Grips: glue or safety wire? - Wrist Twisters
post #1 of 34 Old 07-28-2008, 07:01 PM Thread Starter
Trackday Recognition Veteran
I've always used safety wire for the dirt, glue and safety wire for my race Sea-Doo's. What do you guys recommend for the street/track?
Sokali is offline
post #2 of 34 Old 07-28-2008, 07:07 PM
I ride street and mx track / trails & don't use either one (for either application) - never had any problems.
...but I've never been on an enclosed road course - so I can't help you there.
omaha_919 is offline
post #3 of 34 Old 07-28-2008, 07:17 PM
I use both for all bikes.
post #4 of 34 Old 07-28-2008, 09:06 PM
Go'n So slow I'm stopped
xrmikey's Avatar
Clear coat paint. I use it for off-road(+ safety wire) & street (no wire)
It allows the grip to slip on like grease & locks the grip better than glue.
Spray some on the bar or throttle tube & some in the grip (at the opening) then slip it on & adjust as needed.
xrmikey is offline
post #5 of 34 Old 07-28-2008, 09:18 PM
I use hairspray on the street bike and used Hairspray and safety wire on my track bikes.
post #6 of 34 Old 07-28-2008, 09:25 PM Thread Starter
OK Are you guys trying to be funny or is that what you really use?
Sokali is offline
post #7 of 34 Old 07-28-2008, 09:28 PM
I really use hairspray.
If you just squirt a little on, the grip will slide on easy.
When it dries, it is sticky.
To get the grip off, just spray some Hairspray on a small screwdriver, slide it under the grip and do one revolution aroudn the bar, the grip will slide right off.
post #8 of 34 Old 07-28-2008, 09:41 PM
xrmikey's Avatar
I'm not kidding either.
Hair spray works! just not when it gets wet.
It tends to loosen a little in high humidity. At least for me, it did.
xrmikey is offline
post #9 of 34 Old 07-28-2008, 09:53 PM Thread Starter
I'll try the spray paint tomorrow; then I should be good to go for Streets of Willow this Sunday.
Next up is the Race Tech emulators and springs, after the track day.
Sokali is offline
post #10 of 34 Old 07-29-2008, 05:39 AM
Don't use the fru-fru hairspray either. Buy the cheap stuff. Rave, Aqua-net, cheapest you can find. It works like a charm.
post #11 of 34 Old 07-29-2008, 05:45 AM
No, all are real and work. I've tried all the above stated with good success. My favorite is 3M adhesive spray and compressed air. Spray the bar or throttle lightly, start the grip, insert the air nozzle, squeeze gently for light pressure and slip right on. Let stay overnight ... perfect. I haven't had a need for safety wire. To remove the grip just lift an edge of the grip, insert air nozzle, blast air and pull off.
Air is your friend ...
RC51_CBRXX is offline
post #12 of 34 Old 07-29-2008, 05:59 AM Thread Starter
Thanks for all the help. I'm looking forward to changing the grips after work; I'll figure out which method to use.
Sokali is offline
post #13 of 34 Old 07-29-2008, 08:26 AM
aka Jungle Boy
smrookie's Avatar
That's an old bmx grip install trick.
I wouldn't trust it when it comes to bigger machines though.
I just installed some new grips on my SM over the weekend. I went ahead and used "Renthal Grip Glue." Surprisingly, it worked great!
Make sure that you don't get any glue stuck between the "throttle tube & handlebar." I had to go back after the glue/grip dried and cleaned-up the glue between the tube & handlebar because the throttle wasn't returning as crisply as it should've. No big deal though. The glue comes right off like "hardened booger" from your nose.
smrookie is offline
post #14 of 34 Old 07-29-2008, 08:33 AM
Six years of track riding and I only had a grip slip once (in the rain). I came in and safety wired it. Never a problem again.
post #15 of 34 Old 07-29-2008, 09:10 AM
Paint and hairspray are both time tested methods of installing grips.
Ridge is right about the cheap hairspray, I think theres more lacquer in it than the expensive stuff.
As far as paint is concerned, I would use a clear acrylic enamel like Krylon "crystal clear". Dries fast and is water proof.
I would use safety wire.
Professional
post #16 of 34 Old 08-01-2008, 07:20 PM
Sheepdog
oldfordguy's Avatar
Its not lacquer in the hairspray that makes it work, it's poly-vinyl alcohol. I've also used it as a mold release for laying up fiberglass. It's also water soluble, that's why it may loosen up in high humidity conditions, but it also allows you to put some water under the grips if you want to remove them without damage.
When seconds count, the police are only minutes away! Support Concealed Carry & the Right to Keep and Bear Arms!
"Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other." - John Adams
oldfordguy is offline
post #17 of 34 Old 08-02-2008, 06:43 AM
aka Jungle Boy
smrookie's Avatar
As the old saying goes, "we learn something new everyday!"
smrookie is offline
post #18 of 34 Old 08-02-2008, 06:56 AM
That makes sense as lacquer isn't water soluble. I knew it had to be someting, I just didn't know what.
Thanks for the heads-up OFG.
Professional
post #19 of 34 Old 08-02-2008, 07:19 AM
Ok, here's my stupid question of the day:
How do you safety wire the grips? Does that involve drilling holes?
post #20 of 34 Old 08-02-2008, 08:01 AM
No drilling, just the wrapping of the grip with a thin (usually .032) Diameter stainless steel wire and twisting the ends tight, clipping the end to about 3/16 of an inch and then bending it over and out of the way.
You will usually do this right next to the grip flange and again at about 1 inch in from the end. Some guys will give it a wrap in the middle as well.
Professional
post #21 of 34 Old 08-02-2008, 08:10 AM
Thanks HBR!
post #22 of 34 Old 08-02-2008, 08:14 PM Thread Starter
I wrap the middle of the grip too. Some grips, like Renthal, have a groove next to the flange for safety wiring.
I used Krylon "Fusion For Plastic" spraypaint(used it for painting the flyscreen).
Fusion is the no-prep, superbond paint from Krylon.
I was planning on safety wiring also but the paint bonded good enough to hold all day at the Streets.
I'll report in a few months on how it's holding up.
Sokali is offline
post #23 of 34 Old 08-02-2008, 09:22 PM
TrackXperience Pusher!
Jayfooey's Avatar
paint and safety wire!!! FTW!!!
K7 GSX-R 750 for racing only
2006 YZ250 for getting dirty
www.TrackXperience.com
WSMC #689
Jayfooey is offline
post #24 of 34 Old 08-03-2008, 01:06 PM
9nineteen's Avatar
Donation BOTM
Simply. . .glue AND safety wire.
9nineteen is offline
post #25 of 34 Old 08-05-2008, 07:19 AM
how does the honda/xxx factory do it?
martin_nj is offline
post #26 of 34 Old 08-05-2008, 11:27 AM
SportyChick's Avatar
It's scary that you would know what hairsprays are the "fru-fru" ones!
I safety wire the track bike grips.
SportyChick is offline
post #27 of 34 Old 08-05-2008, 11:57 AM
I just looked at the assortment you left on the bathroom counter at Deal's.
Dolling yourself up for the day's ride and all....
post #28 of 34 Old 08-17-2008, 08:06 AM Thread Starter
It's been over two weeks since I changed the grips and the paint is still holding up. I might safety wire it before the next track day though.
Sokali is offline
post #29 of 34 Old 08-17-2008, 07:15 PM
what he said!
hutcho is offline
post #30 of 34 Old 08-17-2008, 07:43 PM
BrokeRecord
Has anyone ever really had a grip come off? I've never seen that happen.
brokerecord is offline
post #31 of 34 Old 08-18-2008, 06:35 AM Thread Starter
No, but I've had some that twisted around when they were glued with no safety wire.
Sokali is offline
post #32 of 34 Old 08-31-2008, 06:11 PM Thread Starter
Sokali is offline
post #33 of 34 Old 08-31-2008, 06:23 PM
Those babies arn't going anywhere!
Good job Mike.
Professional
post #34 of 34 Old 11-28-2008, 08:54 PM
CB900
rockdog32's Avatar
I use hairspray, grip slides on and holds really well....
rockdog32 is offline
