Gauge cluster Wiring Digram for 2007 919 - Wrist Twisters
post #1 of 19 Old 10-31-2012, 04:22 PM Thread Starter
Does anyone have the wiring diagram for the gauge cluster on a 2007 honda 919?
Thanks
ASIANREDNECK is offline
post #2 of 19 Old 10-31-2012, 07:45 PM
download the 919 service manual (hosted on my webhost)
http://teamlosi.andrevas.net/pics/ri...ice_Manual.pdf
page 425 of the pdf.
post #3 of 19 Old 11-04-2012, 02:46 PM Thread Starter
I tried reading the wiring schematics, super confused. I've been working on this for like 4 days and can't seem to get things right.
Can anyone help me match up the wires?
My aftermarket gauge cluster have these wires
Aftermarket Gauge Function and wire color: The 919 Wires according to schematics
1st Gear/Pink:
2nd gear/ Blue/ Red:
3rd Gear/green/Black:
4th Gear/Yellow/ Black:
5th Grear/Brown/ white:
Speedometer/ Yellow: PurpleGreen/RedGreen?
Water Temp/ Green/ Blue: Green/Lightbrown?
Fuel Level/ Yellow/white: Brown/ Black?
Neutral/ Green/red: Red/Light Green?
Gear 6 red/white:
Left turn signal/ orange: Green/ Orange?
High Beam/ Blue: Greenn/ Blue?
Back Light/ Brown: Green with Brown?
Ground/ Green: Black?
Right Turn Signal/ Light/Blue: Green/ Light Brown?
RPM/Blue/white: Green/black?
Positive/ Black:
post #4 of 19 Old 11-04-2012, 06:20 PM
snowytgr1's Avatar
this was coppied from arctic954 wiring a KOSO RX2N gauge to his 919
This came from thread "Koso RX2N Finally installed"
Hope this helps
KOSO--------------------------------- OEM Harness
White (right turn signal) --------------Lt Blue
Brown (RPM wire)--------------------- Yellow/Green Stripe
RED (Main Positive Power)------------Connect to the battery + terminal
Black (ground) ------------------------ Green (this wire goes to Rob's LED fuel harness)
Brown (keyed Ignition, 12v +)-------- Keyed Ignition Signal (on your own)
Lt Grey (left turn signal) ------------- Orange
Orange (oil light) --------------------- Blue/Red Stripe
Purple or Violet (FI light) ------------ White/Blue Stripe
Yellow (high beam indicator)---------Dark Blue/Black Stripe
Blue (neutral light)--------------------Light Green/Red Stripe
Green (fuel gauge indicator)----------No Connection - See below
snowytgr1 is offline
post #5 of 19 Old 11-04-2012, 06:27 PM Thread Starter
I just notice that the user manual nd4spd sent me has a different wiring harness
thanks that helped a lot.
post #6 of 19 Old 11-04-2012, 08:13 PM Thread Starter
Anyone know how much Rob is selling is resistor thingy for the fuel gauge?
post #7 of 19 Old 11-05-2012, 08:44 AM
+04's have a different wiring harness, Arctic did his for a 1st gen harness; I had to pull the pins out of the harness and reassemble them in a different order for my Koso install to work.
post #8 of 19 Old 11-05-2012, 08:46 AM
Not sure how much, but I think you can contact him through here:
Thar Engineering - Electronics and Instrumentation
post #9 of 19 Old 11-05-2012, 01:09 PM Thread Starter
G00gl3it Do you have the pin diagram for the 2007 919?
Thanks
post #10 of 19 Old 11-05-2012, 03:34 PM
Thanks
I don't, unless it's already in the Service Manual that we have linked.
I do know the '07's actually had one less wire than the -02's. I had an 02 to look at, so we physically matched up the color and location of the wires, then I laid out the '07's wiring harness to match up exactly like the 02's receiving end. Then plugged the Koso in and it worked.
Ironically, Arctic mentioned that his blinker indicators on the gauges never worked, but they did on my bike when I plugged the Koso's in.
And Arctic has already done the splicing on the Koso gauges as well as sent me his 02 wiring harness, hence the need for the change. So it was really plug and play for me.
If Helimech ever gets around to looking at his, he could probably tell you, as he has these gauges now, and '02 wiring harness.
post #11 of 19 Old 12-17-2012, 04:48 PM
Dragon Slayer
oak1971's Avatar
Team Losi?
oak1971 is offline
post #12 of 19 Old 03-27-2013, 11:05 AM
Will a digital guage from a cbr work on a 02 919 with just matching to wire correctly or will i need more things.
02hornetrider is offline
post #13 of 19 Old 03-27-2013, 12:43 PM
bpolunin's Avatar
FYI, the 12v constant, you don't have to run all the way to the battery. You can connect to Red/green stripe wire in the harness. And the white/green stripe for the 12v switched. I figured it out thanks to ganktor.
Hope this helps
2007 Yamaha VStar Classic
2005 Suzuki SV650 - traded
2003 Honda 919 - traded
2008 Aprilia Tuono 1000R - Sold
2008 Aprilia RSV1000R Track Only
2007 Honda CBR600RR - sold
2005 Honda CBR600F4i
bpolunin is offline
post #14 of 19 Old 03-27-2013, 01:00 PM
i want to say it MIGHT work... but im pretty sure it uses a different coolant temp sensor .. so temp reading will be off. Also we only have a reserve indicator for gas... the CBR's had a full real time fuel level sensor in em.
post #15 of 19 Old 03-27-2013, 02:45 PM
Cmon people, do a search! You're on a 919 forum, why try to reinvent the wheel?
https://www.wristtwisters.com/forums/...9-a-24654.html
post #16 of 19 Old 03-27-2013, 04:22 PM
Thank you i searched but didnt find...i was on google too...thanks again
post #17 of 19 Old 03-27-2013, 06:30 PM
Twpvs. (That's what PV said). Lol.
post #18 of 19 Old 03-27-2013, 08:30 PM
Haha, that was funny, not gonna lie. Good catch.
NOW GET OFF ME PV!!!!!!
post #19 of 19 Old 03-28-2013, 02:42 PM
The forum has a built in search engine that is a valuable resource. This forum has a heck of a collection of information. Its a great place!
Now that was funny. You're a sick sick man....
