Headlight dead after lifting tank - Wrist Twisters
post #1 of 3 Old 09-19-2015, 08:22 AM Thread Starter
I lifted the tank to change out the spark plugs and now my headlight is dead. I know that the starter switch is a common solution to this problem, but I'm almost certain that's not it because the light was working before I changed plugs with no problems.
The highbeam light indicator stays on regardless of whether I switch from high to low beam. I tore into the headlight and the bulb is good, as is the connector. I checked connections under the tank and all seem fine; fuses are good too. Is there perhaps something else under the tank that I could have undone?
Power is also getting to the H4 connector.
fritzwilliam is offline
post #2 of 3 Old 09-19-2015, 08:28 AM
If the high beam indicator still works, it's either the bulb is burnt or the connection in the starter switch.
post #3 of 3 Old 09-19-2015, 11:27 AM Thread Starter
Went with the easiest fix first and changed the bulb. The one taken out must have had a micro fracture in it because it definitely looked good. The bulb change cleared the issue. Thanks.
