Front sprocket removal 919 - Wrist Twisters
post #1 of 13 Old 07-26-2013, 06:27 PM Thread Starter
RIDE RED
SPYDER's Avatar
How the hell do you get this thing off left-hand thread right-hand thread bikes in gear still can't get it to break loose any help greatly appreciated respond as soon as possible thank you
SPYDER is offline
post #2 of 13 Old 07-26-2013, 06:35 PM
Stutz's Avatar
Stutz is offline
post #3 of 13 Old 07-26-2013, 06:39 PM
Impact.
post #4 of 13 Old 07-26-2013, 06:42 PM Thread Starter
RIDE RED
SPYDER's Avatar
Don't have heat or an impact wrench gonna put the old chain back on use rear brake to hold it should have known to not take it off first weber's law
SPYDER is offline
post #5 of 13 Old 07-26-2013, 06:47 PM Thread Starter
RIDE RED
SPYDER's Avatar
Thanks for the quick reply guys my new chain and sprockets are supposed to be here next week haven't been riding as my chain was making a god awful grinding growling noise upon closer inspection my sprockets are starting to curl forward maybe I should have replaced everything last spring and not just the chain at least it was just a cheep Chinese $40 chain and it got me by for this long new Sunstar sprockets and a D.I.D. Chain on the way live and learn
SPYDER is offline
post #6 of 13 Old 07-26-2013, 06:50 PM
You can also use a broomstick thru the rear wheel to jam against the swimg arm. Easier than using the rear brake.
post #7 of 13 Old 07-26-2013, 06:52 PM Thread Starter
RIDE RED
SPYDER's Avatar
Had to become a contortionist but holding the rear brake seem to work just fine thanks again guys
SPYDER is offline
post #8 of 13 Old 07-26-2013, 07:24 PM
yup i have always used the rear break to break that bolt loose... typically ill sit on the bike. with breaker bar in hand and foot on the rear break.
post #9 of 13 Old 07-26-2013, 07:24 PM
Hastatus Prior
TheBeeDeeGee's Avatar
Glad you got it off. I just held my rear brake and stepped on a the ratchet with my weight to break it loose.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #10 of 13 Old 07-26-2013, 07:31 PM
+1 works great
post #11 of 13 Old 08-02-2013, 09:58 AM Thread Starter
RIDE RED
SPYDER's Avatar
Another front sprocket ? Ordered a Sunstar and its narrower than the one I removed I've read on here you have to shim it if loose on the shaft but both dealers I have called say there is no such thing where do I get them? The one I took off measures .68 the one I want to put back on is .58 or should I just throw it on and go with it?
SPYDER is offline
post #12 of 13 Old 08-02-2013, 10:38 AM
All of the aftermarket sprockets I have used are narrower than OEM. They will move laterally on the splined shaft a bit. I haven't had any issues with it.
post #13 of 13 Old 08-02-2013, 10:46 AM Thread Starter
RIDE RED
SPYDER's Avatar
Thanks Mike
SPYDER is offline
