Goodbye Camshafts - Wrist Twisters
post #1 of 16 Old 10-11-2013, 07:35 AM Thread Starter
Goodbye Camshafts
I saw this the other day and thought it was really cool. Hopefully we see this on motorcycles sometime in the not so distant future.
Less weight, more power and better MPG... YES PLEASE!
The Future of the Internal Combustion Engine - /Inside Koenigsegg - YouTube
post #2 of 16 Old 10-11-2013, 08:02 AM
Wow! Truly remarkable. Can't wait to see this become common & finally trickle down to motorcycles. No need to open an engine to perform cam timing, no valve clearance checks! Just open your laptop, plug in & change timing.
arshishb is offline
post #3 of 16 Old 10-11-2013, 08:03 AM
TEXAN
MF1VE's Avatar
Saw that a while ago. I like the electro-pneumatic concept, and I hope this technology makes it all the way to large scale production.
MF1VE is offline
post #4 of 16 Old 10-11-2013, 08:18 AM
yeah saw this awhile back as well. Cool technology! lets see it make prime time.
post #5 of 16 Old 10-11-2013, 10:29 AM
Pulse controlled valves, there's an idea! Think what the weight and size savings can do!
post #6 of 16 Old 10-11-2013, 10:42 AM Thread Starter
Question for the gearheads: How does the ECU know when to spray fuel from the injectors and fire the spark plug? I assume the 9er still uses some sort of distributor, but what drives that? Is any of that driven from the cam assembly?
post #7 of 16 Old 10-11-2013, 10:51 AM
I could be completely wrong but here goes anyway: Probably a combination of Crankshaft Position sensor, Camshaft position sensor & the TPS.
arshishb is offline
post #8 of 16 Old 10-11-2013, 10:56 AM
You are completely right. Cam and crank sensors dictate timing order & the tps predicts input duration.
post #9 of 16 Old 10-11-2013, 01:36 PM
along with map sensor to detect load, and intake air temp as well.
post #10 of 16 Old 10-11-2013, 04:09 PM
Every current ECU made holds a virtual engine in memory, and the crank and cam sensor signals tell it where the crank (and therefore pistons) are within less than one degree, and which is completing the compression stroke. Obviously the crank sensor also gives engine speed information. From this data the raw injection period and timing is determined. This data is then modified by inputs from (in order) Manifold Absolute Pressure sensor, Throttle Position Sensor, Engine Coolant Temperature sensor, and Intake Air Temperature sensor, all of which can have a varying amounts of influence on the injection period. It also uses the signal from the speed sensor which when compined with the crank sensor signal tells the ECU which gear is in use and therefore anticipated engine load for the throttle position which is compared to the MAP input to determine relative ambient air pressure. From this information the final injection period is determined by shifting the X, Y, and Z coordinates of the injection and ignition maps from the raw values. Another parameter is the rate of the change from the TPS: a slow change (rolling on the throttle) modifies the injection period and ignition timing slightly, and a large change (whacking the throttle open) activates the accelerator pump function with a single long injection period and makes adjustments to the ignition timing for as long as the max acceleration continues.
I know for a fact that fueling and emissions software engineers worked on it for more than a year before they had something that Honda would release, and just the closed throttle response took more than three months to get accurate enough -- it's the best I have ever had the pleasure of using simply because of that.
Nonetheless, adding a pneumatic valve control function would not be an easy task, undoubtedly requiring endless hours of dyno work to get it close enough to start real world testing. Then packaging the necessary support equipment such as an air pump, accumulator tank of sufficient capacity for starting and maintaining pressure until the air pump catches up, control valve assemblies, yards of high pressure hoses, and all the other peripherals necessary to keep it working on a motorcycle is a seriously difficult task as well, and will probably weigh considerably more than the "old" cams and followers.
Whether it would pay sufficient dividends in terms of power and efficiency remains to be seen. TANSTAAFL. Besides, the three times I have checked the valve clearances in 70,000 miles without having to adjust one valve seems to make the "no valve adjustment necessary" argument moot.
post #11 of 16 Old 10-11-2013, 07:22 PM
Interesting Rob.....but I want to know what you REALLY think!
Professional
post #12 of 16 Old 10-13-2013, 06:29 PM
Damn Alan ... apparently you know me pretty well, don't you?
Yeah, as soon as I saw the video the thought "How would I do that?" came to mind. A couple of hours spent playing with CAD gave a pretty good start on it, though there is a ton of math to do! The most important aspect is packaging, especially on as space limited a platform that is a typical motorcycle. Lots of ideas on that subject.
I'll keep you posted here.
post #13 of 16 Old 10-13-2013, 07:50 PM
Well, I know that you only say about 1/100th of what you're actually thinking at any given time.
Wankel did away with cams and valves back in the 50's. I wonder what could be done with a similar rotary design with todays technology.
Professional
post #14 of 16 Old 10-13-2013, 07:58 PM
apex seals always kill that idea.
Though i love me the sound of a 4 rotor just bangin on the rev limiter.
post #15 of 16 Old 10-13-2013, 08:32 PM
That's why I qualified it with "todays (or even tomorrows) technology".
I don't see seals being that big of an engineering challenge now days.
Always kinda felt the Wankel concept was ahead of it's time.
I was lucky enough to drive Glenn Harris' stadium truck back in the mid 80's. It's little wonder why all the other teams complained about Mazda's rotary advantage....that thing was a little rocket ship!
Professional
post #16 of 16 Old 10-13-2013, 08:46 PM
What about toroidal engines? Seems promising but never understood why companies never funded it:
Toroidal Internal-Combustion Engines.
new engine - YouTube
