Dust seals - Wrist Twisters
 4Likes
  • 3 Post By robtharalson
  • 1 Post By Islandboy
post #1 of 25 Old 06-02-2012, 11:05 PM Thread Starter
Dust seals
Hey everyone, I sold my 02 forks to PDX_Luda in an effort to try and help him out. Unbeknownst to both of us, one of the forks left a wet spot when compressed after the deal was said and done. I know the forks worked great when I swapped them out for the F4i forks and the stockers were stored for over a year.
My question is: could the dust seal have gone bad from lack of use? Is it the dust seal itself that needs to be replaced? Is it possible to clean out the seal to see if something is letting the oil past the seal? is it possible the oil is bad and has turned to crap which in effect is able to seep past the dust seal? What about the other fork?
If the dust seal itself needs to be replaced, is it worthwhile to just replace the seal itself or is a full rebuild needed? PDX_Luda bought my forks in an attempt to avoid having to rebuild his. if its just the dust seal then I'd like to cover the dust seal and get it installed so he doesn't have to rebuild his forks.
The other option of course that I offered him was a full refund and he rebuild his forks which defeats the purpose in the first place
any thoughts or comments?
post #2 of 25 Old 06-02-2012, 11:13 PM
pdx_luda's Avatar
PDX_Luda bought my forks in an attempt to avoid having to rebuild his...
Sorta...
Locally was $135 (seals, fluid and labor) vs. $100 for a used set... would have saved a cpl $ towards either an adjustable set (04+ or F4i) or the inverted upgrade.
I guess my real concern is if I can hand compress them, what will happen when I go from 100mph to nothing, blown (leaky) is blown I'm thinking.
2002 cb919
- pretty much stock... <-- haha
pdx_luda is offline
post #3 of 25 Old 06-02-2012, 11:32 PM Thread Starter
Ah crap, guess I misunderstood you on the pricing. Thought it was $135 per fork and had to be rebuilt due to riding with the seals blown for so long there were internal damage. If its $135 for both, then its a no brainer for me. I'll just not take the $$ and that way you can get your forks rebuilt.
Sorry dude, I tried to help. We'll figure out how to get the forks back and what not. Looks like that settles it, which is a bummer since it was a waste of time for the both of us At least we got to finally meet and what not. Keep me posted and we'll get it all figured out.
post #4 of 25 Old 06-03-2012, 01:47 AM
pdx_luda's Avatar
No worries man, I did/do appreciate it!
pdx_luda is offline
post #5 of 25 Old 06-03-2012, 06:31 AM
Too bad it didn't work out, but big props to PV for making things right. I heard a trick on another forum was to wrap a piece of 35mm film round the fork and slip it under the seal. That may clean of any debris that may be preventing a good seal.
post #6 of 25 Old 06-03-2012, 06:42 AM
"SEAL MATE" it's a fork seal cleaning tool. A co-worker made one out of the flat side of a plastic orange juice container. Worked like a charm1!
Seal Mate the Tool that Fixes Leaking Fork Seals - YouTube
post #7 of 25 Old 06-03-2012, 06:48 AM
Very slick. I like the hook part of it to pull the dirt out.
post #8 of 25 Old 06-03-2012, 11:15 AM Thread Starter
that's great helimech! i'll have to see if i can find that thing.
thanks marylandmike! that's also a great idea!
post #9 of 25 Old 06-03-2012, 11:24 AM
pdx_luda's Avatar
Yupper's... def added to my task list for 2day!
pdx_luda is offline
post #10 of 25 Old 06-03-2012, 12:04 PM
Just make one. This thread has a printable pdf, just print/trace/cut and enjoy!
http://www.goldwingfacts.com/forums/forum1/119728.html
Although u gotta join a goldwing forum to get it. =p
post #11 of 25 Old 06-03-2012, 12:21 PM
pdx_luda's Avatar
Homemade Sealmate - fork seal repair tool - Goldwing Technical Forum - Forums - Steve Saunders Goldwing Forums
"print screen" feature plus several cut/pastes from word to PP gave me a real life template I just made!
BELIEVE IT or not, that did the fuckin' trick! Leak appears to have vanished!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pdx_luda is offline
post #12 of 25 Old 06-03-2012, 01:04 PM
Happy endings FTW!
post #13 of 25 Old 06-03-2012, 01:24 PM Thread Starter
thats awesome luda! post up the file of the "real life template"!
post #14 of 25 Old 06-03-2012, 01:36 PM
NICE!! That's a cheap and easy win, helps offset the busted head stud at least.
post #15 of 25 Old 06-03-2012, 02:09 PM
pdx_luda's Avatar
Will do, later though... still got a big fish 2 fry!
pdx_luda is offline
post #16 of 25 Old 06-03-2012, 05:18 PM
pdx_luda's Avatar
DIY Seal cleaner (full size - print, xfer, and cut)
Bout the only non-obvious thing was that I used a kitty litter container outta the neighbors trash... slimmed the thickness down a ways using the side of a fine bench grinder wheel.
It work's for sure, 1st hand knowledge.
http://www.filehosting.org/file/deta...al_cleaner.pdf
pdx_luda is offline
post #17 of 25 Old 06-03-2012, 05:36 PM
Excellent. Love it when a plan comes together.
post #18 of 25 Old 06-03-2012, 07:05 PM Thread Starter
filehosting.org - download page for DIY_Seal_cleaner.pdf
that's awesome! great work Luda this needs to get put into the dropbox asap!
post #19 of 25 Old 06-03-2012, 09:05 PM
TEXAN
MF1VE's Avatar
Yeah no doubt. This probably would have saved me from having to install seals on my dirtbikes at least once or twice back in the day.
MF1VE is offline
post #20 of 25 Old 06-04-2012, 04:22 AM
Added a link to this thread in the https://www.wristtwisters.com/forums/...ners-1209.html thread.
post #21 of 25 Old 06-05-2012, 03:55 PM
While you're at it MM, put up the link to the downloadable content for Dropbox on there, too:
https://www.dropbox.com/sh/rb2wzm4lnxmbdon/qIOpO0i9Sh
"https://www.dropbox.com/sh/rb2wzm4lnxmbdon/qIOpO0i9Sh"
This doesn't provide write access, just read only. So everyone can at least download the content, but can't delete it.
post #22 of 25 Old 06-05-2012, 05:59 PM
Done. Called it Goog13it's Drop Box.
post #23 of 25 Old 06-05-2012, 06:11 PM
yay! I'm famous .
post #24 of 25 Old 08-28-2017, 09:58 PM
My right fork started leaking last week, and in preference to tearing them down (never do just one) I tried the cleaning procedure outlined above using a piece of soda bottle shaped appropriately without expecting it to work. This is one case where I was glad to be wrong! It worked like a charm and only took about 10 minutes.
My advice is to try this before spending a bundle having the seals replaced at a dealership or doing it yourself.
post #25 of 25 Old 12-10-2017, 09:43 AM
Add me to the list of people this has worked for. I didn't think it would work. A couple of months ago I rebuilt my forks. New seals. Almost immediately I noticed the left fork tube was "wet" after every ride. Sort of got worse over time with some drops of oil now running off dust seal. Thinking I was going to have to tear fork down, I gave this method a go. I used a drink bottle. Cleaned the seal. No more leaks. Thanks wrist twisters.
badmoon692008 likes this.
