Desmogging the Super Duke - Wrist Twisters
post #1 of 25 Old 05-28-2011, 05:29 PM Thread Starter
Removed the carbon evap canister on the Super Duke today, gained a whole bunch of space under the seat...
Before
Naked bike
It had two hoses, one is a gas tank vent and has to be left open, I routed it down by the rear cylinder and out the bottom with another hose. It's the small hose on top of the frame.
The second hose runs to a valve on the front of the airbox, then tees off and goes to a nipple on the side of each cylinder head. I just removed the single hose from the canister to the valve and plugged the valve nipple, the other tee hose going to the cylinders can be removed and capped as well, but it will take removing the airbox to access the front cylinder. I'll wait until the SAS removal plates come in off back order and do it all at once.
The gas tank pivots on two bolts at the rear, removing a single bolt in front allows you to lift it up to access the airbox. Several threads on the Super Duke forum warned that it's a bitch to get the gas tank bolt lined up again and you have to remove the pivot bolts as the plastic tank tends to expand, especially when full of gas which mine was. Sure enough the mounting tab on the tank was way off from lining up with the frame, but it seemed like undoing the pivot bolts was only going to complicate matters worse. I took a large flat screwdriver, wrapped the tip in tape, inserted it between the front of the tank tab and the top triple and gently pried until the bolt dropped into place.
It had virtually no underseat space before, registration slip was all that fit. Can fit a towel, small chamois, kickstand pad, helmet cable lock, and even the tool kit if I want.
Makes zero difference in how the bike runs, the tank just vents to the atmosphere now instead of back through the airbox. Hopefully the SAS kit (think PAIRS plates) will be here soon, can get rid of the rest of the plumbing. Also ordered 02 sensor eliminators, let you unplug the sensors without tripping the light. Supposed to eliminate the low throttle snatchiness, which does make the bike a handful in low speed corners and around town, easy to lurch forward when you're only trying to apply a little throttle.
post #2 of 25 Old 05-28-2011, 05:39 PM
Nice work Scott. Dang that canister took up a lot of room. That's a clean machine and looks very well built. All the wires and cables very neat and tidy. Also the bike looks kinda cool without the little orange wings on the front. I always wondered what it looks like without them.
Hope the mods work out well
post #3 of 25 Old 05-28-2011, 05:44 PM Thread Starter
Thanks Mike, I'm enjoying getting to know the bike as I mess with it. Definitely well built, interesting to see how KTM designs things, different than the Japanese bikes that make up the bulk of my experience.
post #4 of 25 Old 05-28-2011, 06:24 PM
Very cool.
What's the banjo bolt for in the one picture?
2015 Ducati Monster 1200S
FlyCatcher is offline
post #5 of 25 Old 05-28-2011, 06:49 PM
Originally Posted by FlyCatcher View Post
Very cool.
Hydraulic Clutch
post #6 of 25 Old 05-28-2011, 07:04 PM Thread Starter
Hydraulic Clutch
Ding ding ding
post #7 of 25 Old 05-28-2011, 09:47 PM
schrock86's Avatar
That's quite the nice storage space now.
schrock86 is offline
post #8 of 25 Old 05-29-2011, 12:08 AM
Darn I like that bike. I hope that's a brand new rear tyre .........
post #9 of 25 Old 05-29-2011, 06:50 AM Thread Starter
Brand new bike, only 350 miles on it so far. Lots of chicken strip to scrub off still!
post #10 of 25 Old 05-29-2011, 12:54 PM
i always drool over the duke's ... they sound so SO mean.... id probably kill myself on one, id be railing a corner then flog the throttle like i do on the 919, and the stupid torque of the duke would just spin the rear tire.
post #11 of 25 Old 05-29-2011, 06:09 PM
I am pretty set on a new Tuono when they eventually get here. Worried about the same thing. How do you manage 160HP on a 400# bike without wadding it up on every turn
post #12 of 25 Old 05-29-2011, 06:24 PM Thread Starter
Even 120hp on a 390lb bike takes some finesse, still learning how to get the most out of it without scaring the hell out of myself.
post #13 of 25 Old 05-29-2011, 07:06 PM
and its not necessarily the HP... i have ridden 600cc sport bike with more hp than the duke or the 919... its that stupid low end of the duke. i mean 65+ ftlbs at the rear wheel from 2.5k rpms on... peaking at 73... bejezus. the 919 peaks at around 65 ft lbs at the wheel... at 2.5k rpms... maybe 50 ftlbs. and a time or two i have managed to be relativity lugging it and spin the rear tire on a rapid throttle opening.
i cant imagine 15ish more hp and tons more torque on a 60-70lb lighter bike (duke) .. ya id get myself introuble REAL quick.
post #14 of 25 Old 05-30-2011, 06:44 AM Thread Starter
Yeah, it pretty much has instant power as soon as you barely twist the throttle, that's what makes the low throttle snatchiness an issue, easy to accidentally give too much power when you don't want it. The O2 sensor eliminators are supposed to cure that problem, the O2 sensors only provide readings under a certain rpm to meet emission standards, when disconnected it smooths out the on/off throttle characteristic.
This thing does rev fast, hits the rev limiter in an instant!
post #15 of 25 Old 05-30-2011, 08:57 AM
ya i have heard the 02 sensor eliminators do nice things, tiz a shame they are only on their for emmission reasons, as a closed loop system is much better for fuel mapping!
post #16 of 25 Old 05-30-2011, 11:24 AM
KTM should have put the battery where tha char can is.
You need to put a filter on one of those lines. I for get which one. Spykes can tell you which one.
It seems some SDs are a lot more abrupt than others. KTM revamped the ECU somewhere around 08, which may explain that. I think mine is just fine.
For all their ferocious rep, You'd have to do something very stupid to get a Super Duke all crossed up. Even at that, I think you could reel in a SD long after other bikes have signed off. Either they're that good, or they inspire that much confidence. I don't know which. Mine is very easy to ride. If you get one, stock up on pucks.
post #17 of 25 Old 05-30-2011, 06:28 PM
mambomonster's Avatar
How does the SD sound compared to a Ducati? Does it have that sweet, v-twin, torque tune? Maybe you posted a clip of your FMFs already?
mambomonster is offline
post #18 of 25 Old 05-30-2011, 06:45 PM Thread Starter
I've not made a sound clip, will have to work on that. It's loud...very loud...snarling, barking loud, sounds fantastic!
post #19 of 25 Old 05-30-2011, 06:56 PM
they sound better IMO..... its like pure sex purring there.
and ya the superduke battery location is WACK.
also no need to put a filter on the vent line for the fuel tank... most bikes done have it, if you REALLY want to you can but def not necessary.
post #20 of 25 Old 05-30-2011, 07:02 PM Thread Starter
That's what I figured, it's just a vent tube.
post #21 of 25 Old 08-06-2011, 10:12 PM Thread Starter
SAS plates finally arrived off back order. Have the O2 plugs already, time to finish the desmogging!
post #22 of 25 Old 06-16-2012, 08:00 PM
Doing this Evaporectomy too
Ive got an SD also, I'm about halfway done with this process and I'm curious why you took the tank off did you have to to get to the valve on the air box you mentioned? What did you use to plug the nipple on the solenoid?
Thanks!
Dcastor is offline
post #23 of 25 Old 06-16-2012, 08:05 PM Thread Starter
Thanks!
The airbox is much easier to access with the tank lifted up, and only one bolt to allow the tank to tilt so no big deal. I've completely removed the solenoid and all the associated plumbing now, as well as the SAS valves and installed block off plates.
Superduke
R1200GS
XR650L
post #24 of 25 Old 06-16-2012, 08:10 PM
I understood but I don't think I want to go as far as you did...so curious what you did to block off that valve until you pulled did the SAS kit.
Dcastor is offline
post #25 of 25 Old 06-16-2012, 08:19 PM Thread Starter
I just wrapped electrical tape around it, not a high suction valve.
Superduke
R1200GS
XR650L
