front sprocket removal - Wrist Twisters
post #1 of 5 Old 11-29-2008, 11:13 PM Thread Starter
How do you get the front sprocket off? Is it reverse threaded?
I had the bike in 2nd gear and tried doing lefty loosey and it made the transmission turn while on the rear stand. I tried putting the rear tire down and it acted like it was going to turn the tire against the cement.
post #2 of 5 Old 11-30-2008, 06:56 AM
Put the bike in 1st gear and have someone step on the rear break while breaking loose the counter shaft bolt. They can be tuff!
Lefty = Loose
post #3 of 5 Old 11-30-2008, 07:14 AM
Like Mike said, put the front wheel against a wall and have someone step on the rear brake. If that doesn't work I usually put a 2x4 thru the wheel and let it lockup on the swingarm. Reverse it for tightening. I've got an air ratchet that I sometimes take it off with but I like using a torque wrench to put it back on.
post #4 of 5 Old 11-30-2008, 07:53 AM
it takes a little bit of what we call force.... MAKE SURE YOU USE A QUALITY TOOL... if you use the little cheapy sockets you get anywhere you may strip the head.... spend the money get a good craftsman socket or someother HIGH quality brand....
post #5 of 5 Old 11-30-2008, 08:50 AM
I have about a 24" long 1/2" breaker bar. I sat on the bike, right foot on the rear brake & loosened it with the breaker bar in my left hand. Same to install.
Bryce919er is offline
