front fork component replacements - Wrist Twisters
post #1 of 12 Old 05-09-2015, 03:46 PM Thread Starter
Hey guys. I managed to find a pair of fork seal kits and upper bushings. The parts guy was very friendly and knowledgeable, mentioned that I may or may not need the lower bushings and won't know until I tear into them and can look at them.
Anyone ever have to replace the lower bushings? I can either not get them and tear into them again if I need to at another time or I can drive an hour 1 way to another shop that has them on the shelf.
Thoughts?
post #2 of 12 Old 05-09-2015, 05:33 PM
notsowisecracker
Monkeywrench's Avatar
I just had mine apart a week ago to replace a seal that had leaked off and on again since I bought the bike.
I don't know how many miles you got on your bike Pvster, or how you tell if the bushing is worn.
I had approx. 12,000 on mine and just guessed it probably didn't need replaced.
The lower bushing just pops into a groove in the lower fork tube. Super simple on and off.
If you've got a bunch of miles, and the're cheap enough, i'd be really tempted to just replace them.
Monkeywrench is offline
post #3 of 12 Old 05-09-2015, 07:54 PM
if you are taking the forks apart to that point. Replace both bushings on the lower fork tube and upper. The bushings are cheap and super easy to replace while your there.
This is assuming we are talking about the 9er forks which only have 2 main bushings.
If we are talking about something like a dual chamber cartridge fork there is at least one or two more bushings in the inner cartridge.
post #4 of 12 Old 05-10-2015, 09:02 AM Thread Starter
Sadly I didn't make it to the other dealership in time. So I'll be tearing them apart again on another day. For now I will have to just hope the lower bushings are in decent enough shape to get me by.
post #5 of 12 Old 05-10-2015, 09:26 AM
more than likely it is so long as you had decent oil in the forks, those PTFE bushings last a long time.
post #6 of 12 Old 05-10-2015, 04:01 PM Thread Starter
Well, got hit with a bit of bad luck. Both bushings look decent, the important surface areas look good but there were some scoring on the inside of the bushings which puzzled me. As I worked through the first fork I didn't see much.
Cracking open the second fork immediately looked bad. The plastic rod guide was split completely in half. The fork seal had white corrosion on the inside of the seal and the lower seal/lock ring was completely caked in white corrosion. This warranted closer examination and saw that the top of the plastic rod housing was chipped which led me to looking at the first fork. My fears were confirmed, the plastic rod housing also had chipped pieces but worse, which leads me to think that contributed to the sudden and immediate failure.
Interestingly enough, the other fork had clear signs of dry rot going on, covered in the white corrosion, but had no leaks. Granted, it was just a matter of time.
So now I have to cage it tomorrow and hope I can source the plastic bits in addition to the lower bushings. I'm baffled as to what led to the deterioration of the plastic bits. Age, mileage? I know the forks have at least 35k miles that I put on it, no idea how many miles were on it before I got them.
post #7 of 12 Old 05-10-2015, 04:02 PM Thread Starter
Adding pictures.
post #8 of 12 Old 05-10-2015, 08:29 PM
Ah, that sucks dude. Downtime to fix broken stuff... .
post #9 of 12 Old 05-11-2015, 02:11 AM
Wouldn't the fracturing of plastic have to come from impact? I imagine enough small vibration could do it over a long enough time, but it seems to work more as a retainer/guide.
If you bought the bike used, it could have been from a front impact and/or a slight bend in the forks.
If you examine it, you might notice wear or being out of round.
Maybe even a slight out of round or bend in the forks could cause too much heat / friction which could have caused a stress crack.
It could also be the case that these same conditions caused water or something to get in there.
KarlJay is online now
post #10 of 12 Old 05-11-2015, 04:49 AM
Those kind of look like aftermarket spring guides (not sure of the proper name). They are used to help keep the springs from scraping against the insides of the fork tubes. If I'm right, and if all of the OEM parts are still there, you shouldn't even need them.
post #11 of 12 Old 05-11-2015, 12:27 PM Thread Starter
You are correct, they are spring guides. Got them from Racetech. I was disappointed in the sad shape they were in. I will be calling Racetech to see what the deal is.
post #12 of 12 Old 05-11-2015, 12:48 PM
I had thought about getting some when I did my f4i forks, but ended up not getting them. How long since you installed them? Agree that it's disappointing to see them fail like that.
