Front sprocket removal - Wrist Twisters
post #1 of 12 Old 01-04-2009, 07:04 PM Thread Starter
Can someone please tell me how to remove my front sprocket. I attempted it and it was turning the transmission. I tried with the bike on the ground and on the stand. I think I was in second gear while doing such. Is the sprocket reverse threaded or something?
post #2 of 12 Old 01-04-2009, 07:13 PM
Curmudgeon
semi_gray's Avatar
No, it's not left-hand thread.
Try 1st gear. The gear reduction is more to your advantage.
Try to use a hammer and whack the wrench to effect short sharp spikes in torque. Barring that, an air impact wrench would be preferred.
semi_gray is offline
post #3 of 12 Old 01-04-2009, 07:17 PM
get someone to press on the rear break always works for me... and use a quality socket or you will strip the head.
post #4 of 12 Old 01-04-2009, 07:23 PM
Curmudgeon
semi_gray's Avatar
Nice tip! I had overlooked that one.
post #5 of 12 Old 01-04-2009, 07:29 PM Thread Starter
thanks guys ill give it a try.
post #6 of 12 Old 01-05-2009, 04:01 PM
get 1/2" breaker bar--hold in left hand, right hand on handlebars
sit on bike
right foot on rear brake, left foot on ground
loosen bolt
Bryce919er is offline
post #7 of 12 Old 01-05-2009, 04:14 PM
sit on bike
loosen bolt
My next step would be hit ground with face and cover body with motorcycle
voodooridr is online now
post #8 of 12 Old 01-05-2009, 07:59 PM
You must not be very coordinated. It worked fine for me.
post #9 of 12 Old 01-11-2009, 03:40 PM
Ride Offensively
FloridaMountaintop's Avatar
AIR Impact is best!
I Can and will ride anything!
Bikes I own:
New addition 1978 CB750Four
2006 919
1994 home built springer
1984 KLR 600
1985 Honda 200M ATC
1985 Honda ATC 70
YEA BIGDAA I Gotta GUN!
FloridaMountaintop is offline
post #10 of 12 Old 02-06-2009, 09:26 PM
BrokeRecord
What
40 lbs of torque shouldn't be a big bear in the woods. Impact wrenches are for lug nuts on a truck, not 40 lbs. If your friend holds the brake and it still won't bulge, get a membership at the health club. I doubt the factory torqued too much.
brokerecord is offline
post #11 of 12 Old 02-06-2009, 09:46 PM Thread Starter
I ended up using a 15'" breaker bar and put it on the nut. Sat on the bike holding front brakes and pushing rear brakes while the bike was on the stand in first gear and left leg on the ground. Was able to break it loose.
The shop that put the sprocket on put it on tighter than the recommended torque. I was having problems with the the small ratchet, because i had the bike in 2nd and was not holding and breaks. When I made the transmission turn once I got scared and stopped.
post #12 of 12 Old 02-07-2009, 06:17 AM
This useful but so wrong. If you are going to use this method. Please purchase a dead blow hammer for this. Or if you can find one, a Brass hammer. These types of hammers will give you the force need to move a wrench. But they won't send a shock wave through the entire system. Ex: Hammer to wrench>nut>shaft>sprocket>into transmission> and who know where else. This is not good for the motor. A dead blow or brass absorbs the impact with out sacrificing the power of impact.
rockertom is offline
