Flooded engine rant - Wrist Twisters
post #1 of 9 Old 08-20-2012, 09:44 AM Thread Starter
carotman's Avatar
Flooded engine rant
When I started the bike this morning, it fired right up as usual but died the instant I released the starter.
When I tried to restart it, it had no compression. Bam, the engine was flooded.
I cranked the throttle to the max and just held the starter button. It finally came alive after a loud pop in the exhaust . The engine ran fine afterwards.
I guess it's time to check the FPR and air filter.
carotman is offline
post #2 of 9 Old 08-20-2012, 12:36 PM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Don't dismiss the battery as a possible issue. I just went through the same scenario on my '03(62K) with the original battery that is always tendered. A new battery alleviated the situation.
Doc
ST-DocLizard1 is offline
post #3 of 9 Old 08-20-2012, 02:13 PM
if it had "no compression" you have serious issues... but i doubt its that.
more than likely a dead or almost dead battery, pc3, or a cold cold morning doing it to you... there is a "choke" knob on the left hand side of the motor... pull it out to get the bike running, on a cold morning.
post #4 of 9 Old 08-20-2012, 03:12 PM
Crotchety Rocket
cmelnick's Avatar
Donation Extraordinary Ride
I've had the same thing happen when it gets cold, just gotta choke or let warm up for a minute. The first time it happened, it waited until I was out the garage and a couple hundred feet down the street, and kind of idling up to a stop sign. As soon as I backed off the throttle, the RPM just dropped, kept dropping past the idle, and just died.
- Stephen Hawking
cmelnick is offline
post #5 of 9 Old 08-20-2012, 04:54 PM
Lightbulb
Doc
Im impressed with the life of your battery 9 years has got to be the record.
post #6 of 9 Old 08-20-2012, 05:13 PM
Serial Monogamist
Total Awards: 21
I don't know about a record, but I am completely satisfied and went with another Yuasa. My '04 ST1300A is probably next on the list with an in service date of 8/04 and 41K on the clock. We shall see.
Doc
post #7 of 9 Old 08-20-2012, 08:04 PM
if it had "no compression"...
....and then went on to run fine later, this is a mechanical miracle!!
K1w1Boy is offline
post #8 of 9 Old 08-20-2012, 09:41 PM Thread Starter
carotman's Avatar
It had no compression because the cylinder walls are washed by the unburned gas. The engine did crank like it had no compression at all.
The battery could be the culprit. I had the gauges reset a few times when I first started it in the morning.
carotman is offline
post #9 of 9 Old 08-21-2012, 02:26 AM
never herd that one before
secondchance is offline
