Dead bike - Wrist Twisters
post #1 of 12 Old 04-28-2013, 12:52 PM Thread Starter
Flatulent
Dead bike
2007 919 with 16k. New battery and ran before storage for winter.
I was putting the battery back into the bike today and I had the neg cable hooked up and my hand slipped and the positive terminal touched the metal part of the fuel line coming from the tank. Sparked, some light smoke at the battery. Reassembled, checked fuses for FI, starter and main 30 amp fuse all good.
Bike will turn on, lights come on, no fuel prime(yes the handlebar switch is in the start position), bike turns over just not getting fuel. Just hear a click in the area of the ECM. Did I fry it? I hope there is something I am missing, as I believe I have checked everything else.
Jon
sodakshooter is offline
post #2 of 12 Old 04-28-2013, 02:17 PM
Check battery voltage. Might have enough to turn over but not enough to fire. Hopefully others will chime in with more ideas.
post #3 of 12 Old 04-28-2013, 02:37 PM Thread Starter
Flatulent
Voltage is good. I checked the FI for errors, no flashing just stays lit.
Basically the FI isn't working and the fuel pump starting. I guess I will try to get the bike into a shop in the next week or two.
post #4 of 12 Old 04-28-2013, 02:59 PM
Double check ALL fuses.
post #5 of 12 Old 04-28-2013, 03:03 PM Thread Starter
Flatulent
I have and I replaced them all to make sure.
post #6 of 12 Old 04-28-2013, 03:07 PM
Batman
velodesign's Avatar
Clutch cable loose or kick stand sensor?
velodesign is offline
post #7 of 12 Old 04-28-2013, 03:18 PM
Kill switch? You in neutral? Clutch sensor wiring plugged in (or whatever it is that plugs to the clutch lever assembly)?
post #8 of 12 Old 04-28-2013, 03:39 PM
If the FI light stays lit, the computer's probably toast.
post #9 of 12 Old 04-28-2013, 04:14 PM Thread Starter
Flatulent
Looks like the fuel pump is fried. Tested by running 12v direct and nothing. The positive terminal struck the tube that goes into the pump.
So be careful when reinstalling your battery. If I would not have had both the positive and negative cable connected this would have never happened. Next time I will wait until the battery is in place before connecting the negative.
Jon
post #10 of 12 Old 04-28-2013, 04:20 PM
Hastatus Prior
TheBeeDeeGee's Avatar
Daaaan sucks man. At least you didn't fry the computer. That woulda been $$$$
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #11 of 12 Old 04-28-2013, 07:37 PM Thread Starter
Flatulent
She lives!!! Apparently when I tried to test it direct from battery my wires didnt hit the right spots. I pulled the tank and tested again and the negative fuel pump cable fried. Patched it and she is back to purring like a kitten.
Jon
post #12 of 12 Old 04-28-2013, 08:34 PM
NWTB Non Stinky 919
jeffie7's Avatar
Awesome gotta love easy fixes.
Now it's time to drill your undertail for a tag relocate kit.
jeffie7 is offline
