Do you hone plated cylindrers? - Wrist Twisters
 2Likes
  • 2 Post By K1w1Boy
post #1 of 7 Old 10-03-2018, 09:23 PM Thread Starter
I am rebuilding a 2003 YZ125. The bike shows extremely little use internally. The bike sat in a barn for years & mice built a nest in the air box. Eventually mouse pee destroyed the carburetor--actually dissolved the aluminum--& also found its way down to the reed block, crank, & bearings & ruined those too. I think the cases are OK, need to clean them up. The cylinder looks great (case reed so untouched by pee). There is very little riding time on this bike. The cylinder, piston, & clutch basket basically look new. Still nice original cross hatch on the cylinder. Since I am putting in a whole new crank, going to do the top end too. What do I do to prep the cylinder for the new piston & ring? Anything? I have flex ball honed cast iron 4 strokes before but unsure of what is best not only for the plating but don't want to bust only porting either. Half the internet says ball hone it. Half says the world will end if you ball hone it.
Bryce919er is offline
post #2 of 7 Old 10-04-2018, 03:19 AM
If it's a genuine nikasil-type plating, then I definitely wouldn't hone it, I'd just fit the new parts and break them in for a while before running wide open.
mcromo44 and Superdog like this.
K1w1Boy is offline
post #3 of 7 Old 10-04-2018, 08:03 AM
+1, especially since the hatching still looks good. If there was carbon buildup or piston material on the walls, I would consider a light hone using an adjustable cylinder hone. As you mentioned, I think a ball hone would be a bad tool to use in this case.
I'm no expert, just my opinion.
Sent from my XT1575 using Tapatalk
post #4 of 7 Old 10-04-2018, 10:15 AM
Maybe I should have used the word 'deglaze' instead of 'hone'?
post #5 of 7 Old 10-04-2018, 09:17 PM
Back in the day, as long as the Nikasil was not chipped, one simply reringed.
On two strokes, a bad seizure would means scraping out the aluminum, and using acid to eat out any aluminum in the root of cross hatch.
Muriatic acid, as in = 10 % hydrochloric acid, being my recollection.
Normal hones will not work, as one needs a special diamond like hone in the hands of a pro, seeing as Nikasil is essentially nickel with silicon carbide.
post #6 of 7 Old 10-05-2018, 10:21 AM
Re the Nikasil not being chipped.
That comment pertains to the ring sweep zone.
While less than "textbook", a chip, technically a breakout from a previous bad "stick", could be tolerated as long it was not seeing the rings.
post #7 of 7 Old 10-05-2018, 10:23 AM
Quite a bit of what appears to be multiple vertical markings visible in the picture.
Most odd for a low hours engine.
