Fuel Pump Not Priming After PCIII USB Install - Wrist Twisters
post #1 of 5 Old 10-25-2014, 11:24 AM Thread Starter
Mxhonda215's Avatar
Yesterday afternoon I finally got around to installing my PCIII usb. After I was all said and done, I went to start it to make sure everything was working properly. I turned the key on and flicked off the kill switch and everything turned on on like normal....except the fuel pump did not prime. I played around with the kill switch (just to make sure it didn't have a bad contact) but still nothing. Has anyone else experienced this problem before? I still need to go through and do some more thorough trouble shooting, but if any of you have an idea on what it could be, let me know. The weather is way to nice to be wasting right now. Thanks guys
Mxhonda215 is offline
post #2 of 5 Old 10-25-2014, 11:36 AM
Did it start?
post #3 of 5 Old 10-25-2014, 12:08 PM Thread Starter
Mxhonda215's Avatar
Originally Posted by voodooridr View Post
Did it start?
No, it did not. The engine turns over but does not fire
post #4 of 5 Old 10-25-2014, 01:42 PM
Honda919Rider #1
If it was fine before the install, recheck all connections - especially the connector and the ground.
Does the PCIII show power? When you turn the throttle, lights light up in sequence with the throttle
Steve is offline
post #5 of 5 Old 10-25-2014, 03:27 PM
Was the bike in Neutral or the side stand up?
