Engine mount torque specs? - Wrist Twisters
post #1 of 4 Old 02-16-2019, 01:58 PM Thread Starter
Hey, does anybody know the engine mount torque? Doesn't seem to be in the service manual...chasing a horrible vibration sound on engine braking and want to rule out loose engine mounts
Cheers
Troy Schumaker is offline
post #2 of 4 Old 02-16-2019, 05:37 PM
Cheers
It's all in Section 7 in tabled and pictorial formats.
Factory Service Manual that is.
While you are at it, suggest you also check the swing arm bushing torque.
Assume you are aware that to check, you have to back off and retorque.
There is no other way to check torque of tightened fasteners. (aside from so called thread stretch based measurements of change in length)
And that all the stated values are for dry (no lube!) and clean threads in good condition.
post #3 of 4 Old 02-18-2019, 09:48 AM Thread Starter
Downloaded a different manual and there it was in section 7..all 50nm, I'll give the swing arm a go over as well thanks!
post #4 of 4 Old 02-18-2019, 11:50 AM
Check you exhaust hanger mount/bolt underneath as well. My bolt come loose and my footpeg vibrated. The mount has been known to break too.
I had a weird vibration coming from my headlight bucket/rim assembly at certain revs.
