fuel pump - Wrist Twisters
 3Likes
  • 2 Post By beefsalad
  • 1 Post By Islandboy
post #1 of 12 Old 01-07-2020, 08:23 AM Thread Starter
fuel pump
looking for the proper fuel pump for my 919 any help is greatly appreciated.
theicon45 is offline
post #2 of 12 Old 01-07-2020, 11:26 AM
I had surprisingly good results from a very cheap pump, Kemso. Ran great for two years or so. Only took it out cause I found a brand new OEM unit that was going cheap. The kemso pump is now a spare.
It's a rebranded aeromotive stealth pump and I doubt very much it is made in Japan.
https://rover.ebay.com/rover/0/0/0?m...2F163973502473
post #3 of 12 Old 01-15-2020, 11:36 AM
https://www.highflowfuel.com/ag-1323...b900f-efi.html $70-$100 depending on how complete of a kit you want. I believe they only sell remans, but I've had darn good luck with them.
mcromo44 and Islandboy like this.
post #4 of 12 Old 01-15-2020, 01:28 PM
Looks like they sell some good 919 fuel tank stuff.
mcromo44 likes this.
post #5 of 12 Old 01-16-2020, 03:56 PM
Website access info duly squirreled away,
post #6 of 12 Old 03-10-2020, 07:02 AM
Reagan.a's Avatar
That's a great price for a fuel pump, but it looks like it doesn't come with a low fuel sensor. Can it be rewired to use the existing sensor? Also, how hard was it to replace the old fuel pump with this one?
Reagan.a is offline
post #7 of 12 Old 03-11-2020, 04:00 PM
Reagan.a's Avatar
Ah just saw that you have to disassemble the fuel pump assembly to add this in with the existing low fuel sensor and fuel filter.
I ended up buying Kemso. It was too hard to pass up at $25 USD.
http://www.ebay.com/itm/151917929325
Thanks for recommending it Islandboy! Besides the intake strainer, did you have any other problems assembling it?
Reagan.a is offline
post #8 of 12 Old 03-11-2020, 04:37 PM
Glad to help mate.
The new pump fitted up to the old pump assembly easy. An electrical connector, fuel line and a band clamp.
Just reuse the old strainer if the supplied strainers don't fit. I gave the old strainer a good clean.
post #9 of 12 Old 03-12-2020, 09:31 AM
Reagan.a's Avatar
That's a relief to hear. Would you recommend changing the fuel filter as well?
Reagan.a is offline
post #10 of 12 Old 03-12-2020, 01:23 PM
If it was me. I would drop in a new fuel filter.
The one in there might be fine but how can you tell? By putting in a new one you can be sure.
post #11 of 12 Old 03-12-2020, 03:03 PM
Aye tae tha'.
Once you're in, and don't want to have to go back in, wiser to replace it, even more so, it being a nickel and dime part.
post #12 of 12 Old 03-15-2020, 03:46 PM
Reagan.a's Avatar
That's a good point. I'm not trying to do this again in the near future after this time. I ended up ordering the fuel gasket, fuel return filter and the fuel filter from quantum. It was cheaper than OEM, hopefully it's just as good.
Reagan.a is offline
