Fuel pump not working - Wrist Twisters
post #1 of 27 Old 03-12-2014, 03:18 PM Thread Starter
loudcity919's Avatar
Went to turn on my bike, didn't hear the fuel pump engage. I just put a brand new one in a month ago. Turns over but won't start. Keep in mind I'm not exactly a motorcycle expert. What's wrong with it?
loudcity919 is offline
post #2 of 27 Old 03-12-2014, 03:27 PM Thread Starter
Just went and tried it again and it's working now. Wtf
post #3 of 27 Old 03-12-2014, 03:28 PM
Time to check connections...
post #4 of 27 Old 03-12-2014, 03:59 PM
Check the cables inside the starter and kill switch. Maybe your relay got stock?
Next time your fuel pump doesn't prime try flicking the kill switch fast a few times (with ignition off) and see if that does it...then it's a dirty or loose connection.
If that doesn't do it, pop the seat off and tap the relay. The manual says which is for the fuel, tap it with the back of screwdriver and see if it might be stuck.
That's what I'd do firs.t
post #5 of 27 Old 03-12-2014, 04:53 PM
That damn killswitch should be removed! I noticed it first on my 2004, then while rebuilding my 2002 I noticed the same problem. Since I had the 02 apart, I went ahead and cleaned it up. Easiest way to tell if its the problem is to set it to run, then tap on it. I was able to get the fuel pump to recycle doing that.
post #6 of 27 Old 03-13-2014, 01:22 PM
The kill switch is a known Honda weak point. People need to stop using it in general and use it only in emergencies.
post #7 of 27 Old 03-13-2014, 01:27 PM Thread Starter
So I got it running and ride around, but she'll turn off randomly. Once at a stoplight and the other while riding. Where is the kill switch located
post #8 of 27 Old 03-13-2014, 01:29 PM
Big red rocker switch next to the throttle.
post #9 of 27 Old 03-13-2014, 01:32 PM Thread Starter
Oh lol I thought you might have meant the one for the kickstand. I feel stupid now.
post #10 of 27 Old 03-13-2014, 01:34 PM
post #11 of 27 Old 03-13-2014, 02:08 PM Thread Starter
Ya
post #12 of 27 Old 03-13-2014, 02:11 PM
Real question though is there a throttle out there which does not have a kill switch? Something sleek simple and low profile?
post #13 of 27 Old 03-13-2014, 02:21 PM
Lol, don't worry about it. It's taken me way too long to learn that it's better to ask the question if there's any doubt or possibility of misunderstanding.
post #14 of 27 Old 03-13-2014, 02:30 PM Thread Starter
I'd buy that if there is one
post #15 of 27 Old 03-13-2014, 04:12 PM
redacted statement
post #16 of 27 Old 03-14-2014, 01:29 PM Thread Starter
Every now and then I can get it to start working. Do I need to go ahead and buy a new kill switch? This shit is driving me crazy.
post #17 of 27 Old 03-14-2014, 03:11 PM
If it starts working when you are jacking with the kill switch just take the switch apart and clean up the contacts....then stop using that switch.
post #18 of 27 Old 03-14-2014, 03:25 PM Thread Starter
I just did that and after I cleaned up everything it completely stopped working.
post #19 of 27 Old 03-14-2014, 10:16 PM
You sure you put it all back together correctly? Check for any loose wires if you can.
...on my droid.
post #20 of 27 Old 03-14-2014, 10:18 PM Thread Starter
I had it back together for over a month and everything worked great. Is there something in the kickstand that would keep it from working?
post #21 of 27 Old 03-15-2014, 07:38 AM
If the bike is in neutral, the sidestand switch is bypassed.
post #22 of 27 Old 03-15-2014, 10:16 AM
I haven't been following the thread but, if it does turn out to be the pump, I have have one I'll make you a great deal on. The original owner changed it for a new one because the low-fuel light came on early, don't they all, but this one does the same thing.
He had it swapped when the bike had less than 1,000 miles so this one is like-new.
post #23 of 27 Old 03-15-2014, 02:08 PM Thread Starter
Thanks man when I get it diagnosed I'll let you know if I need it.
post #24 of 27 Old 03-15-2014, 02:28 PM
Good luck man.
post #25 of 27 Old 03-16-2014, 05:07 PM Thread Starter
Fully charged the battery, fuel pump still won't turn on. Cleaned the connections on the killswitch. Still nothing.
post #26 of 27 Old 03-16-2014, 05:50 PM
Lift the tank, measure for voltage the fuel pump connector.
post #27 of 27 Old 03-31-2014, 05:14 PM
redacted statement
Sooooo I was surfing Nagawa parts for my cbr250 last night... and realized I indeed wrongfully redacted my statement. I thought I had seen these available elsewhere, but could not for the life of me remember when or where.
ACTIVE : Only vehicles High throttle kit [ EVO ] [1065042]
If it was way less than $150 and there were more details available I'd certainly be looking at purchasing one. If it doesn't fit the 919 it'll fit the cbr250. Looking at the pictures they have different cam sizes available.
Anyone want to contribute to the fund to see if it'll work with the 919?
