ECM QUESTION - Wrist Twisters
post #1 of 5 Old 07-12-2011, 05:06 AM Thread Starter
Brute919's Avatar
ECM QUESTION
I recently put a f4i guage cluster on my 919 . I have got everything to work except the tachometer. I checked the fuses and connections. The service manual says the ecm needs replacing. I dont know how could be since the bike runs fine. Doesnt that control everything.
Brute919 is offline
post #2 of 5 Old 07-12-2011, 06:00 AM
Tried attaching the old ones to see if the signal is still good?
post #3 of 5 Old 07-12-2011, 06:42 AM Thread Starter
Brute919's Avatar
Unhappy
Yes i connected the stock guages back up everything works there but the tach also.
Brute919 is offline
post #4 of 5 Old 07-15-2011, 03:56 PM
snowytgr1's Avatar
you can check the voltage output on the tach signal wire it should be 10.5v minimum anything less and that circuit from the ecu is bad. If you did not short the tach signal wire the ecu should still be good.
snowytgr1 is offline
post #5 of 5 Old 07-16-2011, 05:44 AM Thread Starter
Brute919's Avatar
Unhappy
I checked the tach signal wire with a multimeter it only had 1.59 volts
Brute919 is offline
