Help identifying fork part... - Wrist Twisters
post #1 of 10 Old 11-01-2015, 07:17 AM Thread Starter
Mazaev's Avatar
So I was having some issues with the forks clicking and not rebounding well, and it was way overdue for a refresh anyway, so I went and got some new springs and seals.
When the forks were removed there was this broken spring guide type thing in there that I can't find on any fiche. They were previously worked on at Traxxion, but I was told they only changed the springs.
Anyway, could someone tell me what this black piece is?
File Type: jpg 12197510_10206849586773736_1461492762_o.jpg (140.6 KB, 35 views)
File Type: jpg 12190339_10206849634094919_982260690_o.jpg (96.9 KB, 34 views)
File Type: jpg 12204134_10206849742897639_1184004219_o.jpg (238.4 KB, 22 views)
Mazaev is offline
post #2 of 10 Old 11-01-2015, 08:04 AM
It's a guide to centralize the springs on true centre to reduce spring bowing on bump.
That was the spring rubs less on tube inner and reduces the amount of super fine rubbings that contaminate the oil.
post #3 of 10 Old 11-01-2015, 08:18 AM Thread Starter
Mazaev's Avatar
Right.. but are they required? And more importantly, what do they come with, since they aren't in the fiche, nor seem to be sold separately at either Traxxion or Race-Tech (where the new springs are from).
Mazaev is offline
post #4 of 10 Old 11-01-2015, 09:16 AM
They are not absolutely needed.
There are not an OEM build component
I'm not aware of Racetech having them
Traxxion sells them as stand alone but it is not apparent from the website
post #5 of 10 Old 11-01-2015, 09:22 AM
Wow. I think I'd rather have the springs rub a little than have plastic chunks floating around inside my forks. Agree with McRomo; don't worry about replacing them, just leave them out.
post #6 of 10 Old 11-01-2015, 11:20 AM
A buffer kit remains a valid addition for front ends with no spring centralization feature aside from tube inner diameter.
(Traxxion calls then buffer kits when one is looking at a set of them for one front end)
post #7 of 10 Old 11-02-2015, 01:41 PM
Had the exact same issue on my forks. Went ahead and junked them. Currently running without any issues.
post #8 of 10 Old 11-02-2015, 03:18 PM
Total Awards: 17
A lot of fork manufacturer's use those nowadays just for reasons mcromo described, with no such issues. Don't believe Honda had these stock in 9er forks. If they were indeed traxxion units, I would be sending these pics to them.
How long is it? is it longer than fully compressed spring? (spring wire diameter x number of coils)
zaq123 is offline
post #9 of 10 Old 01-09-2016, 07:15 AM Thread Starter
Mazaev's Avatar
Err... forgot to update this. I ended up calling traxxion, who said that the plastic pieces were specific to a line of their springs are were not otherwise needed.
Have had the racetech springs in there since and been super happy with the handling improvement.
Sent from my Nexus 6 using Tapatalk
Mazaev is offline
post #10 of 10 Old 01-09-2016, 11:41 AM
They have a thick collar that goes between the spring & preload spacer so there would be a difference between running them vs. not running them as far as effective preload spacer length is concerned when using Traxxion springs.
Too late now since you switched to Racetech but...
http://www.traxxion.com/Omni-Fork-Sp...ffer-Kit-11mm/
919 is the 11mm.
Bryce919er is offline
