electrical problem 919 - Wrist Twisters
post #1 of 9 Old 01-01-2009, 03:28 AM Thread Starter
dml
HI i have a 04 919 and did something stupid.
I put the battery terminals on the wrong way(-on+, +on-) and now my bike has no power and is acting like there is no battery in..So any help or ideas would be great. Cheers Dave
dml is offline
post #2 of 9 Old 01-01-2009, 03:29 AM Thread Starter
dml
Also does any one have any idea where i can get a pdf manual from?
dml is offline
post #3 of 9 Old 01-01-2009, 07:41 AM
there was one posted on here not long back... try the search feature
post #4 of 9 Old 01-01-2009, 07:54 AM
With a little bit of luck the 30A main fuse did its job. Test/Replace it. Located under the seat.
post #5 of 9 Old 01-01-2009, 08:39 AM
Welcome, DML!
The 30 amp main fuse is located on the top of the starter relay about 4" ahead of the fuse box. The 4 pin connector has to be removed from the relay to expose the fuse.
Fortunately the only electronics connected directly to the battery are the voltage regulator, with diodes rated to withstand over 100 amps (roughly three times the fuse rating), and the memory circuit for the odometer / trip meter in the instrument cluster. Honda planned for this error and diode protected this circuit. This is assuming the key was not on when the battery was connected. If it was, well, good luck!
By the way, the fuse noted in Mr. Mike's post is the spare. Nice of them to put it there.
post #6 of 9 Old 01-01-2009, 09:09 AM
Rob: Thanks for clarifying the fuse location. I did not want to stay out in the garage long enough to remove the connector. It is not heated and the temperature is 6 degrees outside. Brrrr...
post #7 of 9 Old 01-01-2009, 09:27 AM
3dcycle's Avatar
wow a whole six above. you luck [email protected] below 0 fer me
3dcycle is offline
post #8 of 9 Old 01-01-2009, 11:31 PM Thread Starter
dml
thanks rob and mike for the help. You were spot on with it being the fuse. I haven't had any luck with finding a manual I sent MotoCycho a pm hopefully he can re-post it. Cheers Dave
dml is offline
post #9 of 9 Old 01-02-2009, 05:45 AM
I tried using the PDF manual for a bit but ended up getting a real one from eBay. With shipping it was under $20. I have the PDF of the Owner's Manual and Shop Manual on my Flash Drive, but it's too large to email. They are nice to have at the office for quick reference, but not as good at the house. Maybe it's because I'm a computer guy who doesn't like using the keyboard with grease all over my hands and don't like washing up 5 times, or wasting my paper.
