eBay Chain Tool Verification - Wrist Twisters
post #1 of 40 Old 02-18-2013, 08:45 PM Thread Starter
An English Teacher
thumper's Avatar
Motorcycle Chain Repair Break Tool Riveter Rivet | eBay
I need a chain on my new 919 soon. Since I don't have a chain tool and heard good things about the D.I.D./eBay clone tool, I figured I would have a look. Did I find it? Is this the tool for around $50 that everybody's talking about?
Also, do you know of any cheaper, equally reliable models?
Thanks gang.
Corey B.
2003 Honda 919: orange.
thumper is offline
post #2 of 40 Old 02-18-2013, 08:49 PM
Toll Runner
str8ghtjacket's Avatar
Uh Ive put over 20k on a 9er's and never had to have one of those. Save the money for mods. Buy a chain from LDH and be done with it. Its all about maintenance.
Edit. Try a kerosene bath and a good cleaning with the chain on the bike, dont over do it. Good luck Bro
str8ghtjacket is offline
post #3 of 40 Old 02-18-2013, 09:16 PM
Ive used a Motion Pro breaker/riveter tool and had great luck with it...it has a very different design from this one.
post #4 of 40 Old 02-18-2013, 09:54 PM
even if you buy a chain from LDH you still will need a rivet tool.
I am going to expierement with a steel bb and a C clamp here in the coming weeks on a chain on my CRF250X ... i figured if the ghetto ball peened master link has lasted this long anything else will be better... that stated the 250X has a LOT less power than the 9er.
post #5 of 40 Old 02-19-2013, 12:39 AM
If you get an EK chain, you can go with their screw type master link. It's got good reviews and all you need to install is an 8mm wrench.
Scroll halfway down to check it out
http://www.ekchain.jp/feature/index.html
post #6 of 40 Old 02-19-2013, 04:27 AM
EK MOTORCYCLE CHAINS | Enuma Chain Mfg. Co., Ltd.
Interesting. I never saw the screw type.
post #7 of 40 Old 02-19-2013, 05:07 AM Thread Starter
An English Teacher
thumper's Avatar
That is interesting. Any other reviews opinions of this chain?
Corey B.
thumper is offline
post #8 of 40 Old 02-19-2013, 07:09 AM
itskoopa's Avatar
I bought the tool kit off ebay. It was like 50 bucks and came in a red box. It works great. Just make sure you use some sort of grinder first to grind the rivet down. I broke the spare pin trying without grinding. Dremels work as do drill attachment grinders.
itskoopa is offline
post #9 of 40 Old 02-19-2013, 07:12 AM
"CERTIFIABLE"
Ken Phenix's Avatar
Thanks gang.
I have never used one like that. I wonder if it uses the same rod to press out the old pin and spread the new rivet.
I bought this one 7 years ago and after doing several (I mean a lot) of master links for myself, my buddies (free beer) and my son and his buddies the rod finally broke - but it still works. I have more than gotten my money's worth. Unless you're thinking of giving up riding someday a good chain tool is always a good investment.
Motorcycle ATV Chain Cutter Breaker Riveting Rivet Tool Sizes 428 520 530 | eBay
As far as the screw type link goes, you'll just have to weigh the cost of the links over several years vs buying the tool - give or take free beer from your buddies who don't have a tool.
You can get away with stuff on a 250 but a high torque liter bike can be less forgiving. A good friend of mine put a cheap chain on his DL1000 and when it broke, it wrapped around the countershaft . . . . . . . .
. . . . . he had to order a new engine case. $$$
So I would put nothing less than a 10,000# tensile strength chain on a 919 and use a real rivet type link - but that's me.
BTW: I quit drinking beer and switched to highland single malt. My buddies don't come around so much any more.
Ken Phenix is offline
post #10 of 40 Old 02-19-2013, 07:12 AM
itskoopa's Avatar
I also bought a chain sprocket kit off ebay for 99 bucks. Magnum oring chain and jtsprocket sprockets. 2000 hard miles and no problems.
itskoopa is offline
post #11 of 40 Old 02-19-2013, 07:22 AM
itskoopa's Avatar
itskoopa is offline
post #12 of 40 Old 02-19-2013, 08:23 AM
Hastatus Prior
TheBeeDeeGee's Avatar
Stockton kit worked very well for me.
I tried the BB and clamp method, but couldn't get it to work. I finally broke down and spent the money on the tool.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #13 of 40 Old 02-19-2013, 08:27 AM
Brain stolen again?
Thanks gang.
I'm not talking about it...........
Mathew Quigley
post #14 of 40 Old 02-19-2013, 11:09 AM
Not on this forum but do a Google and you'll see reviews.
post #15 of 40 Old 02-19-2013, 12:21 PM
DID chain always.... im sorry but the rest just do not compare.
as far as riveting my chain... ill probably hit my buddy up for his tool.
post #16 of 40 Old 02-19-2013, 12:29 PM
Tirone shoelaces
TexasTraffic's Avatar
Yes. A couple years ago I bought one of these clone DID chain tools.
The U-shaped piece did not fit correctly and would flex under load until one side slipped out. I was able to - WITH DIFFICULTY - get one chain broken and riveted.
Then I asked for a replacement that had better quality control. No Joy!
I got a refund and now have an El-Cheapo Cycle Gear chain tool. It works
Thoughts -
If the U-shaped piece had more & better contact with the main body and did not flex and disengage, then this would be a great tool. You can easily generate HUGE force to push pins & break the chain, and to set rivets. I guess that's why the name-brand D.I.D. tool is so darned expensive.
It looks like these clones are QA rejects from the D.I.D. factory in China.
As seen on E-Bay:
The tool I had:
Under load - note the far "ear" coming out of its slot
CB550-Four; CB750F; VF1000F
750 Nighthawk; CB900F; CBR1000rr
TexasTraffic is offline
post #17 of 40 Old 02-19-2013, 12:46 PM
Yikes. A C-Clamp on that sucker would allow you to keep using it, I bet. Although, best to just get a proper tool.
I bought a Tusk kit that works good. Probably a re-named knock off, but I've had no problems in the 5-6 chains I've done. The key is to grind off the old pin before pressing.
post #18 of 40 Old 02-19-2013, 01:10 PM
this is why you have to grind off the rivet to break the chain otherwise even high quality tools will break. it will make your life MUCH easier if you do so.
Texas wanna sell that tool.... ill buy it off you if its not broken.
post #19 of 40 Old 02-19-2013, 02:05 PM
TWHS
post #20 of 40 Old 02-19-2013, 02:15 PM
TWHS
its so cal man... we are always hitting eachother up for eachothers tools.
post #21 of 40 Old 02-19-2013, 02:43 PM
I've never changed chain/sprockets before, something I let the pros do. Does taking the chain off really have to be so proper? What about some bolt cutters?
post #22 of 40 Old 02-19-2013, 02:44 PM
Tirone shoelaces
It took more than a C-clamp to get the chain riveted.
The ears on the main part of the tool took some bending in (via 4-lb sledge) to finish the job, and even then it was still not working right.
post #23 of 40 Old 02-19-2013, 02:49 PM
Tirone shoelaces
I did grind the head of the rivet off before trying to press the pin out. That wasn't the main problem.
Pressing the plate on went OK.
Setting the rivet was the biggest b!tch -w- that tool. The tool would pop apart before the rivet was properly expanded. The two images with the tool on the chain show it ready to come apart while setting the rivet on the new chain.
No, I do not have it anymore. I returned it for a refund.
post #24 of 40 Old 02-19-2013, 03:20 PM
^^ I meant putting a c-clamp on the tool itself, not the chain. To keep those jaws from spreading apart and the tool from coming apart.
post #25 of 40 Old 02-19-2013, 06:04 PM
Brain stolen again?
Well, if ya got a circle of friends, why not.
I myself do not like to lend them out unless I am there.
That way I can try to keep them from fucking it up, but if they do, I can hit them with it after they break it, over and over and over again.
Then, they buy me a knew one.
Mathew Quigley
post #26 of 40 Old 02-19-2013, 07:43 PM Thread Starter
An English Teacher
thumper's Avatar
So to verify, this product is an effective one?
Universal Motorcycle Cam Chain Cutter Breaker Riveting Rivet Tool 428 520 530 | eBay
Corey B.
thumper is offline
post #27 of 40 Old 02-19-2013, 07:50 PM Thread Starter
An English Teacher
thumper's Avatar
....or, I found these, too, via the recommendations in this thread:
Heavy Duty Chain Breaker
Motion Pro Chain Press Tool - Dirt Bike Motocross - Motorcycle Superstore
Which would you choose? These two together or the eBay tool in my previous post?
Corey B.
thumper is offline
post #28 of 40 Old 02-19-2013, 10:36 PM
itskoopa's Avatar
The universal one in the red box is what i used twice. Still have it. Grind down the rivets and pick the right pin. Works just fine for me. I watched some youtube vids til i felt comfortable with what i was doing.
itskoopa is offline
post #29 of 40 Old 02-19-2013, 11:02 PM
Same here, I have the ebay one. It works fine so far. Have used it on a couple 530's and 3 or 4 520's.
post #30 of 40 Old 02-20-2013, 05:04 AM Thread Starter
An English Teacher
thumper's Avatar
So the EBay kit sets the side plate and peens the new rivets, too, right?
Corey B.
thumper is offline
post #31 of 40 Old 02-20-2013, 05:30 AM
"CERTIFIABLE"
Ken Phenix's Avatar
The master link side plate installation spacers included with EK brand chains make it easy.
I have also learned to use the rear sprocket as my "work bench" by zip-tying the chain ends to it with the extra links hanging out. Then I grind the pin to remove the extra links with no chance of cutting the new chain too short. Working on the rear sprocket makes cranking down on the chain tool much easier.
That other tool could not be used over the sprocket.
post #32 of 40 Old 02-20-2013, 08:38 AM
^^ +1. I've used that eBay tool just like Ken has. Works great.
post #33 of 40 Old 02-20-2013, 08:52 AM Thread Starter
An English Teacher
thumper's Avatar
Ken, so the tool pictured is the eBay tool?
Corey B.
thumper is offline
post #34 of 40 Old 02-20-2013, 10:57 AM
itskoopa's Avatar
The universal one in the red box. That you referenced. It will push the plate on and push down the rivets as well.
itskoopa is offline
post #35 of 40 Old 02-20-2013, 10:58 AM
itskoopa's Avatar
The one in the pic^^
itskoopa is offline
post #36 of 40 Old 02-20-2013, 01:09 PM Thread Starter
An English Teacher
thumper's Avatar
I see the light. Sorry for being thick.
Thanks, all, for the help.
Corey B.
thumper is offline
post #37 of 40 Old 02-21-2013, 08:24 AM
can that "universal" one on ebay set the rivets?
post #38 of 40 Old 02-21-2013, 08:37 AM
Yup.
post #39 of 40 Old 02-21-2013, 02:44 PM Thread Starter
An English Teacher
thumper's Avatar
eBay kit in transit. Thanks again, dudes.
Corey B.
thumper is offline
post #40 of 40 Old 02-21-2013, 04:10 PM
do you have a picture of what the rivet setting pin looks like? I got a nice chain breaker that i use all the time to break chains, but im wondering if it can also be used to set the rivet.
Doing a lil research this tool ... all for 11.99
http://www.harborfreight.com/heavy-d...ker-66488.html
Comes with two tips and with just the use of the extra tip you can rivet it.
Oh and look at that i just got a 20% off coupon in the mail for HF. winning
http://www.youtube.com/watch?v=qd83Y_hjbEU
