help: intermittent horn - Wrist Twisters
post #1 of 5 Old 07-08-2012, 04:13 PM Thread Starter
I'm troubleshooting my horn, the switch doesn't seem to have issues but after opening the housing the horn works intermittently. Sprayed it down with wd40 to try to clean the contacts, inspected the cables to the switch (within the housing) all seems well.
I tried another horn, same issue. Anywhere else I should be looking at and how do I fully removed the parts from the housing? I got to this, don't wanna break anything trying to get it out.
post #2 of 5 Old 07-08-2012, 04:33 PM
Hastatus Prior
TheBeeDeeGee's Avatar
Had this problem on my 599. Check the connections at the horn. I had to replace the connectors.
Sent from my DROID RAZR using Tapatalk 2
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #3 of 5 Old 07-08-2012, 05:12 PM Thread Starter
Found the culprit, kinked wire close to the connectors at the horn. Can someone check if the cables are suppose to route around front of the frame or straight down to the horn next to it.
post #4 of 5 Old 07-08-2012, 05:23 PM
straight down the inner side of the frame.
post #5 of 5 Old 07-08-2012, 06:03 PM Thread Starter
Thanks!
