Gear backlash from neutral to first gear solved - Wrist Twisters
post #1 of 4 Old 06-03-2014, 09:28 PM Thread Starter
Just hoping this might help someone as I myself just sifted through the site for this problem and didnt find too much.
Riding home from a typical commuter day probably about two hours of ride time total with about 15000 on the clock I started noticing a rattle when shifting from N to 1st and giving some throttle to get going again at stop lights. It felt like the clutch shifter was violently jerking back and forth. My heart fell into my butt since I had been practicing clutchless shifting, visions of loose gears erupting from the side of my engine danced in my head.
When I got home I put the bike up on a swingarm stand and noticed the chain was unexpectedly very loose so I tightened it up and the lock nut on by the clutch lever was freely spinning so I adjusted the clutch cable as well.
Took it for a spin down the street and voila no more crazy noises, this is my commuter and I have a 4 hr round trip planned for tomorrow so moral of the story is a very loose chain can make the 919 do crazy things. If things go bad tomorrow I will recant.
g26er is offline
post #2 of 4 Old 06-03-2014, 10:06 PM
Yup. Also check the shifter linkage, it will vibrate loose on you and fall off.
post #3 of 4 Old 06-04-2014, 04:16 AM
Good catch. Glad you got it solved easily!
post #4 of 4 Old 06-04-2014, 04:51 AM
Honda919Rider #1
Agreed, good catch.
Routine maintenance is important.
Check your owners manual for a list of everything else that should be checked, you might be surprised.
Once, a long time ago, 1980's I believe, I was able to cure an issue with poor handling and slow steering by adding air to my tires.
Who would of thought!
Steve is offline
