Head light out, fuses OK. - Wrist Twisters
 1Likes
  • 1 Post By maxlast
post #1 of 5 Old 09-25-2017, 05:12 PM Thread Starter
Not A Mechanic
maxlast's Avatar
Hello fellow 919 owners! (it's my first post on this forum).
I come looking for help because I have a problem that's bugging me.
The other day I was installing a new horn so cagers could actually hear me, and I must have done something wrong because my head light went out...
But I am not sure if it was related since I don't know exactly when it went out (whether it happened when I was working on the bike, or if it was right after).
Anyway, it could be a wire that I pulled, a short circuit that burnt something, a fuse...
I've been looking at this diagram to try to figure this out: http://www.cb750c.com/publicdocs/CB9..._Schematic.jpg
So far, here is what I checked:
Battery: OK
Main 30 Amp fuse: OK
Head Light / Back lights 10 Amp fuses: OK ((( BUT, no juice seems to be flowing through the Head Light fuse (it's under the seat right?) )))
Light bulb: OK
Headlight switch: OK
Starter switch: not tested yet.
I stopped there because I couldn't find the cable for the starter switch (unless it's black and red, not black and orange like on the diagram).
One good thing is that if I run a wire from the battery (+) to the blue&white wire that goes to the Headlight Dimmer Switch, my bulb lights up (and the switch works).
Some details that matters: the bike starts just fine. I have everything working (break lights, signals, speedo, horn, and so on). the headlight is the only thing not working.
Another detail: at roughly the same time the headlight went out I started hearing a noise in the front every time I hit a small bump on the road. It sounds like there's a bunch of coins in a metal box jumping around
Could it be the ignition switch?
Is there any other fuses that I missed?
I'm hoping a wizard among you will know exactly what's wrong
Cheers!
(If I have to, I'll the run a wire with a fuse from the battery straight to the headlight switch but i'd rather avoid that).
maxlast is offline
post #2 of 5 Old 09-26-2017, 04:19 AM
Normally this issue has been traced back to the starter switch and a broken solder joint. The wiring runs through there to cutout the headlight while the bike is starting.
https://www.wristtwisters.com/forums/...king-6400.html
marylandmike is online now
post #3 of 5 Old 09-26-2017, 07:24 AM
Moto-Doc
Nealio919's Avatar
Welcome to the forum...
Oh, and what he said ^^^^^
2006 Honda 919 TURBO
2014 Honda CB1000R
2005 Ducati Monster S4R
2000 Honda 750 Nighthawk -Sold
1997 Suzuki DS350SE -Sold
2002 Honda 750 Shadow ACE -Sold
2006 Kawasaki ZX-6R -Sold
2003 Honda CBR954RR (Drag Bike) -Sold
2002 Honda CBR954RR -Sold
1992 Honda 750 Nighthawk -Sold
1972 Honda CB350 -Sold
Nealio919 is offline
post #4 of 5 Old 09-30-2017, 10:07 AM Thread Starter
Not A Mechanic
maxlast's Avatar
You are a WIZARD!
I finally found the wires and tested them and it confirmed what you said, so I opened the starter switch and found the broken solder joint.
Thanks so much guys
File Type: jpg Screen Shot 2017-09-30 at 12.00.52 PM.jpg (214.7 KB, 12 views)
badmoon692008 likes this.
maxlast is offline
post #5 of 5 Old 09-30-2017, 04:55 PM
Originally Posted by maxlast View Post
You are a WIZARD!
Thanks so much guys
Excellent man. Glad you got it fixed!
