Electrical problem AKA: I screwed up - Wrist Twisters
post #1 of 16 Old 04-17-2014, 05:52 AM Thread Starter
Hello all,
New member here, but have come to this site for many years to read the threads.
My Problem: I mistakenly crossed the cables when jumpstarting my 2002 Honda Hornet 919 with a battery charger(please stop laughing). The charger has a jump-start switch which sends out 50 amps. I did hear a "click" near the front of the seat/rear of the gas tank. I replaced the battery and have no power at all. I checked the fuses and they seem fine.
I know just enough about electrical issues to get myself in trouble, so I did not go any further after checking the fuses.
Any help would be appreciated. And yes I am expecting some pleasant jokes sent my way.
Tiny
tiny is offline
post #2 of 16 Old 04-17-2014, 07:08 AM
Todi's Avatar
Originally Posted by tiny View Post
Hello all,
Tiny
I did the same when I bought my bike two years ago and I burned the 30A fuse. It's on the side of the fuse panel, by itself, if i remember
Todi is offline
post #3 of 16 Old 04-17-2014, 07:09 AM
Semper Vigilo
2007BruteForece's Avatar
Been there done that.
Have you checked the main fuse? When you turn the key on does the fuel pump prime?
Main fuse is located closer to the battery than the fuse block with the smaller fuses, IIRC.
Edit: What Todi said
2007BruteForece is offline
post #4 of 16 Old 04-17-2014, 08:42 AM
Use a meter to check the fuses. Sometimes they look fine but are blown
post #5 of 16 Old 04-17-2014, 09:42 AM
+1 to what everyone has said. Be sure to check the main fuse first.
post #6 of 16 Old 04-17-2014, 09:53 AM
Yup. blown fuse.
post #7 of 16 Old 04-17-2014, 10:48 AM Thread Starter
Thanks for the replies guys. I did check all the fuses, and what I believe is the main fuse(30amp) They all look fine, but I think I will replace them all and see what happens.
tiny is offline
post #8 of 16 Old 04-17-2014, 10:49 AM Thread Starter
...Also when I turn the key on I get absolutely nothing - no fuel pump, no odometer, nothing.
tiny is offline
post #9 of 16 Old 04-17-2014, 10:57 AM
Do you have a multimeter? If not, they are fairly cheap and you can use that to check the resistance in each fuse (starting with the main fuse). The resistance should be almost 0 ohms. If you read a high resistance reading, or no reading at all, the fuse is blown and needs to be replaced.
post #10 of 16 Old 04-17-2014, 01:15 PM Thread Starter
Well I went to the auto parts store and bought replacement fuses and a multi meter. I had a couple of the fuses tested and the guy there did say that the 30amp fuse is dead - even though it looks fine. That brightened my outlook, but when I got home and tried 3 different 30 amp fuses nothing, no power.
tiny is offline
post #11 of 16 Old 04-17-2014, 02:01 PM Thread Starter
There is a red "Coupler" next to the 30 amp fuse I replaced, which I unhooked. Low and behold there was another 30 amp fuse below that coupler. Apparently the 1st 30 amp fuse I replaced was the spare. The 30 amp fuse below the coupling was blown and has been replaced and the bike lit up like a christmas tree! The bike fired right up! Thank you guys who responded to my post!
You guys saved me the hassle of taking my bike to the shop and spending who knows how much to have them replace a fuse.
Awesome.
I am glad to be a part of wristtwisters
tiny is offline
post #12 of 16 Old 04-17-2014, 02:02 PM
post #13 of 16 Old 04-17-2014, 02:08 PM
Well, glad you got it fixed. I will laugh now as I picture you replacing the spare fuse and scratching your head thinking... huh... The guys over at WT said this should fix it...
post #14 of 16 Old 04-17-2014, 02:10 PM
I love quick and easy fixes!
post #15 of 16 Old 04-17-2014, 02:18 PM
Todi's Avatar
HAHAHAHAAAAA!!!!! I NOT the only one that replaced..... THE SPARE
Todi is offline
post #16 of 16 Old 04-18-2014, 10:59 AM Thread Starter
Thanks a bunch!!
Anytime any of you are near Livonia Michigan I will buy you a beer!!!
tiny is offline
