Heated grip pad question - Wrist Twisters
post #1 of 18 Old 10-21-2012, 02:09 PM Thread Starter
redline919's Avatar
I bought some of those heated grip pads from Fleebay and only one side gets really hot. It is because the clutch side grip is a thicker rubber to compensate for not having a throttle sleeve. My question is does anyone have any ideas on grips that are possibly thinner? Maybe buy a set for smaller bars? Drilling holes or perforated grips would invite rain so I need ideas please other than throwing them away lol
redline919 is offline
post #2 of 18 Old 10-21-2012, 02:56 PM
StormSurfer
Whiplash97's Avatar
Buy another set, splice throttle side from new set on to clutch side of existing set and presto warm hands
:buell:
Whiplash97 is offline
post #3 of 18 Old 10-21-2012, 03:08 PM Thread Starter
redline919's Avatar
They are both the same my grip is too thick for the heat to make it through
post #4 of 18 Old 10-21-2012, 03:12 PM
StormSurfer
Whiplash97's Avatar
Oh...
:buell:
post #5 of 18 Old 10-21-2012, 03:14 PM Thread Starter
redline919's Avatar
They are the ones that go under your own grips the throttle side is toasty
post #6 of 18 Old 10-21-2012, 03:32 PM
StormSurfer
Whiplash97's Avatar
wouldn't that heat up the whole bar?....can you just change your grip out with a thinner one? Or take it off wrap the heater with electrical tape to keep out dirt/water then punch a few holes in the grip? Do you have hand guards? That might break the wind so it can heat up more?....I'm running out of ideas
Do they look anything like these?
If yes, can you wrap them over your grips then shrink wrap/tape to seal?
I'm really trying here, I need some myself, Brrrrrrr!
:buell:
post #7 of 18 Old 10-21-2012, 04:27 PM Thread Starter
redline919's Avatar
They are similar yes but a they are shipped from the US. I just went on a test ride and I had to turn them on low after riding for 10 mins or so. The throttle side definitely gets a lil hotter but I still felt the clutch side I just want them even. I think they would get too hot on the outside of the grips. Your idea about holes and tape would probably b best (TWSS)
post #8 of 18 Old 10-21-2012, 04:32 PM Thread Starter
redline919's Avatar
I have it powered like this just went to radio shack and an auto parts store about 30$ to do http://www.canyonchasers.net/shop/generic/relay.php
post #9 of 18 Old 10-21-2012, 04:44 PM Thread Starter
redline919's Avatar
I bought these the only thing is that hi is low and low is high according to the switchplate lol http://pages.ebay.com/motors/link/?n...d=360495283782
post #10 of 18 Old 10-21-2012, 06:11 PM
Di"zx"en
97af's Avatar
With both wraps being equal in current draw, the wrap that is directly in contact with the steel or aluminum bar is transfering most of its heat output to the bars instead of the grip. The wrap that is around the plastic throttle tube isnt transfering heat into the bars but only to the grip.... Which means a warmer throttle side grip because its not heating as much material IE: the bars too. I'm betting a few wraps of electrical tape on the bar (clutch side) before you wrap the heating element to it would greatly reduce the heat transfer to the bars and instaed to your grip...Just "swag" scientific wild a _ _ guess but worth a shot...
That'll work........
97af is offline
post #11 of 18 Old 10-21-2012, 06:22 PM Thread Starter
redline919's Avatar
That makes sense I will try that thanks
post #12 of 18 Old 10-21-2012, 08:08 PM
HornetMan's Avatar
Instead of electrical tape use heat shrink tubing. Heat will make a mess of the electrical tape adhesive.
"Keep on 9-in"
HornetMan is offline
post #13 of 18 Old 10-21-2012, 08:25 PM
Di"zx"en
97af's Avatar
Way better idea than mine.......
97af is offline
post #14 of 18 Old 10-21-2012, 10:57 PM
StormSurfer
Whiplash97's Avatar
Wow! You guys are good!
:buell:
post #15 of 18 Old 10-21-2012, 11:02 PM
Nah, just keeping gixmix out of the equation helps a lot
post #16 of 18 Old 10-21-2012, 11:24 PM
StormSurfer
Whiplash97's Avatar
:buell:
post #17 of 18 Old 10-22-2012, 08:26 AM
Di"zx"en
97af's Avatar
Another option would be to pick up a real set of heated grips....I've had a few sets of heated grips over the years.....Oxfords woulds be the ones to go with.
97af is offline
post #18 of 18 Old 10-22-2012, 01:55 PM Thread Starter
redline919's Avatar
I said I'm not throwing them away, lol. They really do work good so I am please with the results. Plus they are cheaper
