Disabling 919 Gas Tank Lock - Wrist Twisters
 3Likes
  • 1 Post By robtharalson
  • 1 Post By Monkeywrench
  • 1 Post By CB700S
post #1 of 15 Old 10-05-2015, 12:52 AM Thread Starter
So, this is sitting on my desk.
It's a Chinese clone cap and ring mated to an original CBR600F4i lock core. Unfortunately, I don't have a key to this. I'd like to be able to swap it onto my bike to get the original one powder coated. I've learned how to take the lock cylinder out from videos on YouTube. Does anyone have any idea how I could modify the lock cylinder so any key or even a screwdriver could open it?
I could always do the "break it with a screwdriver" trick, but I'd rather not do that.
post #2 of 15 Old 10-05-2015, 05:12 AM
Does your 919 key fit in the lock? If you know how to remove the lock cylinder and the key fits you're golden. Once the cylinder is out remove all the wafers and springs, and place just one wafer and spring that coincides with a cut on the key, and you have a locking cap without all the work of putting all the wafers back in (at least the ones that would match the key).
If, however, the key won't fit, just remove all the wafers and springs and leave them out. Anything that can engage the slot in the lock can then be used to open the cap. I have even filed down a penny into a sort of "T" shape and tapped it into the lock to serve as a handle to open the cap during an endurance race for quicker refueling. That probably wouldn't fit under the cover in this case.
WxN likes this.
robtharalson is online now
post #3 of 15 Old 10-05-2015, 09:55 AM
There are only 3 tumblers in the tank lock if memory serves me correctly...it shouldn't be hard to pick. I'd be surprised if a locksmith took more than 5 seconds and charged you for it if you took it to them.
post #4 of 15 Old 10-05-2015, 05:41 PM
I took my mis matched set or locks to a local locksmith. For $20 he gutted the seat lock and gas cap lock so that they work with any key .... or flat key like object now.
post #5 of 15 Old 10-05-2015, 06:18 PM
notsowisecracker
Monkeywrench's Avatar
If you are able to get the lock cylinder out you can stick your key it while out, and file the wafers down to fit.
WxN likes this.
Monkeywrench is offline
post #6 of 15 Old 10-06-2015, 06:50 PM
This might help show you how to disassemble it, but it still might require the key:
post #7 of 15 Old 10-06-2015, 07:00 PM Thread Starter
Yeah, saw that video. I do have a set of lock picks if needed, I just don't want to be picking the lock on my own bike at a gas station. It invites unwanted appearances by the police. :P
post #8 of 15 Old 10-24-2015, 04:02 AM Thread Starter
Posting for future readers' archival reference - assuming our new overlords don't manage to kill the forum through continued mismanagement...
Turns out it actually has five pins. Here's the cylinder as you extract it from the lock core, with three of the wedges removed.
Here's the removed pins and their springs out of the cylinder.
You can use your fingers to remove the pins but you will likely need a pick to remove the springs.
If the cap assembly has already been removed from the tank, you do *not* require the key to remove the lock cylinder. If you want to make this an "any key or a screwdriver can open this" cap, remove all the pins and springs and put it back together. Either way, if you're having problems with your lock, you can strip it down this far, clean up the ancient grease it shipped with, regrease and reinstall.
Here's the lock cylinder reinstalled in the (stripped) core.
The core and cylinder with the rubber cover/diaphragm back over the serpentine fume vent/air equalization vent path.
This is the back of the cap that you screw the core down onto.
This tab with a square hole on the core is the outlet of the tank vent path.
WxN likes this.
post #9 of 15 Old 10-25-2015, 09:01 AM
This reminds me.....I did take video of the locking bits I tore apart, I'll be damned if I remember where they are though.
post #10 of 15 Old 10-27-2015, 11:49 PM Thread Starter
And here's the original one, now powdercoated.
post #11 of 15 Old 10-28-2015, 05:13 AM
Sweet, a nice polished stainless bolt kit from ProBolt and you're done
post #12 of 15 Old 10-28-2015, 06:42 AM Thread Starter
Does it come in black? :P
post #13 of 15 Old 10-28-2015, 08:04 AM
Actually I think they do have a black anodized aluminum set
post #14 of 15 Old 09-04-2019, 07:43 AM
It's really very easy for a locksmith to re-key mismatched gas cap lock.
RobertSteller is offline
post #15 of 15 Old 09-11-2019, 08:22 AM
I don't think it will be easy for a locksmith to re-key that particular lock, dealer must be the suitable option.
JoshClayton is offline
