Gauge Face replacement? - Wrist Twisters
 3Likes
  • 1 Post By g00gl3it
  • 2 Post By ewmin3m
post #1 of 12 Old 08-11-2018, 12:38 PM Thread Starter
CenCO 919's Avatar
Water has found its way into the speedo and Tach on my 919 resulting in a few small ( max 8mm) bubbles. It's not a big deal and I believe the issue is just cosmetic, but haven't torn it all apart.
I am a little obsessive about the bike...
Is there an alternative to buying a used speedo assembly (~$400) ? Seems to be no shortage of replacement gauge backgounds for cars- havent seen any for the bike and dont know if replacing just the numbered background is an option..
Thanks
CenCO 919 is offline
post #2 of 12 Old 08-11-2018, 03:08 PM
Quadiak's Avatar
I'm not sure if the 599 hornet has the same gauges. Also not sure if you are near Ontario canada anywhere but I found these.
Please view this ad:
599 Hornet Guage Faceplates, New,
https://www.kijiji.ca/v-motorcycle-p...nt=app_android
Price: $*20
Which also leads me to believe that they might be available for the 919 as well
Download the application from the Google Play Store.
http://goo.gl/Hs9Yg
Quadiak is offline
post #3 of 12 Old 08-11-2018, 06:00 PM
Diablo's Avatar
You can get a whole new setup on ebay, if your really fussy that is.
https://www.ebay.com.au/itm/Gauges-S...sid=m570.l1313
Diablo is offline
post #4 of 12 Old 08-11-2018, 06:54 PM Thread Starter
CenCO 919's Avatar
I am not $200 fussy, but that seems like a good deal if i lived in AUS.
Thanks
post #5 of 12 Old 08-11-2018, 06:55 PM Thread Starter
CenCO 919's Avatar
Price: $*20
http://goo.gl/Hs9Yg
thanks for looking this up, will check it out.
2002 Bandit 1250s
2003 SV650
1995 ZX1100e
2006 919
post #6 of 12 Old 08-15-2018, 09:30 PM
Topher919's Avatar
Here's an option. Plenty more on eBay.
https://www.ebay.com/itm/Gauges-Spee...Submodel%3A919
Topher919 is offline
post #7 of 12 Old 08-15-2018, 09:31 PM
Topher919's Avatar
The gauges on my 9er are cracked, so I do wonder about the mileage when installing new gauges. Is it pretty simple to program in the old mileage in to the new gauges? Anyone know?
post #8 of 12 Old 08-16-2018, 03:49 PM
599 gauges will not work. I had both bikes. 599 redline is higher and the connections are quite a bit different. Also, they changed gauges between the 2004 and 2006 years from analog to digital.
I guess you could try getting the digital one's to work, if it could read all of the values. One thing for sure that probably wouldn't work would be the fuel level sensor.
Price: $*20
http://goo.gl/Hs9Yg
ewmin3m likes this.
post #9 of 12 Old 08-16-2018, 04:12 PM
ewmin3m's Avatar
Why not go custom?
Wasn't there a ballin' write up of Koso Gauges or wtvr it's called?
Gives it a more modern look.
g00gl3it and steev like this.
ewmin3m is offline
post #10 of 12 Old 08-21-2018, 04:27 PM
Koso gauges are the bomb for aftermarket...
post #11 of 12 Old 08-21-2018, 04:32 PM
ewmin3m's Avatar
and for your wallet lol :P
400greens :P if you want to go brand new:
https://kosonorthamerica.com/shop/mo...on-10-000-rpm/
Though I would assume it's worth it if you re-do the entire from end, to modernize the whole area.
ewmin3m is offline
post #12 of 12 Old 08-21-2018, 04:35 PM
This was a great read for Koso gauges. I ended up buying those gauges from Arctic and had a blast with them. Yes, they are a bugger to install, but are the shiznit.
https://www.wristtwisters.com/forums...led-25350.html
