DIY Dyno tune - Wrist Twisters
post #1 of 24 Old 05-20-2011, 01:20 AM Thread Starter
Carp Killer
Wallybanger's Avatar
DIY Dyno tune
I have a stock air filter, 2 Bros pipes and a PCIII on my 919. I'm finding that I'm still getting a good amount of BLACK soot around my pipe tips and it even blackens my license plate!
I don't really wanna pay for as professional tune because I know it's going to cost me an arm and a leg. That said, if I can spend the money on equipment to do the tuning myself, I call that a win.
Someone else mentioned in another thread that they welded a bung into their pipe and used a wideband O2 sensor with an LED readout to mod their map.
That sounds like a good idea but I would like to log the output so I don't have to look at the readout while I'm ripping. I would also like to log the RPM so I can make a graph.
You can buy fairly cheap OBD2 scan tools which will log data and generate graphs but since our bikes aren't OBD2 I imagine it would take some jerry rigging.
I could ride with a laptop in my backpack but would need some sort of USB adapter for an O2 sensor and RPM readout.
Anyway, I would love to hear some ideas... maybe this tool already exists?
Wallybanger is offline
post #2 of 24 Old 05-20-2011, 01:31 AM Thread Starter
Carp Killer
Guess you could use an electrical signal data logger. Would probably need to build something that would generate the correct voltage output for the RPM.
Electronic Signal Data Logger - Seacom Process Instruments
post #3 of 24 Old 05-20-2011, 01:40 AM Thread Starter
Carp Killer
Scratch last.... looks like this will do the trick
LM-2 Wideband O2 Digital Air/fuel Ratio Meter
Has anyone had the soot issue and been able to rectify it with tuning?
post #4 of 24 Old 05-20-2011, 04:16 AM
Looks like you are back into "arm & a leg" territory. I would investigate if a PC-V and Auto-tune module would work on the bike. You still would need an O2 sensor welded into the exhaust. With this set-up I think you just set the target A/F ratio and it will make it so.
http://www.powercommander.com/downlo...des/AT-200.pdf
post #5 of 24 Old 05-20-2011, 05:38 AM
firedave's Avatar
I gave Pvster's PC111 map a try. After 600kms I had very little soot on my end caps and the exhaust stink is almost gone. Probably be able to get rid of it fully if you went the wide band root, then you could tune for your elevation.
2016 Honda Africa Twin
1998 Kawi ZX9R (Sold)
firedave is offline
post #6 of 24 Old 05-20-2011, 06:32 AM
I'm curious as to what map you are presently running.
It sounds rather rich.
Are you running regular grade gas ? (if not, you ARE wasting money and losing power)
You're near or at sea, correct ?
If you don't have it, LDH's v4 Moriwaki based map is probably the best baseline map to use with twin outlet slipons.
Have you done any map compare work with software ?
IF you have not, and don't want to, feel free to e mail me your map and I'll do a map compare for you.
post #7 of 24 Old 05-20-2011, 06:38 AM
Tirone shoelaces
TexasTraffic's Avatar
Soot issue - YES. It is a PITA.
No attempt to fix, yet.
TexasTraffic is offline
post #8 of 24 Old 05-20-2011, 07:24 AM
I agree....try a different map. Here are all my maps, plus Pvster's is in there, too.
Dropbox - PC3 maps.zip - Simplify your life
Experiment! Clean the tips off and ride hard. Or have someone follow you and they will be able to see the smokey look of a rich exhaust on hard accel. and/or smell it.
Rinse and repeat.
post #9 of 24 Old 05-20-2011, 02:26 PM
Alternatively just ride the heck out of the thing. A few skiddies in your undies does not ruin a day.
post #10 of 24 Old 05-20-2011, 10:49 PM
SiB
SiB's Avatar
I use the LM-2 on my 919, just started. I log AFR obviously, RPM and TPS. Open the datalogs on the laptop and adjust the power commander at the same time. Its obviously not really fast, but its the next best thing to a dyno, and better than using random maps.
SiB is offline
post #11 of 24 Old 05-21-2011, 12:22 AM
Istvan's Avatar
I dont really understand, so you are willing to pay 4-500 dollars for equipment and go through alot of hazzel just so you can make a half-good map. Rather then pay a 150-300 dollars for a pro to make a really great map for your bike on a dyno with numbers to see the difference? Don't get me wrong, but I just think it's a waste of time & money, and you can do it for severeal hours but it wont turn out as good as if a pro did it for 30min on a dyno.
Just my opinion after maping a couple of cars.. Alright if you already had all the equipment to do the map for free. But spending big money on a LM-2 and etc just sounds wrong to me on a bike where even pro's have touble finding a couple of extra HP compared to stock. What they can do for you is to smoothen the hp/nm curve out, which will be impossible for you if you dont have a superb ass-dyno and can feel the difference of 1-2hp difference across the range.
My tip, go to a local tuner with a dyno, talk to him and ask him for 30-60 min of his time, wont cost you that much cause there isn't to much to do on a stock map if you just done some BPU on youre bike.
Just my 2 cents..
Riding a GSX-R 1000 Streetfighter 170whp
Istvan is offline
post #12 of 24 Old 05-21-2011, 09:36 AM
SiB
SiB's Avatar
Just my 2 cents..
Or if you already own the LM-2 from other projects and the closest bike dyno is a 6 hour drive away........ ya I dont have a choice. If you have a tuner with dyno close by for sure do that.
SiB is offline
post #13 of 24 Old 05-21-2011, 01:22 PM
Istvan's Avatar
Offcourse, as I said " Alright if you already had all the equipment to do the map for free. But spending big money on a..." And this was not ment for you buddy. Just my advise for the topic starter as he does'nt seem to own any equipment
Best regards
Istvan is offline
post #14 of 24 Old 05-21-2011, 05:56 PM
Pvester's dyno curves are very very smooth and displaying the expected numbers.
I'm still scratching my head over the actual map, but that is very secondary to what works well.
I'm going to be trying the map out for both typical mixed riding and a track day, a hot track day in particular.
post #15 of 24 Old 05-22-2011, 06:13 PM
touring919's Avatar
I say get the LM2 or similar system. Tuing on the bike on the road is actual use. Much more accurate than dyno. Maybe not the safest.
And it makes perfect sense to buy it. Its a tool. 300 bucks andd the guy never has to pay for a dyno tune every again. On any IC vehicle. Car, bike, heck he could tune his freakin lawn mower if he wanted to. I think its a no brainer to get the software. There is a reason why Bazzaz systems work great on the track. They tune on the track at speed. There are short comings to that system though. And a wide band with a logger would be awsome tool in the tool box.
If you couldn't tell, I want a wide band logger really bad. Havn't had the stars aligne so that i would buy one yet. but it will happen soon for sure.
02 919 (RIP)
07 600RR
07 CRF450X
81 XS850
09 Versys
touring919 is offline
post #16 of 24 Old 05-24-2011, 09:53 AM Thread Starter
Carp Killer
I'm running the map from the Two Brothers website.
Yep, just running regular gas
I'm at 350M (1150ft) AMSL
I haven't done any map compare and I honestly don't know what that is or how to do it.
Can you mess the engine up by running all sorts of different maps? Can you lean things out too much?
Cool, good to know. Where did you put the bung for the O2 sensor? The LM-2 sounds like a really good deal considering it comes with a sensor too.
post #17 of 24 Old 05-24-2011, 11:07 AM
If one really leaned it out on an arbitrary basis at full power and stayed at full power, a hot exhaust valve would likely result, as in possibly burning it.
I suggest you at least try the LDH Mori v4 map.
I have it stored in both the original map format and the present day djm format that your PCIIIusb uses.
If you don't want the bother of getting the map and doing the file conversion (which the PowerCommander software easily does) send me a PM with an e mail address and I get it to you.
Map Compare is a feature within the PowerCommander software that lets you compare two maps on screen. A manual way of doing it is to simply print off the maps and eyeball the different fueling values, not as sophisticated, but does give one a handle on things.
Personally, I'd make sure I tried something different than a Two Brothers map, especially if its an old one, possibly even the M112-003.djm map. The point being, if the maps are as good as their stuff was back then, well, I won't say any more.
post #18 of 24 Old 05-24-2011, 05:50 PM
or you can try MY map : )
post #19 of 24 Old 05-25-2011, 08:47 AM
or,
you can try MY map ;-)
I'll even provide a LINK.
Don't worry Pvster, yours is in there too.
post #20 of 24 Old 05-25-2011, 02:01 PM
or,
post #21 of 24 Old 05-25-2011, 02:42 PM
New link to maps as I've moved some stuff around in our dropbox folder and broke the link.
post #22 of 24 Old 05-25-2011, 03:46 PM Thread Starter
Carp Killer
OK, I've downloaded a bunch of maps and I'll try a map compare. I don't see a 'LDH Mori v4' map anywhere in the stuff I've downloaded....
As for the quality of the 2-Bros stuff, I'm extremely happy with the build quality, fit & finish of the pipes I have.
post #23 of 24 Old 05-25-2011, 04:25 PM
Just sent you the maps you are looking for.
post #24 of 24 Old 05-26-2011, 08:36 PM Thread Starter
Carp Killer
Got em, awesome, thanks.
