Gauge backklights stopped working - Wrist Twisters
post #1 of 21 Old 06-30-2013, 03:56 AM Thread Starter
Anyone have any ideas about gauge backlights that have stopped working. I don't think its bulbs as both stopped working at the exact same time.
thanks
scsaxott is offline
post #2 of 21 Old 06-30-2013, 07:12 AM
Ginger-prick
EatDirtFartDust's Avatar
The guages come off and the backing splits away from the front pretty easy.
You can check for power at the bulb sockets. I've seen where one bulb on a circuit goes out and the powers surge/spike causes the other to go too. I've seen it on cars a few times.
If you need bulbs, I can drop a few red led replacements in the mail for you Monday.
2007 Honda 919.
EatDirtFartDust is offline
post #3 of 21 Old 06-30-2013, 07:15 AM
Ginger-prick
Are any other lights not working? Taillight, headlamp, fi indicator, low fuel, check all of them.
2007 Honda 919.
post #4 of 21 Old 06-30-2013, 04:46 PM
thanks
Yup, bulbs blew. Replace them. Or if you prefer, do a search and find the LED replacement equivalent and order them on ebay in the color you like.
post #5 of 21 Old 06-30-2013, 04:51 PM
Ginger-prick
If you want red, don't buy them. I have extras.
2007 Honda 919.
post #6 of 21 Old 06-30-2013, 04:59 PM
happened to me, takes a bit to remove all the stuff in the way, but pretty easy job.
all of mine were out at the same time.
post #7 of 21 Old 06-30-2013, 05:15 PM
Nice! Great offer of you
Where's mine?
post #8 of 21 Old 06-30-2013, 05:22 PM
Ginger-prick
Just pm me your address.
I think I'm gonna order some green LEDs and see how they look...
2007 Honda 919.
post #9 of 21 Old 06-30-2013, 05:50 PM
Real nice of you, I was just kidding though
Do post a review of the green ones! While the blue ones looked slick, they were very hard to see/read.
post #10 of 21 Old 06-30-2013, 06:22 PM
Ginger-prick
Will do.
$100 PayPal to the first person that can make our gauges go from green to red as the gauges get farther to the right. That would be sick.
2007 Honda 919.
post #11 of 21 Old 06-30-2013, 06:53 PM
Will do.
It may only work once...
Green LED turns red! - YouTube
post #12 of 21 Old 06-30-2013, 09:08 PM
Raddock
04Hornet919's Avatar
I am really interested too - I have a green 919 and I bet some green lights would look sick!
Keep us posted!
Doc Hornet
Certified Streetfighter Enthusiast
2004 Honda Hornet Owner
04Hornet919 is offline
post #13 of 21 Old 07-01-2013, 04:51 PM
One solution would be to have BOTH green and red, switch one off, the other on at certain RPM/speed/etc...
You'd have to have a sensor. I think the 919 comes stock with a rev limiter so that might work, otherwise you'd need some kinda sensor.
Wouldn't mind having a one, but finding the sensor could be a challenge.
post #14 of 21 Old 07-01-2013, 05:44 PM
Ginger-prick
I'd have a sensor on the speedo which switched at 70
And one on the tach at around 6-7 k.
I'm not that hard on her, so I wouldn't see the red much if I used the actual red-line.
2007 Honda 919.
post #15 of 21 Old 07-03-2013, 07:03 AM
Will do.
No sweat. There are a variety of frequency to voltage IC's that could take the speedo or tach signal and at a predetermined speed / RPM change instrument illumination from green to red. BTW, they have been making both Green and Red LEDs in a single two lead bulb for quite a while -- polarity in one direction lights Green, in the other lights Red. Presently looking for ultra bright units. I'll keep you posted.
post #16 of 21 Old 07-03-2013, 09:18 AM
Ginger-prick
Sweet!
2007 Honda 919.
post #17 of 21 Old 07-03-2013, 09:25 AM
Sweet!
+1 that would be Hella epic! Only issue is you wouldn't be able to see it in the day time. That might actually be a good thing as then I wouldn't be tempted to make the colors change on every shift
post #18 of 21 Old 07-03-2013, 10:48 AM
I'd be far more interested in one of the "flash" brake lights you see on fire trucks. When the brakes are applied, the brake light flashes then comes one solid. I was behind a fire truck and it was very noticeable.
I imagine they have one of these somewhere. Maybe better would be a constant and flashing brake light.
post #19 of 21 Old 07-03-2013, 01:36 PM
CUSTOMLED
Very
Can change strobe from 1 flash up to I think 6 or 7 before becoming solid. I have mine currently set to 3. Love that thing.
post #20 of 21 Old 07-03-2013, 02:23 PM
Ginger-prick
I have the CustomLED too, it's pretty cool. And very bright. It'll be brighter when I switch from a red to a smoke lens.
2007 Honda 919.
post #21 of 21 Old 07-03-2013, 07:04 PM
both mine went out, turned out they had both loosened off, so when pushed back they worked.
I had already bought the red leds incase they were broken, so i put them in. Glad i did the are bling and bright.
Its only a half hour job and easy
davehirt is offline
