Engine burning oil - Wrist Twisters
post #1 of 14 Old 02-17-2012, 09:12 PM Thread Starter
Hastatus Prior
TheBeeDeeGee's Avatar
Engine burning oil
I was wondering if it was normal for the 919 to burn a little bit of oil. In about 3k miles the oil level went from filling the entire sight glass, to just below the top line. This is my first experience with a vehicle that uses the same oil in the transmission and engine, so maybe this is a completely normal but I thought I'd ask.
Don't want to turn this into an oil thread but I changed it last with the Honda GN4 stuff, dunno what the previous owner used be he said he never did any of the work himself so I'm guessing it was the same if a Honda dealer did it.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #2 of 14 Old 02-17-2012, 09:35 PM
Did you check the fill level after running the engine? The filter soaks a bit of oil when the oil is circulated. Just a thought
Mine uses less than half a quart, if that, between OCIs (5k miles). Some have reported no drops in oil level between changes.
post #3 of 14 Old 02-17-2012, 10:02 PM
I've got one of the no-fill between changes bikes, but it might relate to the fact that I don't bump it off the rev limiter all the time. By which I mean, it gets a pretty easy life with me..
K1w1Boy is offline
post #4 of 14 Old 02-17-2012, 10:05 PM
And BTW.... you're not suppose to fill the sight glass. You invite the engine to consume oil by doing that. Keep her between the upper line and the halfway mark when you fill and see if you still get a drop in level.
post #5 of 14 Old 02-17-2012, 10:23 PM
Shreddin Rubber's Avatar
Some oils burn off a bit quicker than others,it may burn off quickly,then level off. Never run with too much oil.
If it's concerning you then top it up,with help if it's a sight glass type. Get it perfect,then keep a vigil,checking every 100 miles or so. If it doesn't taper off after 1000 miles take it in.
If you want to,check the plugs for oil fouling,or a shiny black coating of fresh wet oil. That could indicate a valve seal failing.
Have someone start it when the engine is cold,after sitting over night while you stand behind it watching the exhaust The black puff of smoke at start up is a tell tale sign of worn rings.
Now I have seen some low mile Harleys(5000 miles) vaporize a quart of oil in a 3000 mile oil change interval. The dealer called it normal. Sure,normal for that crap factory fill syn 3. A top quality synth like red-line or amsoil doesn't experience this kind of issue. You shared sump guys would benefit from a very stout thick 5w-40 like rotella.
Or it could be you just got a bad batch of oil. Top up,monitor it closely,if it remains excessive take it in.
Good luck. I hope it's something simple,like a loose oil pan bolt.
Shreddin Rubber is offline
post #6 of 14 Old 02-17-2012, 10:28 PM
IMO you may have had it slightly over fill. Mine does not use any oil between changes (5-6000 kms) and I fill it by measuring the correct amount which leaves the oil level just under the top line in the sight glass. Any over that is too much and I suspect your motor is just sorting out it's correct level.
I'd not be concerned unless it starts to consume oil making the visible level lower than half way between the two lines. Measured when the oil is warm and the bike level on both wheels (not on a race stand - this gives a false reading).
post #7 of 14 Old 02-17-2012, 11:01 PM
This sounds like the best advise so far. Keep an eye on it. If it's a bigger issue I'm sure it will present itself.
post #8 of 14 Old 02-18-2012, 05:05 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Did you "pre-load" the filter before you screwed it on? I usually fill the filter up twice to the top and let it soak up some fresh oil before I screw it in place.
Just a thought.
Doc
ST-DocLizard1 is offline
post #9 of 14 Old 02-18-2012, 06:35 AM
If your sight glass is completely covered with oil you have overfilled it. An oil and filter change requires 3.8 quarts and will put the level to the top line in the sight glass.
post #10 of 14 Old 02-18-2012, 08:09 AM Thread Starter
Hastatus Prior
Thanks for the responses guys. I did over fill the engine slightly at the last change, I even drained some out before running it and got it to where the glass was almost completely filled (still past the top line, but I gave up)
see below
https://www.wristtwisters.com/forums/...oil-28492.html
Something I didn't think about until just now, and I'm embarrassed to admit, is it is may have been because I had just ran the bike, I didn't think about it until I read the responses, and I can't remember if I checked it before I went for a ride or after I'm gonna check it again today after the bike has sat all night,
next oil change, which is coming up in 1k miles, I'm gonna use a measuring cup and get the right amount in there.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #11 of 14 Old 02-18-2012, 08:34 AM
Just drain 6 ounces out of one quart and dump it in. Most of the containers are graduated these days, makes life much easier.
post #12 of 14 Old 02-18-2012, 09:12 AM
you also have to take into consideration the small amount of oil consumed by the crank case breather in the form of oil vapor.
that being said, the "oil burning" you describe is nothing to worry about, like others state probably either 1 not exactly the same level of the bike, or 2. slightly overfilled and just using some to get back to its proper state.
That being said... i just dump a gallon of rotella t in her when i do an oil change and fogeddaboutit! .2 gt aint gonna hurt nothin.
post #13 of 14 Old 02-18-2012, 03:24 PM
Gallon and extended filter gets you between the halfway and upper line every time. Mobil 1 M110, Bosch 3323, Purolator 16410 to name a few.
post #14 of 14 Old 02-19-2012, 07:57 AM
Rich Jura's Avatar
What he said
Rich
Rich Jura is offline
