Does this mean I can run 112 links? - Wrist Twisters
post #1 of 24 Old 03-13-2012, 07:32 AM Thread Starter
Hastatus Prior
TheBeeDeeGee's Avatar
Will I be able to get it to correct slack
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #2 of 24 Old 03-13-2012, 08:05 AM
Love my BIG BOY Toys!
BBB2's Avatar
Based on the slack from the Honda service manual? No, that is written for a 114 link chain. At least mine is. It seems there is info that Honda,under warranty, installed 112 link chains or removed 2 links on a 114 chain for 02 models. If I were you, I would call and talk to my local dealer. Explain the situation and ask them if they have any recall or warranty info on 02 models and 112 link chains.
1999 Honda Valkyrie Interstate
2011 Kawasaki Vulcan Vaquero*
2004 Honda 919 *
2002 Honda VTX 1800C*
* SOLD *
BBB2 is offline
post #3 of 24 Old 03-13-2012, 08:20 AM
dr1
dr1
dr1's Avatar
Hold on, let me use my psychic powers to see what your seeing. Could you please grab the tape measure....
In other words, I dont know, does it have enough slack? :P
dr1 is offline
post #4 of 24 Old 03-13-2012, 08:42 AM
Total Awards: 17
Didn't you already put ML and it's all done now? (other thread). No patience. I was going to look for 530 links tonigh for you. I guess it's no longer needed?
zaq123 is offline
post #5 of 24 Old 03-13-2012, 08:53 AM Thread Starter
Hastatus Prior
haha yeah, no patience indeed. You get so used to the fast responses you just want it immediately!
I appreciate the offer for the links, but I got it straight. I'm now running 112 link DID x-ring.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #6 of 24 Old 03-13-2012, 11:04 AM
Other than the swing arm markings, the Honda procedure was correct for setting chain tension. However, I could not fit a 114 to my 2002 because if I did so, the adjusters would have been almost all the way out and there would have been no significant adjustment available for wear. I *had* to run 112 to get any adjustment back, and mine was made fairly early in the 2002 run.
post #7 of 24 Old 03-13-2012, 11:12 AM
BBB2's Avatar
You are correct about adjustment procedures being the same. He was asking about the amount of slack and my service manual gives slack based on a 114 link chain. I had no doubt he could run the 112. I'm just glad he didn't trash can that high $$$ DID chain I would like to know what was different about the 02 swing arm that caused "lack of" adjustment for a 114 link cain and what they changed on newer models...
2004 Honda 919 *
* SOLD *
BBB2 is offline
post #8 of 24 Old 03-13-2012, 12:34 PM Thread Starter
Hastatus Prior
Man, just took it out for a ride, and you can really feel the difference with the 112 link chain. Maybe it's just in my head but it felt a lot more flickable.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #9 of 24 Old 03-13-2012, 02:47 PM
Shorter wheelbase.
post #10 of 24 Old 03-13-2012, 02:57 PM
Your wheel base is shorter now, too, you'll feel a bit lighter in the front end, too.
post #11 of 24 Old 03-13-2012, 03:00 PM
Are the 07 112 link...thanks
secondchance is offline
post #12 of 24 Old 03-13-2012, 03:05 PM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
I had chain replaced at a Honda Dealer while returning from California. They cut it at 112 links to give me better chain life(more adjustment). All was well until I sat on the 919 and tried to back it up. The rear tire was rubbing on the aftermarket hugger(Pyramid). They added two more master links to make it right and we were right back at 114 links. Should not be a problem with the stock liner.
Doc
ST-DocLizard1 is offline
post #13 of 24 Old 03-13-2012, 03:26 PM Thread Starter
Hastatus Prior
Doc
Yeah I was worried about that, but I have stock hugger. Yeah its real close but no rubs
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #14 of 24 Old 03-13-2012, 06:11 PM
I'm pretty sure Honda made a swingarm length adjustment in 02.
post #15 of 24 Old 03-14-2012, 08:25 PM
My 2003 is running 112 links.
post #16 of 24 Old 03-15-2012, 07:05 AM
Mine is too. I don't think the swing arms are any different.
post #17 of 24 Old 03-15-2012, 08:53 AM
BBB2's Avatar
Are you guys that are running 112 link chains running the 16/43 tooth sprockets?
2004 Honda 919 *
* SOLD *
BBB2 is offline
post #18 of 24 Old 03-15-2012, 09:37 AM
16/45 actually. 520 chain. I had just enough slack with my axel all the way forward.
post #19 of 24 Old 03-15-2012, 10:26 AM Thread Starter
Hastatus Prior
16/43 sprockets. I had plenty of slack with the tire forward all the way. Had to slide it back a good amount to get it right even with 112 links.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #20 of 24 Old 03-15-2012, 12:45 PM
BBB2's Avatar
This is 114 link chain 17/44 sprockets. How does it compare to yours with 112link chain?
2004 Honda 919 *
* SOLD *
BBB2 is offline
post #21 of 24 Old 03-15-2012, 02:17 PM
Looks like you have plenty of adjustment!
post #22 of 24 Old 03-15-2012, 02:27 PM
BBB2's Avatar
yes Mike and I'm shocked how I had NONE with my old chain at 8000 miles. I was wondering what the guys with the 112 link chain looked like in comparison, hopefully Dee will post a pic of the adjustment on his new setup
2004 Honda 919 *
* SOLD *
BBB2 is offline
post #23 of 24 Old 03-17-2012, 01:34 AM
Who knows but it's St Patrick's Day, so fill yer feckin' boots, mon.
K1w1Boy is offline
post #24 of 24 Old 03-17-2012, 06:28 AM Thread Starter
Hastatus Prior
Yeah, looks pretty much identical
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
