-04-2012, 04:54 PM Thread Starter
holeysocks's Avatar
post #19 of 42 Old 10-04-2012, 04:55 PM Thread Starter
holeysocks's Avatar
post #20 of 42 Old 10-04-2012, 04:56 PM Thread Starter
holeysocks's Avatar
post #21 of 42 Old 10-04-2012, 04:57 PM Thread Starter
holeysocks's Avatar
ok that's what I have..help please
post #22 of 42 Old 10-04-2012, 05:02 PM
Somebody that didn't know what they were doing put those bearings in. The one on the brake side isn't driven in all the way and has no dust seal. See attached pic. This is after I drove in a new bearing before the dust seal went in. Also the bearing in the driven flange should also be a sealed bearing. It's missing the seal at least on one side. I would get those bearings replaced if it were me. The one on the sprocket side of the wheel looks OK.
post #23 of 42 Old 10-04-2012, 05:32 PM Thread Starter
holeysocks's Avatar
I FOUND IT!!!!! Mike, Thank You and when you said they did not know waht they were doing!! you were right the O.P. had put the dust cover 1st and the bearing on top of it,,so the bearing would not go in the thickness of the seal
Where can I find the bearings and seals..I see kits for the wheel bearingsand seals,, but what about the bearing and seal in the driven flange?
post #24 of 42 Old 10-04-2012, 05:44 PM
Here's a couple of links with all three bearings and seals. I got the All Balls set, but a lot of folks here have recommended the Japanese set
Premium Rear Wheel Bearings and Seals Kit Honda CB900F (919) 2002-2007 Japanese
25-1257 All Balls Racing
post #25 of 42 Old 10-04-2012, 05:49 PM
The kits come with all three bearings and the appropriate seals.
Premium Rear Wheel Bearings and Seals Kit Honda CB900F (919) 2002-2007 Japanese | eBay
Edit: Mike, the All Balls will work according to all reports. Thing is, I've had the kind of Chinese bearings that All Balls uses disintegrate at inopportune moments and I wouldn't use them in any high speed application on anything I own if I had a choice. Peace of mind is more important.
Koyo is Japanese and one of Honda's OEM suppliers.
post #26 of 42 Old 10-04-2012, 05:49 PM Thread Starter
holeysocks's Avatar
Thanks Again
post #27 of 42 Old 10-04-2012, 05:51 PM Thread Starter
holeysocks's Avatar
CB700S you are about 150 miles from me! my youngest daughter lives in Mansfield
post #28 of 42 Old 10-04-2012, 05:52 PM
Thanks Again
You're welcome and glad you got it figured out.
post #29 of 42 Old 10-04-2012, 05:59 PM
Yup, this is why pictures are a must when asking people to help diagnose stuff.
post #30 of 42 Old 10-04-2012, 06:03 PM Thread Starter
holeysocks's Avatar
Thanks again guys..bearing kit has been ordered, I might be able to go on my 1st ride on Tuesday!!!!
post #31 of 42 Old 10-04-2012, 06:06 PM
It looks like dude may have actually been riding it that way for a while. Check the caliper bracket for damage and thoroughly check the thickness of the rear disc while you're at it.
Edit: The more I look at that rear disc, the less I like the look of it. You should consider just flat out replacing it.
post #32 of 42 Old 10-04-2012, 06:10 PM
Edit: The more I look at that rear disc, the less I like the look at it. You should consider just flat out replacing it.
+1 That rotor doesn't look so good.
post #33 of 42 Old 10-04-2012, 06:11 PM Thread Starter
holeysocks's Avatar
caliper bracket is a bit banged up,, and I will get one when I can..I will check on a used disc..Thanks
post #34 of 42 Old 10-04-2012, 06:36 PM
post #35 of 42 Old 10-05-2012, 04:18 AM
Thanks CB. I didn't know about this other source when I replaced mine. I have this Japanese source bookmarked for next time.
post #36 of 42 Old 10-05-2012, 10:12 AM Thread Starter
holeysocks's Avatar
post #37 of 42 Old 10-08-2012, 07:18 PM Thread Starter
holeysocks's Avatar
Bearings will be here tomorrow,,Caliper mount around Friday, with the rain
post #38 of 42 Old 10-09-2012, 06:32 PM Thread Starter
holeysocks's Avatar
Rode it today!!!!!
post #39 of 42 Old 10-10-2012, 10:03 PM
I'm going to guess the wheel didn't fall off?
Also, do work on replacing that rotor, it's really important.
post #40 of 42 Old 10-11-2012, 04:30 AM Thread Starter
holeysocks's Avatar
Nope it did not fall off!! I cleand the rotor with a scotch brite pad ans air grinder and it look much better!! but I will keep my eye open for a replacement
