Fork seals - Wrist Twisters
post #1 of 8 Old 05-10-2013, 05:59 AM Thread Starter
papabear's Avatar
Fork seals
Just after replacing fork seal on my Suzuki GS500e, reason they were replaced was one was leaking an had started drippin onto edge of tyre. Now after seals replaced the side that wasn't leaking before is now leaking worse than the previous side, in less than five miles run it's running down the fork really bad,
If anyone can suggest anything it be much appreciated
Thanks
papabear is offline
post #2 of 8 Old 05-10-2013, 06:12 AM
Hastatus Prior
TheBeeDeeGee's Avatar
What'd you use to drive the seal in?
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #3 of 8 Old 05-10-2013, 06:14 AM Thread Starter
papabear's Avatar
A waste pipe te drive seal in
papabear is offline
post #4 of 8 Old 05-10-2013, 08:32 AM
Were the tubes cleaned really good? Are they pitted at all? Might not be the seals fault.
post #5 of 8 Old 05-10-2013, 04:40 PM
Total Awards: 17
Have you practiced safe insertion? Was it lubed nicely? If not, you shaved your seals on sharp edges of fork tubes while sliding them on
Attachment 25537
Attachment 25538
Attachment 25539
zaq123 is offline
post #6 of 8 Old 05-10-2013, 05:06 PM
Attachment 25537
Attachment 25538
Attachment 25539
Hilarious.
Most excellent.
post #7 of 8 Old 05-13-2013, 05:53 AM Thread Starter
papabear's Avatar
Tubes are slightly pitted but naw much, were lightly sanded with very light sand paper and put back together, with the same result
papabear is offline
post #8 of 8 Old 05-13-2013, 09:15 AM
It doesn't take much - those tubes have to be super smooth. You could send them off to have them recoated, or find another used set and rebuild your forks again.
