Died while running and I don't know why yet. Huh. - Wrist Twisters
post #1 of 24 Old 12-19-2015, 01:49 AM Thread Starter
derpydog's Avatar
So I was riding up to see some friends when the new 919 suddenly died on me in traffic. It was raining and cold and I was stuck in some pretty shitty traffic, then all of a sudden, no throttle response, and I looked down to see the oil pressure light came on like it always does when the key is on but the bike isn't running. (Yes, I was so cold and annoyed at that point that the oil light and not the lack of vibration was what clued me in that the engine had just died on me.)
Tried to restart in the road, no dice. A nice stranger held up the other two lanes of traffic for long enough for me to push it across to the shoulder of an offramp, and also took me to the gas station to get some gas. (It wasn't out of gas. But I wasn't going to turn down the offer, just in case.)
So all the lights come on as normal. None of the fuses are blown. The fuel pump seems to be priming-- the FI light comes on with the key, then goes off a second or two after the killswitch is flipped to "run" just like normal. While holding down the starter, the engine kind of coughs and grumbles like it's trying to run, and I could occasionally see the tach get up to 500-1000rpm for a second, but it doesn't stay running. The minute I let go of the starter button, everything shuts back down.
I had a minor mishap while installing heated grips a couple weeks ago and melted some of my own wiring, but it didn't blow any fuses or cause any other damage. (I am not very talented at crimping connectors, i don't wanna talk about it lol.) And I'd ridden at least a hundred miles after that happened with no incident. The battery should be good, it took all my attempts at starting the bike like a champ. Bad ignition coil? Fueling problem? Come to think of it, I hadn't ridden this one in more than a light drizzle before tonight. What are the odds that it's a water-related electrical problem?
It's at a friend's shop now... gonna go look at it tomorrow. It's almost 2am here but this is keeping me up haha.
Fine, I'm adding a signature, leave me alone!
derpydog is offline
post #2 of 24 Old 12-19-2015, 03:08 AM
Well, I'm up because of pain from surgery, but I'll chime in for most folks here, it's probably (90% chance?) related to whatever you last did to the bike if it was working fine before you meddled with it. Any chance your wiring was in the headlight bucket? It could have gotten wet and shorted out.
post #3 of 24 Old 12-19-2015, 07:58 AM
I'll add that wires can be damaged to the point they still work but don't provide the amperage needed. If you damaged some wires that go to something and the device is pulling too much amperage it can run for a while then damage the connection even more.
Also, doesn't cold weather cause weak connections to break, where they might have worked under warm conditions?
post #4 of 24 Old 12-19-2015, 07:04 PM Thread Starter
derpydog's Avatar
Well, I was completely unable to replicate the problem today. Started right up.... Goddammit. One of the older techs thinks that it was cold enough last night that the lovely ethanol-laden fuel that we all love so much, might have separated and let water clog up the injectors. It fits the symptoms as well as anything, I guess. I'll throw some Startron in the tank and top it off with some ethanol-free gas and see if I can't get through a tank without a repeat incident.
derpydog is offline
post #5 of 24 Old 12-19-2015, 07:15 PM
My vote would be the cheesy connections at the kill switch, cold (34) caused my starter switch to prevent the headlight from coming on
post #6 of 24 Old 12-20-2015, 09:09 AM
redline919's Avatar
This is why I never use my kill switch. Too many instances noted on this forum
redline919 is offline
post #7 of 24 Old 12-20-2015, 01:03 PM
do you have a power commander OP?
post #8 of 24 Old 12-20-2015, 01:49 PM Thread Starter
derpydog's Avatar
No power commander. Rode it around the block a little more just now, still unable to reproduce the problem I'll check the right-side controls, since I did have to take those off to install new bars and I'm not ruling out water causing an electrical problem, but the way it wouldn't start the other night really sounded more like a fueling issue.
derpydog is offline
post #9 of 24 Old 12-20-2015, 02:05 PM
RIDE RED
SPYDER's Avatar
Just throwing it out here but when my ignition pulse generator went out my bike would run for 15 minutes almost on the nose then die after the bike cooled it would fire right back up and run for another 15
SPYDER is offline
post #10 of 24 Old 12-30-2015, 02:28 PM Thread Starter
derpydog's Avatar
Happened again today. Got on the freeway, died about five minutes later. Wouldn't restart right after, but after getting it home (~90 minutes later) it will start and kind of idle badly for a few seconds then die, which makes me think whatever the problem is has to do with the bike warming up.
90% ruling out an electrical problem in the right side controls at this point since the killswitch and starter button work as they should and it fires right up when cold and runs great... for about twenty minutes. I hadn't gone for a real ride since two weeks ago when it died, just had it idling for a while and took it around the block, guess it didn't get warm enough for the problem to kick in and fooled me.
derpydog is offline
post #11 of 24 Old 12-30-2015, 03:01 PM Thread Starter
derpydog's Avatar
That's a contender now for sure.
Also the fuel pump priming noise sounds odd to me now. I remember it being 1-2 seconds of a steady mechanical whining noise and now it seems to switch tones halfway through. Been reading old threads on people's fuel pressure regulator problems, not sure if all my symptoms match but the tank does seem suspiciously empty for only having 90 miles since the last fillup.
When I got it off the truck it ran for a minute or so, long enough for me to ride it into the garage. FWIW it was cold but bone dry today so I don't think it's anything moisture/electrical related anymore.
derpydog is offline
post #12 of 24 Old 01-01-2016, 12:25 PM
The change in sound in the fuel pump is a good indicator that it's fouled or failing. I would look there as your culprit, we have another thread somewhere where the symptoms were very close to those you are describing.
post #13 of 24 Old 01-01-2016, 09:44 PM
RIDE RED
SPYDER's Avatar
Pull codes if any and go from there
SPYDER is offline
post #14 of 24 Old 01-02-2016, 01:02 AM
captainchadl's Avatar
Sorry for the repost, but I was using my phone and I was trying to " ".
I had this happen 3 months ago, so I packed the connector with dielectric grease after cleaning the housing up real good. It has been good since.
captainchadl is offline
post #15 of 24 Old 01-04-2016, 02:52 PM
There should be a spot to check the condition of the kill switch. I've never taken one apart on the 919, but they do tend to get moisture and dirt in there.
One option might be to carry a test light with you. Harbor Freight has a good one for dirt cheap, just find a few spots where you can check where the break is.
post #16 of 24 Old 01-13-2016, 02:49 PM Thread Starter
derpydog's Avatar
Just started getting into it today, after the post-holidays/New Years lack of motivation.
FI code showed two blinks, which is a MAP vacuum issue. Manual says the failure mode is "bike operates normally," which is technically true, until it dies while running. So that might be part of it, and I'll put a vacuum gauge on it to check, but I don't think it's the cause.
Took the fuel pump assembly out and popped the filter off. Shot some compressed air through and some brown-black colored gas spatters came out but it doesn't seem obstructed (then again, the air psi may be higher than the bike's fuel psi.)
There was definitely less than half a gallon of gas sloshing around in the tank when I took it off, and my last fillup was 90 miles ago, so even accounting for some idling time when I was trying to get it to die, that's incredibly poor mileage. #2 spark plug doesn't look any different from #1 spark plug, but it's mostly been parked since the first dying incident so possibly hasn't had a chance to really foul out the plugs. Is there a visual indication of a bad FPR? I believe the test for it in the manual needs the bike running so I'll probably get a new fuel filter first before I pop the fuel pump back in the tank, just to eliminate that as a factor.
derpydog is offline
post #17 of 24 Old 01-13-2016, 03:38 PM
RIDE RED
SPYDER's Avatar
Originally Posted by derpydog View Post
Just started getting into it today, after the post-holidays/New Years lack of motivation. FI code showed two blinks, which is a MAP vacuum issue. Manual says the failure mode is "bike operates normally," which is technically true, until it dies while running. So that might be part of it, and I'll put a vacuum gauge on it to check, but I don't think it's the cause. Took the fuel pump assembly out and popped the filter off. Shot some compressed air through and some brown-black colored gas spatters came out but it doesn't seem obstructed (then again, the air psi may be higher than the bike's fuel psi.) There was definitely less than half a gallon of gas sloshing around in the tank when I took it off, and my last fillup was 90 miles ago, so even accounting for some idling time when I was trying to get it to die, that's incredibly poor mileage. #2 spark plug doesn't look any different from #1 spark plug, but it's mostly been parked since the first dying incident so possibly hasn't had a chance to really foul out the plugs. Is there a visual indication of a bad FPR? I believe the test for it in the manual needs the bike running so I'll probably get a new fuel filter first before I pop the fuel pump back in the tank, just to eliminate that as a factor.
Is there fuel or smell of fuel in the vacuum line on your fpr?if so it has most likely failed
SPYDER is offline
post #18 of 24 Old 04-23-2016, 10:16 PM Thread Starter
derpydog's Avatar
Oh boy, it's been a while. Well, I ended up replacing the in-tank fuel filter and the FPR, even though all four spark plugs looked the same and there was no fuel in the vacuum lines or any of the other classic bad FPR symptoms per this forum. Then life happened, I found a great deal on an NX250 which is a bike I'd been low key chasing for two years so I was riding that a bunch, I bought a house, blah blah the 919 sat in my new garage for a couple months. Nicer weather came around and I realized me and my bad shoulder and my case of the squirrelies post-crash had to get in shape for track season, so I started riding the 919 again. It ran perfectly for a week of commuting and then goddamnmotherfuckingshitbiscuits! died on me on my way home. No gas smell, no FI codes, fuel pump priming sound is odd and it cranks but seems like it never quite gets enough gas to get running-- as it cooled down it would idle erratically for a few seconds at a time, and I bet tomorrow morning when it's cold it'll start up again. But at the same time I'm about ready to believe at this point that I'm just stupid and the gas light doesn't work and I'm just running it out of gas. ARGH.
derpydog is offline
post #19 of 24 Old 04-24-2016, 07:40 AM
redline919's Avatar
Have you checked your battery for proper voltage and make sure the connections are tight? Mine acted this way and it was a loose ground to the battery. Which I've had to tighten at least 3 times over the years from vibes and wheelies I suppose. Either that or a bad fuel pump. Check the wires going to the pump for damage also.
post #20 of 24 Old 04-24-2016, 08:08 AM
RIDE RED
SPYDER's Avatar
If it runs until it get warmed up then dies. My money is on the ignition pulse generator. That's what was wrong with mine last season. My FI light didn't start blinking until one time after it died I tried to crank it up again. The IPG is on the throttle side of the engine it attaches to the timing cover. If I remember right it was +\-$50 from partzilla. You'll probably want to get a new gasket too. There are institutions in the manual on how to test the IPG. If you don't have a manual there's a digital copy on here somewhere or I could snap a pic for you. The IPG on my bike pasted when it was cold but failed after warming up.
SPYDER is offline
post #21 of 24 Old 04-24-2016, 11:38 AM Thread Starter
derpydog's Avatar
I haven't tested the battery itself but the connections are tight, and I think I checked the ground when I was last in there but I don't remember now. Each time it's died it'll crank for as long as I care to try with no sign of the battery getting weak, and I remember from my previous 919 that when the battery was on its way out it would kind of hunt for a good idle speed and this one idles dead smooth at 1200 so I've been operating under the assumption that the battery isn't the root cause.
I do have a manual. The infuriating thing is that it's so erratic-- it ran fine for a week of commuting before it died this time, and it was on my way home with no traffic so the engine wasn't even approaching hot. I'll have to test the IPG next week when I can bring my multimeter home from work.
derpydog is offline
post #22 of 24 Old 04-24-2016, 05:25 PM
nathanktm's Avatar
My bike will die with 1/2 to 3/4 galllons of gas left. When my fuel pump runs out of fuel, it will sound a lot more "grindy." Are you 100% sure that you are not running it out of gas? Maybe your low fuel indicator light is dead. You'd be lucky if it was something that simple. As they say, always start with the easiest problem to fix.
nathanktm is offline
post #23 of 24 Old 04-27-2016, 08:31 PM Thread Starter
derpydog's Avatar
The first time this happened I had 80-something miles on the trip odometer, and historically I'm more likely to forget to reset that at a gas stop than I am to accidentally reset it in the middle of a tank. I also had a kind stranger stop and take me to a gas station, and I got about a half gallon to put in the tank and it didn't make a difference. So I was almost certain it wasn't a simple running out of gas, plus the fact that it'll start up seemingly fine if I leave it overnight. But you're right, the simplest explanation is usually best. Maybe a combination of the fuel getting low enough and the bike being warmed up...?
derpydog is offline
post #24 of 24 Old 04-28-2016, 03:44 AM
nathanktm's Avatar
Well if your pump truly is making that noise, either the pump itself is failing, or something else is causing issues with fuel getting to the pump. I don't think you should be seeing brown-black spatters coming out of the fuel pump. That's leading me to think bad gas is a possibility. Water will typically sink below the fuel since it's more dense, so perhaps you have a little bit sitting at the bottom of the tank. It'll get shook up during the ride, and mix with the gas causing the sputtering/stalling. Letting it sit will have it settle back at the bottom of the tank below the fuel pickup, and eventually the pump picks up the fuel again. Not sure how long that 919 was sitting for before you started riding it. People typically have issues with gas going bad after leaving their bike to sit the whole winter. If you emptied the tank out and had only fresh gas in there and it STILL stalled out, and you are 100% certain you had enough gas that the bike wasn't starving, then my guess would be that the pump might have an issue. Just throwing out ideas
