Front wheel conversion question - Wrist Twisters
post #1 of 14 Old 11-11-2014, 02:00 PM Thread Starter
Now that I've been drawn into this conversion exercise, just because it's there (damn you, WristTwisters!), can anyone tell me if the front wheel I am looking for (CBR or VFR) is symmetrical, ie both sides look like the pic below?
K1w1Boy is offline
post #2 of 14 Old 11-11-2014, 02:10 PM
gibbonater's Avatar
You will need an CBR F3 17" front wheel for the 6 spoke conversion. This will have you do the least amount of modifications. Fortunately the one I purchased came with rotors. You will need an F3 front axle and some spacers as well.
I'm not sure about the VFR though.
6 spoke is the ticket!!!
Bikes:
2004 V-Rod (sold)
2004 CBR600F4i (sold)
2003 RC51
2010 Triump Scrambler (sold)
2003 CB900F
2004 CBR 600rr
Non Bikes:
2007 JK Sahara
2005 CTS V (sold)
2006 Audi S4
gibbonater is offline
post #3 of 14 Old 11-11-2014, 02:23 PM Thread Starter
OK.
And are the hubs on a CBR wheel exactly the same both sides? The wheel I'm investigating is purported to be an F3 wheel, but I'm not sure that that's correct, hence my qn about symmetry.
K1w1Boy is offline
post #4 of 14 Old 11-11-2014, 02:28 PM
The front wheel is usually the same on both sides, but it will have a directional (rotational) travel arrow, intended to be mounted the correct direction.
post #5 of 14 Old 11-11-2014, 02:32 PM Thread Starter
Thanks.
What I think I'm seeing [from the pics only] are slightly different hub sizes each side, although identical disc-mounting platforms.
K1w1Boy is offline
post #6 of 14 Old 11-11-2014, 02:36 PM
gibbonater's Avatar
They should be the same on both sides for the F3, yeah. Again, not sure about the VFR, but probably yes as well for the front wheel.
Bikes:
2004 V-Rod (sold)
2003 RC51
2003 CB900F
2004 CBR 600rr
Non Bikes:
2007 JK Sahara
2005 CTS V (sold)
2006 Audi S4
post #7 of 14 Old 11-11-2014, 02:47 PM Thread Starter
Cool, thanks for your help.
K1w1Boy is offline
post #8 of 14 Old 11-11-2014, 03:48 PM
The wheel bearings are the same size for both sides, right? So the hub diameter should be the same.
One thing to note, if the axle is like my 599 axle, the left side (while sitting on the bike) has a larger diameter as the axle itself travels through the left fork and sets into the hub of the wheel, while the right side is smaller where just the axle travels through and connects to the right fork (of course there are spacers on each side). The spacers are what make up the difference between the right and left side differences on the axle (as well as the forks).
So you will also need to know if the axles are interchangeable as well, as that will depend on what forks you can connect to.
post #9 of 14 Old 11-11-2014, 04:01 PM Thread Starter
Thanks, Goog.
I'm prepared to undertake a bit of mix and match by the time I get to the axle / spacer part of the deal.
Another question - do the bolts holding the disc carriers to the hub screw into threaded holes, or are they nut-and-bolt? I can't tell from either schematics or pics.
Thanks.
K1w1Boy is offline
post #10 of 14 Old 11-11-2014, 05:02 PM
Threaded holes in the rim, since you're coming from a land down under check these guys out, looks like pretty good pricing on rotors and such
MetalGear - Home of Quality Braking Components
post #11 of 14 Old 11-11-2014, 06:46 PM Thread Starter
Thanks, and I'll check the link. Cheers!
K1w1Boy is offline
post #12 of 14 Old 11-14-2014, 10:47 AM
redline919's Avatar
The Vfr wheel is the same as the f3
redline919 is offline
post #13 of 14 Old 11-14-2014, 10:49 AM
redline919's Avatar
You have a Vfr wheel sir
post #14 of 14 Old 11-14-2014, 11:41 AM Thread Starter
Sorry, can't attribute this for the deserved hat-tip, but this twister found the 919 axle to be a fit, while others [eg Gibbonater above] suggest an F3 axle is needed:
"By mixing and matching 919 and f3 collars (see photo) all fit PERFECTLY!! The calipers had to be shimmed 1.5mm inward. Done.
Looking directly at the photo (right side of axle is on left) in order of sequence:
1) Mounting bolt
2) Right side 919 collar
3) Left side 919 collar
4) F3 collar, left or right will work
5) 919 axle
6) Above are shims (ss washers)"
Anyone got anything to add? Maybe it depends...?
K1w1Boy is offline
