Ghost in the Headlight - Wrist Twisters
post #1 of 7 Old 01-08-2019, 11:44 AM Thread Starter
Ride with grace.
Devin4242's Avatar
I'm going to throw this one out there with no expectations because I'm fully aware how scattered electrical issues can be. But here goes:
2007 919, something like 12,000 miles on it, new Renthal mediums (last summer), and a new Streetshield installed over the weekend. Never had an electrical issue one. Yesterday evening, started her up at the office to go home and the headlight didn't work - well, I discovered the headlight didn't work as the sun went down. Got home uneventfully and went back out to trouble shoot an hour later or so. Checked for loose wires, bad fuse, etc., couldn't find anything. This morning I started it up to run out to Honda to pick up a bulb (but checked for the light first thing, no joy). I stopped halfway to fill up, restarted and DIDN'T check, having accepted the headlight failure. When I got to the dealership, the light was on and no amount of fussing with wiring or anything would provoke a failure, glimmer, or anything, it was on like it has been for the last 4 years or 5 years I've owned it. Anyone have a similar experience that might shed light on this headlight issue?
Thanks,
Devin
Devin4242 is offline
post #2 of 7 Old 01-08-2019, 11:55 AM
nathanktm's Avatar
Headlight was completely out? No hi or low beam? Possibly the starter ground thingie came off inside the right switchgear. It's common for 919. It's a very simple fix. There's a thread for it somewhere. Basically when you hit the starter, it kills the headlight for more amps. If the solder breaks on it, it's an open circuit and the headlight doesn't work.
nathanktm is offline
post #3 of 7 Old 01-08-2019, 01:54 PM Thread Starter
Ride with grace.
Devin4242's Avatar
Huh, that's a good place to start. I'll check the connection and follow up.
Thanks!
post #4 of 7 Old 01-08-2019, 01:58 PM
nathanktm's Avatar
https://www.wristtwisters.com/forums...ons-28152.html
This is the link to the thread and the fix. Hopefully it's something this simple.
post #5 of 7 Old 01-08-2019, 03:04 PM Thread Starter
Ride with grace.
Devin4242's Avatar
Gotcha, thanks for finding it! It's a likely issue since I had that bar cluster apart not that long ago.
Cheers!
post #6 of 7 Old 01-11-2019, 08:26 AM
Thanks,
Devin
Had this same problem a few years back, ended up being a solder ball bouncing around in there closing the contact to cut the headlight, probably more likely that you have a failed solder joint as that seems to pop up semi frequently, but you have to look in the same place for either problem so at least you know where to start.
post #7 of 7 Old 01-14-2019, 06:08 PM Thread Starter
Ride with grace.
Devin4242's Avatar
10-4, thanks for your input. Of course, it's started working again, without fail so far. I'm going to take the right handlebar cluster apart this weekend and see what's what. I did squirt some electrical contact cleaner in there, but I know that's a layman's answer without opening it up. Funny how such a minor item might cause such a major cluster (other meaning). I have some contact jelly that I will very delicately use on primary contacts, and truth be told, I did run through a major downpour lately, so maybe that has something to do with it. I'll take a picture when the cluster is open.
Cheers
