Found during a mod, loose header nuts - Wrist Twisters
post #1 of 9 Old 09-14-2009, 09:53 AM Thread Starter
oldguard60's Avatar
While trial fitting a 900rr header, I found two loose header nuts and a third one starting to be loose. It is an 05-919 had 2500 miles on it when I got it and about 5500 now. I have always heard a slight ticking noise when it was warming up, then it went away after it was completely warmed up.They were all on the two center cylinders.
I got the header from Ripper at a very good price, the shipping was more than the cost of the header. Thanks, Ripper. I found a wielding shop and they straightened the kink out of it. I test fitted it and found the loose header nuts. The header is back at the shop for a little adjustment. Then next step is to find a slip on that fits the header. The 900rr header is normally a bolt on exhust the collar was removed on the header where the can would bolt on.
If anyone has a used can inside diameter of about 60mm let me know. I am planning of making it into a gp style.....
oldguard60 is offline
post #2 of 9 Old 09-14-2009, 10:12 AM
3dcycle's Avatar
if your research 900rr headers here on the forum you will find some.
i have a sato gp can 60mm ID fits tight with or with out the flage in place.
3dcycle is offline
post #3 of 9 Old 09-14-2009, 10:18 AM
the Sato pipe is the one I'd go with... Good quality and the flow of that pipe is going to be in line with the custom mapping I had done.
Ripper is offline
post #4 of 9 Old 09-14-2009, 10:47 AM
Vehicle Abuse Specialist
WheelieTime's Avatar
I just cut off the flange on on angle so the pipe lets out right behind the right peg sounds great and I have no heat issues.
WheelieTime is offline
post #5 of 9 Old 09-14-2009, 12:34 PM Thread Starter
oldguard60's Avatar
PM sent to 3dcycle..
Funny, I thought there would be more interest in the loose header nuts.....
After this a pcIII mod.....
post #6 of 9 Old 09-14-2009, 01:55 PM
3dcycle's Avatar
https://wristtwisters.com/naked-bikes...aust-done.html
this is what mine looks like with detailed pictures
3dcycle is offline
post #7 of 9 Old 09-17-2009, 01:31 PM
and it looks like?
no pics above
post #8 of 9 Old 09-17-2009, 03:38 PM
Originally Posted by REDROKR View Post
and it looks like?
no pics above
Gotta click the linky
post #9 of 9 Old 09-17-2009, 03:39 PM
3dcycle's Avatar
oh yea sorry clicky the linky gots good pics in there.
3dcycle is offline
