Gel battery - Wrist Twisters
post #1 of 13 Old 09-12-2012, 01:05 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Gel battery
Do I need I special charger for my gel battery?
:buell:
Whiplash97 is offline
post #2 of 13 Old 09-13-2012, 10:57 AM
Nope, ur special enough.
84interceptor is offline
post #3 of 13 Old 09-13-2012, 02:45 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Thanks, I know
:buell:
post #4 of 13 Old 09-13-2012, 03:12 PM
I think my 1month old battery isn't holding a charge. I'm going to have it tested today and if its bad, I'm getting a gel battery.
U mentioned b4 that u live in the NW, where abouts? Coz I'm in WA.
post #5 of 13 Old 09-13-2012, 03:24 PM
It seems a battery tender will do. Not sure if you can use it to maintain the battery, but shouldn't hurt to charge it if there's not enough juice to crank the bike. I have a tender that I rarely use unless my LiFe battery craps out. Even LiFe batteries say not to use chargers but seems to work fine still after using a tender to charge it that one time.
post #6 of 13 Old 09-13-2012, 03:33 PM
I charge it up fully then by 15min stop and go traffic its at about 12.4 volts and my bike is trying to die. So at a light I have to rev the engine above 1500rpm to keep the alt going. I've checked the charging system and its good.
post #7 of 13 Old 09-13-2012, 04:55 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Clatskanie, OR, about 15 miles from Longveiw
:buell:
post #8 of 13 Old 09-13-2012, 06:23 PM
Ah ok gotcha. I'm in bremerton. Ur like 2 1/2 hrs away I guess.
post #9 of 13 Old 09-13-2012, 06:45 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Yeh, we go by there when we go up to San Juan, and visit the inlaws
:buell:
post #10 of 13 Old 09-14-2012, 05:31 AM
Sounds like your bike isn't charging correctly as opposed to a bad battery. My 919 had a battery that was shot. Charge it for two days and it wouldn't even try to crank the bike. Jump the bike and I could ride an hour with the headlight on.
85rx-7gsl-se is offline
post #11 of 13 Old 09-14-2012, 05:43 AM Thread Starter
StormSurfer
Whiplash97's Avatar
Yeh, they get surface charge syndrome, meaning they register 12 volts but no cranking amps, everything works fine but bike won't start
I found my gel battery on eBay for $40-free shipping, they come factory charged, maintenance free, deep cycle....only time will tell if it's worth a shit
I just asked about the charger in case it did die on me
:buell:
post #12 of 13 Old 09-14-2012, 12:39 PM
Had the battery checked and it was good, full amps and all. I check my charging system and its working good. Started a new thread for this "bike trying to die, low rpm" there's more of the story there
post #13 of 13 Old 10-05-2012, 09:21 AM Thread Starter
StormSurfer
Whiplash97's Avatar
Short Description
The Battery Tender® Junior is much more than a trickle charger. It has a brain. It's lightweight, compact, and fully automatic; very easy to use, especially in small spaces. It will keep your battery fully charged so that it is ready to go when you are!
Description
Help Documentation
Perfect for all lead-acid, flooded or sealed maintenance free batteries (AGM and gel cell).
Complete 4-step charging program (Initialization, Bulk Charge, Absorption Mode, Float Mode).
:buell:
